Boston Acoustics TVee 10 Soundbar
tvee-10
Boston Acoustics introduced the slim, space-saving TVee 10 Soundbar for $199.99. The speaker includes its own built-in 30-watt amplifier, simple setup and low-frequency capabilities, so you can forgo a separate subwoofer. The “plug and play” TVee 10 features both digital and optical analog inputs as well as a mini stereo AUX input to connect mobile devices.
With a sleek new design less than 3 1/2 inches high and 3 inches deep – even smaller than previous Boston Acoustics soundbars, the TVee 10 is a simple solution for adding room-filling audio to virtually any TV. The super easy one-wire hook-up allows users to connect the soundbar directly to their TV in one simple step. As soon as the soundbar is plugged in, users can immediately start enjoying their new TV sound experience. Ideally sized for TVs 32″ or larger, the TVee 10 features integrated keyhole-style wall mounts for total ease of set-up. The TVee 10
features touch sensitive front controls, and thanks to its remote-learning capability, it is designed to work seamlessly with a user’s existing remote control.
The TVee 10 features Dolby Digital decoding and Boston Acoustics’ Digitally Optimized Virtual Surround (DOVS) processing for pinpoint, theater-like surround effects and room-filling audio. The system’s “Movie Mode” and “Music Mode” options allow users to easily optimize their soundscape, depending on content. The TVee 10’s soundbar achives its superior best-in-class audio performance through the use of Boston Acoustics’ low-distortion, wide-bandwidth “HHRT” (Hyperbolic High Rigidity Transducer) driver technology. The dual 2″ x 5″ drivers feature a light and rigid elliptical cone that uses a highly complex shape to reduce distortion and enhance dynamic performance. Boston’s unique BassTrac circuitry ensures powerful low-frequency audio without distortion. Frequency range is 70 Hz to 20 kHz.
Features:
  • Easy “one-wire: hookup makes it a snap to install so you can start enjoying the system right out of the box;
  • Elegant design to blend with most TV’s and any room decor;
  • Better music with dedicated Music Mode, provides listeners with a rich and luxurious music listening experience;
  • Touch sensitive controls on the front panel allows users to select power, volume, mute, digital or analog sources and movie/music mode;
  • Boston Acoustic’s Digitally Optimized Virtual Surround processing for pinpoint, theater-like, surround effects and better on screen dialog.
Price & Availability
The Boston Acoustics TVee 10 Soundbar is available now for $199.99.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
