Boston Acoustics TVee 26 Soundbar
tvee 26
Boston Acoustics introduced the TVee 26 Soundbar with Wireless Subwoofer for $349.99. The compact, “plug and play” speaker system offers total system power of 150 watts (RMS), for adding high-quality, and dynamic audio to TV programs, movies, games, and music. Like all Boston Acoustics soundbar systems, the TVee 26 is designed for total ease-of-use and flexibility, with both optical digital and analog inputs, including a mini stereo AUX input to connect mobile devices
The elegant and space-saving TVee 26 Soundbar includes dual 2″ x 5″ built-in drivers that feature a light and rigid elliptical cone with a highly complex shape to reduce distortion and enhance dynamic performance. Adding to the TVee 26’s best-in-class audio performance is Boston Acoustics’ low-distortion, wide-bandwidth “HHRT” (Hyperbolic High Rigidity Transducer) driver technology. The unit’s deep low frequency punch is made possible by the powerful subwoofer, and Boston’s unique BassTrac circuitry ensures the absolute minimum of distortion at all times. The system’s frequency range is 40Hz – 20kHz and with its sleek design (a 31″ bar just over than 3-1/4 inches high and less than 3 inches deep, plus the compact wireless subwoofer), the TVee 26 is both unobtrusive and powerful.
Notably, the TVee 26 features a simple “one wire hookup,” plus integrated keyhole-style wall mounts for quick and easy set-up right out of the box. The TVee 26 features touch sensitive front controls,and thanks to its remote-learning capability, it is designed to work seamlessly with a user’s existing remote control.
The TVee 26 features Dolby Digital decoding and Boston Acoustics’ Digitally Optimized Virtual Surround (DOVS) processing for pinpoint, theater-like surround effects and room-filling audio. The system’s “Movie Mode” and “Music Mode” options allow users to easily optimize their soundscape, depending on content.
Features:
  • Unobtrusive Bass Powerhouse: The TVee 26’s wireless subwoofer can be placed anywhere in the room, even out of sight, which adds to the system’s convenience and flexibility.
  • Easy “one-wire” hookup makes it a snap to install so you can start enjoying the system right out of the box;
  • Elegant design to blend with most TV’s and any room decor;
  • Dedicated Music Mode for improved music listening;
  • Touch sensitive controls on the front panel allows users to select power, volume, mute, digital or analog sources and movie/music mode;
  • Digitally Optimized Virtual Surround processing for pinpoint, theater-like, surround effects and better on screen dialog.
Price & Availability
The Boston Acoustics TVee 26 Soundbar with wireless subwoofer is available now for $349.99.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
