Car Speakers
Boston Acoustics SE Series Car Speakers
Boston Acoustics introduced the SE Series performance car speaker line. Offering true Boston performance at entry-level price points, the 11 models of the SE Series provide a wide array of drop-in installation options for popular OEM sizes focusing on efficiency and great sound using your existing radio or small amplifier power. With two component and nine coaxial models, there is sure to be an SE speaker to fit your car.
Type-S3 Tweeter
SE component models utilize Boston's Type-S3 3/4″ soft dome tweeter. Neodymium tweeter magnets provide an extraordinary power-to-size performance ratio to maintain a compact tweeter size, while Ferrofluid cooling is used for increased power handling. The dome material, a carbon injected polymer, offers a perfect blend of detail and robust output. SE components include multiple tweeter cups allowing for maximum flexibility with installation options for surface-angle, flush-angle, or flush-mount applications. As with all Boston coaxial speakers, the SE coaxial models feature Boston's CATB (Contoured Asymmetrical Tweeter Baffle), which delivers smoother extension and consistant response both on- and off-axis. Redesigned for SE, the new CATB offers a 20% improvement in off-axis response over the previous design.
Woofers and Crossovers
The woofers in all SE Series speakers use 1-inch voice coils, and are built with copolymer cones and butyl rubber surrounds to ensure dependable, uninterrupted performance under the extreme environmental conditions found in automotive environments. Boston Acoustics integrates each SE model with a specifically tuned crossover to deliver a smooth transition between woofer and tweeter. Unlike the coaxial models, which utilize an internal crossover, the SE component models feature compact external crossovers. The component crossovers feature a unique design that can be docked together for presentation or paired with the ISTS imaging system crossovers.
Metal Grilles
Key sizes in the SE Series (SE55, SE50, SE65, SE60, SE95 and SE953) feature metal mesh grilles for optimum protection for the woofer when installed in non-factory locations. Additionally the tweeters for the SE component systems also feature metal grilles for equal protection.
The new SE Series is comprised of 11 models including two component and nine coaxial configurations and is shipping now.
Coaxial Speakers (round) Coaxial Speakers (oval) Component Speakers
SE35 SE75 SE50
2-way 3 1/2″ Coaxial 2-way 4 x 6″ Coaxial 2-way 5 1/4″ Component
US MSRP $69.95/pr US MSRP $79.95/pr US MSRP $149.95/pr
SE45 SE85 SE60
2-way 4″ Coaxial 2-way 5 x 7″ Coaxial 2-way 6 1/2″ Component
US MSRP $79.95/pr US MSRP $119.95/pr US MSRP $149.95/pr
SE55 SE95
2-way 5 1/4″ Coaxial 2-way 6 x 9″ Coaxial
US MSRP $99.95/pr US MSRP $129.95/pr
SE65 SE953
2-way 6 1/2″ Coaxial 3-way 6 x 9″ Coaxial
SE65RC
2-way 6″ Coaxial
US MSRP $119.95/pr
All models available internationally soon.
SilentPower Omni Lan Connection Front
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
