Earbuds & In-Ear Headphones
Bose QuietComfort Ultra Earbuds 2nd Gen: Same Silence, Smarter Sound
Bose updates its QuietComfort Ultra Earbuds with better ANC, wireless charging, and smarter voice pickup—ready to challenge Sony and Apple in 2025.
Bose QuietComfort Ultra Earbuds (2nd Gen) - Lifestyle Man
There’s no cruising in the wireless earbud market—not when Sony, Apple, and Sennheiser are all gunning for the same slice of premium territory. Incremental updates aren’t optional anymore; they’re survival. Bose clearly got the memo. The new QuietComfort Ultra Earbuds 2nd Generation take over as the brand’s flagship and arrive with just enough refinements to keep them in the conversation.
You still get the signature Bose comfort, stability, and industry-leading noise cancellation, but the upgrades are aimed squarely at what matters in 2025: smarter ANC, sharper voice pickup, and—finally—wireless charging.
In a category where everyone is chasing perfection at 30,000 feet and in crowded gyms, Bose is trying to keep its crown by polishing the essentials.
bose-qc-ultra-2nd-gen-tws-4
Smarter Sound and Noise Cancellation: Bose Leans Into AI to Stay Competitive
Like the first-gen Ultra, the new QuietComfort Ultra Earbuds 2nd Generation stick with Bose’s CustomTune calibration technology, which personalizes both the sound and ANC to the shape of your ear—and adjusts dynamically as your surroundings shift. That feature isn’t going anywhere, but Bose is layering in AI where it counts.
The biggest update? A new AI algorithm now works with the noise cancellation system to deliver a more fluid Aware Mode experience. Instead of jarring jumps when the environment suddenly gets louder—think trains, sirens, or that guy on his phone at full volume—ActiveSense now reacts more smoothly, keeping your music or podcast front and center.
Bose is also bringing AI into voice calls. The second-gen Ultra Earbuds use a combination of eight mics, dynamic mixing, and adaptive filters, but it’s the AI-powered noise suppression—borrowed from Bose’s work in hearing aids—that really makes the difference. Wind, office noise, and general chaos get pushed into the background, leaving your voice clean and clear whether you’re using one earbud or both.
Improved Fit and Hygiene: Subtle Tweaks That Make a Daily Difference
Bose didn’t reinvent the form factor, but they did make a few small, smart changes to improve long-term comfort and reliability. The 2nd Gen QC Ultra Earbuds now come with redesigned eartips that include a built-in guard to help prevent earwax buildup—something most brands pretend isn’t an issue.
This simple addition makes it easier to clean the buds and helps maintain consistent audio performance over time. It’s not flashy, but for anyone wearing earbuds all day, it’s a meaningful upgrade that keeps the sound cleaner and the fit more secure.
bose-qc-ultra-2nd-gen-tws-3
Wireless Charging and Smarter Controls: Quality-of-Life Updates That Matter
Bose finally adds wireless charging to the 2nd Gen QC Ultra Earbuds—no extra case, no awkward accessories. Just drop the case onto any Qi-compatible charger (line up the back button with the center), and you’re good to go. It’s the kind of convenience that should’ve been there from the start, and now it is.
Battery life holds steady with up to six hours of playtime per charge, or four with Immersive Audio on. The case packs three full recharges, and if you’re in a rush, a 20-minute quick charge gives you two hours of listening (with Immersive Audio off).
And in a quiet nod to people who don’t want their music skipping every time they adjust an earbud or fix their hair, Bose now lets you disable the capacitive touch controls entirely through the app. It’s one of those options that won’t get headlines, but for real-world use? It’s a win.
App Control, Bluetooth 5.3, and Codec Support: Familiar Foundations with a Few Extras
The Bose Music app (iOS and Android) remains the control center for the 2nd Gen QC Ultra Earbuds. It handles everything from EQ tweaking and Custom Modes to managing Bluetooth connections and customizing shortcuts. Firmware updates roll out automatically through the app, so the earbuds stay current without any extra effort.
On the connectivity side, Bluetooth 5.3 is on board with multipoint support, letting you stay connected to two devices at once. Codec support covers the usual suspects—SBC and AAC for broad compatibility across iOS and Android—but aptX Adaptive is also in the mix. If you’re using a Snapdragon Sound-certified device, you get higher-quality audio and lower latency without touching a setting.
bose-qc-ultra-app-screenshots
Android users also get Google Fast Pair for quicker setup. It’s not a groundbreaking change, but for earbuds living in a world dominated by Apple’s H2 chip and Sony’s LDAC, the connectivity spec sheet here checks most of the right boxes.
Comparison
Bose Model QuietComfort Ultra Earbuds (2nd Gen) – (2025)QuietComfort Ultra Earbuds (2023)QuietComfort Earbuds II (2022)QuietComfort Earbuds (2024)
Price$299$299$279$179
Headphone FitIn EarIn EarIn EarIn Ear
MicrophonesBuilt-in MicrophoneBuilt-in MicrophoneBuilt-in MicrophoneBuilt-in Microphone
Noise CancellingYesYesYesYes
Noise Control TypeAdaptive Noise Cancelling with AIAdjustable Noise CancellingAdjustable Noise CancellingSwitchable Noise Cancelling (Quiet or Aware)
Water ResistanceIPX4IPX4IPX4IPX4
CaseChargingChargingChargingCharging
Dimensions/WeightBud Single: 0.49” W x 1.18” H x 0.98” D
(0.016 lbs)
Case: 2.35” W x 2.60” H x 1.06” D
(0.132 lbs)
Bud Single 1.23″ H x 0.79″ W x 0.96″ D (0.017 lb)
Case 2.61″ H x 2.34″ W x 1.05″ D (0.132 lb)
Bud Single 1.14″ H x 0.99″ W x 0.83″ D (0.024 lb)
Case 1.38″ H x 2.76″ W x 1.9″ D (0.104 lb)
Product MaterialNot ProvidedPlastic (PC-ABS), Silicone, MetalPlastic (PC-ABS), Plastic (PC-ABS), Silicone, Metal
Product Case MaterialNot providedPlastic (Hard)Plastic (Hard)Plastic (Hard)
RechargeableYesYesYesYes
Battery Life6 hours6 hours6 hours8.5 hours
Battery Charge Time2 hours2 hours1 hour1.5 hours
Charging Accessory includedYesYesYesYes
Charging Interface(s)USB-C Port and WirelessUSB-C PortUSB-C PortUSB-C Port
Wireless ConnectivityBluetooth A2DP, HFP, AVRCP, BLE
Spotify Tap
Google Fast Pair
Bose SimpleSync
A2DP Bluetooth Audio Streaming, HFP BluetoothA2DP Bluetooth Audio Streaming, HFP Bluetooth, AVRCP BluetoothA2DP Bluetooth Audio Streaming, HFP Bluetooth, AVRCP Bluetooth
Bluetooth Version5.35.35.35.3
Bose Immersive AudioYesYesNo No
ColorsBlack, White Smoke
Deep Plum (Limited Edition)
Black, WhiteBlack, Gray, SoapstoneBlack, White Smoke, or Chilled Lilac
Bose AppYesYesYesBose QCE App
What’s in the Box2 Bose 2nd Generation QuietComfort Ultra Earbuds
Charging Case
Fit kit (small, medium and large
ear tips and stability bands for
each earbud)
Safety sheet
2 Bose QuietComfort Ultra Earbuds
Charging Case
Bose Fit Kit:3 pairs of eartips (S, M, L) – 3 pairs of stability bands (1, 2, 3)
12” USB-C (A to C) cable
Safety sheet
2 Bose QuietComfort Earbuds
Charging case
USB-C cable (USB-A to USB-C, 12″)
Fit Kit (Small, Medium, and Large eartips & stability bands for each earbud)
Safety sheet
Charging case
Safety sheet
bose-qc-ultra-2nd-gen-tws-2
The Bottom Line
Bose isn’t just updating a flagship—they’re reinforcing their position as one of the few serious alternatives to Apple’s AirPods Pro in the premium ANC earbud space. The 2nd Gen QuietComfort Ultra Earbuds build on the 2023 model with meaningful improvements: smarter noise cancellation, cleaner voice pickup, and long-overdue wireless charging. None of these moves are revolutionary, but together, they show Bose is paying attention.
While they still trail Sony in codec support (LDAC is MIA) and don’t offer the ecosystem integration of Apple, Bose is targeting the middle ground—premium hardware with platform-agnostic convenience. And with updates not just for their own gear but for third-party models like the SkullCandy Method 360, it’s clear Bose is playing a longer, more adaptive game. Whether that’s enough to lure users from the Apple or Sony camps remains to be seen—but at the very least, this is a proper sequel.
bose-qc-ultra-2nd-gen-case-colors
Price & Availability:
The Bose 2nd Gen Quiet Comfort Ultra Earbuds will be available at Bose.com in Black, White Smoke, or limited-edition Deep Plum (available later in summer 2025) for $299
Bose QuietComfort Ultra Earbuds are available for $299 at Amazon.
Bose QuietComfort Ultra Earbuds II (LE version) are available for $249 at Amazon.
Bose QuietComfort Earbuds are available for $179.00 or less at Amazon.
V-MODA M10 and M100 Pro DJ Headphones
Not all headphones are designed for all listening needs. The V-MODA M-100 PRO and M-10 are affordable headphones that provide the quality and durability...
Bluesound POWERNODE 2025 Streaming Amplifier Lifestyle White Bluesound POWERNODE 2025 Streaming Amplifier Lifestyle White
Digital Music Systems
With upgraded DirectDigital amplification, Bluesound's new POWERNODE is a 2 or 3-channel streaming amplifier with support for a center channel speaker and even a...
Cambridge Audio Evo 150 SE Streaming Amplifier Cambridge Audio Evo 150 SE Streaming Amplifier
The Cambridge Audio Evo 150 SE ($3,299) refines a proven streaming amplifier with better sound and features, making it a top contender under $5,000.
Cambridge Audio Melomania A100 Wireless Earbuds White Lifestyle Cambridge Audio Melomania A100 Wireless Earbuds White Lifestyle
The Cambridge Audio Melomania A100 delivers hi-fi sound, advanced ANC, and top-tier codecs like LDAC for $149—challenging AirPods Pro 2 and SoundPEATS with premium...
OXS Storm A2 Gaming Headphones Lifestyle OXS Storm A2 Gaming Headphones Lifestyle
OXS Storm A2 delivers budget-friendly wireless gaming headphones with 7.1 virtual surround, hybrid active noise cancellation, ultra-low latency, and versatile cross-platform support.
STAX SR-007S Electrostatic Headphones STAX SR-007S Electrostatic Headphones
At $2,200, the STAX SR-007S isn’t for the budget-minded, but they provide celebrated Electrostatic Technology for those looking for the optimum headphone listening experience.
Father's Day Gift Guide 2024 Best Tech and HiFi Gifts
Upgrade Dad's digital lifestyle with gifts he'll enjoy all year and beyond this Father's Day. New Hi-Fi, Headphones, Home Theater and more!
Bose expands its portable speaker lineup with the new SoundLink Plus and 2nd Gen Micro—Bluetooth 5.4, better battery life, improved sound, and rugged designs...
Noble FoKus Amadeus true wireless earbuds deliver Bluetooth 5.4, LDAC, Audiodo Personal Sound, and 42-hour battery life—all wrapped in a bold, unique design under...
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
With enhanced adaptive noise cancellation and a new driver design, Technics latest True Wireless Earbuds will give Bose, Sony and Sennheiser a run for...
At $279 or $399, the Beyerdynamic AMIRON 300 wireless ANC earbuds and AVENTHO 300 wireless over-ear headphones with ANC and head tracking are available...
At $449, the Noble Audio FoKus Rex5 wireless noise cancelling earbuds drop xMEMS support in favor of a new hybrid 5-driver array.
