Car Amplifiers
Boston Acoustics GTA Series Car Amplifiers
Boston Acoustics is now shipping six new models for its GTA Series of car amplifiers. These new models deliver an impressive increase in power over their predecessors (up to 25%), while maintaining the same footprint.
Performance Features
Boston GTA amplifiers employ a host of performance-enhancing features not commonly found in amplifiers at their price points. GTA amplifiers are available in both Class AB and Class D designs, as well as a hybrid model. The high-efficiency Class AB models are specifically designed for better sound quality in full-range applications. The Class D models provide optimum power delivery for subwoofer applications, while the hybrid 5-channel amplifier offers the best of both worlds. All models feature adjustable 12dB/octave highpass and 12dB/octave lowpass crossovers. These can be combined in the Class D models for bandpass operation, using the highpass crossover as a subsonic filer. To offer further system “tweaking” power, Boston has incorporated Q-Tune bass enhancement in all models, and, in the Class D models, user-adjustable “Q” for each amplifier's highpass crossover filter to allow the user to optimize the bass from the subwoofer system without overloading.
Because today's vehicles are full of noisy electronic components that sometimes cause noise interference, Boston's SST (Symmetrical Signal Topology) system uses balanced asymmetrical inputs for noise cancellation to ensure that any noise introduced will be removed from the audio path, not amplified by it.
Installation Features
Boston engineers were challenged with very specific design goals for the new GTA amplifiers: to deliver the greatest flexibility for installation ease and locations. Using an extruded aluminum chassis, GTA amps pack a ton of features and power into a compact footprint. Further reducing the overall footprint, Boston's IMS (Integral Mounting System) allows for direct mounting through the amplifier without the need for extended mounting feet or tabs, saving more precious space.
Boston has extended compatibility of the GTA models with widest possible range of head units, factory adapters, and system preamps thanks to dedicated High- (speaker level) and Low- (RCA) level inputs with wide-ranging input sensitivity (200mV to 5V for Low, and 400mV to 10V for High). For added convenience, input/output connections are located on one side of the amplifier, with optimal angled speaker and power blocks for easy wire connections; while recessed control panel permits clean installation with wires concealed.
All GTA amps are designed to increase flexibility and installation ease while retaining full use of interior space, which is so critical as consumers opt for smaller, fuel-efficient vehicles. The new GTA amps received careful consideration of cosmetics to ensure a cohesive blend with legacy models offering seamless integration.
Additionally, the GTA-RSL is an optional remote level control that gives the user independent level adjustment, from the comfort of the driver's seat, of the subwoofer's output level, beyond the standard system volume control.
Price and Availability
Boston Acoustics GTA Car Amplifiers are now shipping.
GTA-602: $149.95
High-Performance 2-Channel (60Wx2; AB amplifier)
GTA-802: $179.95
High-Performance 2-Channel (80Wx2; AB amplifier)
GTA-704: $229.95
High-Performance 4-Channel (70Wx4; AB amplifier)
GTA-500m: $229.95
High-Performance Monoblock (500Wx1; Class D amplifier)
GTA-1000m: $349.95
High-Performance Monoblock (1000Wx1; Class D amplifier)
GTA-1105: $399.95
High-Performance 5-Channel (70Wx4 + 400Wx1; Hybrid AB-Class D amplifier)
GTA-RSL: $19.95
Optional Remote Subwoofer Level Control
Related News
Previous Boston Acoustics GTA Amplifier models (Sept. 2009)
More Coverage
→ Latest Boston Acoustics News and Reviews
→ All Car Amplifier Reviews
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
