Boston Acoustics M Series Home Theater Speakers
mseries
Boston Acoustics introduced seven new
M Series speakers for multi-channel home theater as well as traditional high-fidelity 2-channel music systems. The new M Series offers a step up from their entry level A Series loudspeakers announced last year.
The M Series lineup features three floorstanding speakers, the flagship 3-way M350 ($2,499/pr), with four 5-1/4″ woofers and a 4” midrange, the slightly smaller 3-way M340 ($1,999/pr) with four 4-1/2″ woofers and the smaller yet 2-way M250 ($1,499/pr) with one 5-1/4″ midrange/woofer combination and dedicated 5-1/4″ woofer. Also included in the series is a 2-way bookshelf model M25 ($799/pr), with one 5-1/4″ woofer, as well as the compact center-channel MCenter ($599) with dual 4-1/2″ woofers, the satellite MSurround ($748/pr), and the powerful MSubwoofer ($1,199).
Boston Acoustics M Series loudspeakers are distinguished visually by their elegant rounded cabinet designs, high-gloss finish and premium quality, leatherette covered baffles. All speakers are available in gloss black with black faux leather trim. The look of the M series brings together classic and modern design cues, making them ideal for easy integration into any home decor. All M Series models are designed to blend seamlessly with each other and to mix and match with other Boston Acoustics speakers providing great results regardless of the system configuration and speaker types. Notably, the four-woofer construction in the floorstanding Models M340 and M350 makes it possible to keep the cabinets slim and elegant to fit in today’s living environment – while still delivering serious deep bass performance.
The M Series was created to deliver exceptionally accurate and natural sound reproduction from an aesthetically pleasing design, with each speaker specifically engineered to provide superior acoustic results for the intended application. There are several key innovations that provide the framework for their astoundingly accurate, powerful and immersive sound. The bookshelf and floorstanding models utilize Boston’s innovative Extended Wide Bandwidth (EWB) tweeter in its second generation. Engineered after an extensive research and development effort, the EWB design combines a lightweight high tensile strength fabric diaphragm with a Coupled Dual Concentric Diaphragm (CDCD) design, and an aerodynamically tuned central vent. Notably, the EWB tweeter is different than most tweeters, with a large radiating surface that extends from the center through the crease out to outside perimeter of the diaphragm (which doubles as the surround). This unique design significantly lowers the moving mass of the tweeter diaphragm which makes it better able to track subtle treble details. The result is more stable linear motion, extended high-frequency response, lower distortion and improved clarity in the high registers.
One of the keys to the enhanced performance and wide sonic dispersion of the M Series MCenter and MSurround is the innovative Balanced Mode Radiator (BMR). The BMR is a piston radiator and a bending mode radiator, covering the range normally handled by both tweeter AND a midrange, without a crossover.
Additionally, the polypropylene midrange drivers with mass loading (in Models M350 and M340) provide smooth overall response with minimal coloration in the critical midrange frequencies, which must reproduce the most important part of vocals or the fundamental frequencies and first harmonics of acoustic instruments. For even improved accuracy, the midrange drivers live in their own separate chamber. The polypropylene woofers in M Series speakers are lightweight and rigid with large motor structures for maximum low frequency output and heat dissipation. Notably, a specially engineered Quad-Woofer Array in the M350 and M340 loudspeakers further enhances performance by creating multiple floor reflection points, which helps to smooth out the bass response at the listening position, and allows the speakers to generate their powerful soundfield with a significantly slimmer form factor.
M Series speakers also feature Boston Acoustics’ breakthrough Lo-Q cabinet construction for pure sound reproduction and the absolute minimal interference from the cabinet. This specially designed speaker enclosure (included in all models except the MSub and MSurround (where it is not necessary) ensures the absolute minimum of potentially sound-degrading cabinet vibration.
Key to the effectiveness of the Lo-Q cabinet is a double layer of Medium Density Fiberboard (MDF), joined with a layer of acoustic damping adhesive in the middle. This new construction significantly outperforms conventional cabinet designs, with exceptionally low resonance and ideal acoustic response.
The M Series MSubwoofer features an internal power amplifier rated at 500 watts (1,000 watts of peak output). The amplifier is mated to a specially designed 10” woofer capable of handling this much power. The woofer features high excursion capabilities, a heavy duty surround and a large voice coil. There are also two 8” passive radiators – one on each side of the cabinet – that allow the subwoofer to play the lowest notes and to reproduce the loudest peaks with low distortion in a relatively small enclosure. Finally, the internal power supply includes a large toroidal transformer to keep plenty of power on reserve so the subwoofer can handle even the most demanding music or film soundtrack with absolute ease and authority.
Price & Availability
M350 Floorstanding Speakers $2,499/pr
M340 Floorstanding Speakers $1,999/pr
M250 Floorstanding Speakers $1,499/pr
M25 Bookshelf Speakers $799/pr
MSurround Surround Speaker $748/pr
MCenter Center Speaker $599 each
MSubwoofer $1,199 each
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
