Loudspeakers
Boston Acoustics SoundWare Speaker Line Expanded
New Models Feature the Unique SoundWare Shape and Flexible Placement Options
Boston Acoustics, Inc., a world-renowned manufacturer of high-performance loudspeakers, is adding two new models to its popular line of innovative SoundWare speakers, including the SoundWare XL (MAP: $249.99) 2-way 6 1/2″ speaker geared for 70/100 volt constant voltage commercial applications, and the SoundWare Sub 8″ 100-Watt Powered Subwoofer ($399.99). The new SoundWare models feature the line’s signature polyhedron shape, which allows for a wide range of easy and flexible placement options. Both are ideal for use in homes, apartments, restaurants, and retail stores and SoundWare XL can be used for outdoor entertaining as well. SoundWare speakers are a unique combination of sonic performance, space efficiency, and application flexibility.
SoundWare XL: Great Sound Anywhere — Inside or Out!
Thanks to the same tough weather-resistant construction and build materials of the original Boston Acoustics SoundWare loudspeaker, the SoundWare XL is ideal for either indoor or outdoor applications. Available in either black or white finish, the new SoundWare XL 2-Way speaker features a high-performance 1″ tweeter and a 6 1/2″ copolymer woofer for big rich sound. The 70v/100v constant voltage SoundWare XL is also ideal for multiple speaker commercial installations. Additionally, for commercial applications there is a “Safety bar” on one of the speaker surfaces allowing for secondary independent security mounting if desired.
Incredible Placement Flexibility
With its polyhedron shape and unique articulating mounting bracket, a SoundWare XL speaker can be placed virtually anywhere — flush in a corner, flat on a wall, flat on a table or angled up 30 or 45 degrees on a flat surface. The 2 included brackets mount the speaker just 1 cm from any flat surface or flush in a corner. When mounted flush on a wall, the speaker can be articulated down or sideways to provide the ideal sonic angle.
SoundWare Sub Delivers Deep Rich Bass Up and Down
The new SoundWare Sub 8″ Powered Subwoofer, with its powerful 100-watt amplifier, can be oriented either as forward- or down-firing for placement and application flexibility. It is specifically designed for bundling with either the original SoundWare or SoundWare XL to create a great sounding and looking complete speaker system.
Make It Stand Out with “Paint-Ready” Surfaces…
For consumers who want to customize the look of their SoundWare speakers to stand out or complement the decor of any environment, all SoundWare speakers feature paint-ready cabinet surfaces.
About Boston Acoustics
For nearly 30 years, Boston Acoustics has remained at the leading-edge of audio excellence, designing, manufacturing and marketing innovative high-performance loudspeakers for use in home audio and home theater systems, as well as aftermarket, OEM automotive systems, and custom installations. Highly regarded for creating The Boston Sound, the company commits all of its resources in design, engineering and manufacturing to create superior, competitively priced products that emphasize performance, consistency, reliability and value. For more information on the company’s full range of advanced loudspeakers, as well as its “tabletop radio” products and more, please visit BostonAcoustics.com.
Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
Bang & Olufsen Beosound Balance Natura Wireless Speakers Bang & Olufsen Beosound Balance Natura Wireless Speakers
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Advance Paris Link Cables Advance Paris Link Cables
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Sony's new 2025 model year BRAVIA TVs Sony's new 2025 model year BRAVIA TVs
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
Sony BTAVIA Projectors - 2025 Sony BTAVIA Projectors - 2025
Sony just brought its most powerful video processor for projectors down to what should be a much more affordable price point.
