Center Speakers
Børresen Center3 Center Channel Debuts: Is This Finally the One You Can Almost Afford?
Børresen’s $7,000 Center3 brings flagship tech to home theater but is it the missing piece for X Series owners or still overkill?
Børresen Center3 Front Angle Lifestyle
Part of Audio Group Denmark, Børresen has built its reputation on cost-no-object loudspeakers like the M8 Gold Signature, a statement product priced north of $1 million per pair and designed to showcase just how far its ribbon driver and iron-free motor technologies can be pushed. If you’ve been following our recent coverage, you’ve also seen the broader ecosystem in motion, including new X Series loudspeakers and a six figure Aavik amplifier that makes it clear this is still very much a no-compromise, ultra high-end operation.
The new Børresen Center3 shifts that narrative slightly. It brings Børresen’s core design philosophy into a dedicated center channel format aimed at high performance home theater systems, but this time lands in a comparatively attainable four figure price range.
borresen-center3-woofer-corner
Børresen Center3
The Center3 marks Børresen’s first dedicated center channel speaker, designed to deliver voices with precision and stability while keeping dialogue clear and firmly anchored even in complex scenes. Because the center channel handles most of the spoken content in a system, its performance is critical not only for intelligibility but also for maintaining tonal consistency across the entire front soundstage.
The Center3 is the result of a collaboration between Michael Børresen and Flemming E. Rasmussen, blending engineering precision with a more restrained visual design while extending the Børresen experience into film and television.
Børresen Center3 Technology: Ribbon Tweeter and Carbon Fiber Drivers
DDC5 Neo Midwoofers: The Center3 features advanced 5 inch midwoofers built around a three layer composite diaphragm, with a Nomex honeycomb core sandwiched between carbon fiber skins. This structure delivers high stiffness while keeping moving mass exceptionally low. Graphene whiskers are also integrated into the cone, helping push resonances well beyond the driver’s operating range for cleaner, more controlled output.
borresen-center3-tweeter
RP-94 Ribbon Tweeter: Børresen equips the Center3 with the same ribbon planar tweeter used in its higher end loudspeakers. The RP-94 features an aluminum coated membrane that weighs just 0.01 grams, enabling extremely fast transient response and highly detailed high frequency reproduction. It operates across a wide range from 2.5 kHz to 50 kHz, ensuring clarity and extension well beyond the limits of human hearing.
Serial Crossover: To further refine performance, Børresen employs a serial crossover network rather than a traditional parallel design. This approach maintains phase locked current flow through the drivers within the crossover region, improving coherence and delivering a more unified, seamless acoustic presentation.
borresen-center3-interior
Advanced Cabinet Construction: The Center3’s enclosure is built from thick hardwood laminates with block milled internal bracing to increase structural stiffness and suppress unwanted resonances. Separate acoustic chambers allow each driver to operate with minimal interaction, preserving clarity and control.
borresen-center3-base
Mechanical Grounding: The Center3 incorporates a dedicated cradle system with Ansuz Darkz Feet. This provides mechanical stability and controlled vibration management while allowing precise angular alignment of the center loudspeaker.
Comparison
Børresen ModelCenter3X1X2X3X6
Product TypeCenter Channel SpeakerSoundmount Speaker Floorstanding Speaker Floorstanding SpeakerFloorstanding Speaker
Price$7,000 (ea)$5,500/pr$8,800/pr$11,000/pr$22,000/pr
Speaker Configuration2-Way, Bass Reflex2- way. Bass Reflex2.5 way. Bass Reflex2.5 way. Bass Reflex2.5 way. Bass Reflex
Tweeter 1 x Børresen RP94 Ribbon Planar Tweeter1 x Børresen RP89 Ribbon Planar Tweeter1 x Børresen RP89 Ribbon Planar Tweeter1 x rBørresen RP89 Ribbon Planar Tweeter1 x Børresen RP89 Ribbon Planar Tweeter
Midrange/Bass2 x Børresen DCC5 Neo driver1 x Børresen DCC5 driver1 x Børresen DCC5 driver1 x Børresen DCC5 driver2 x Børresen DCC5 driver
WoooferN/AN/A1 x Børresen DCC5 driver2 x Børresen DCC5 driver4  x Børresen DCC5 driver
Frequency Response45Hz – 50KHz50Hz – 50kHz40Hz – 50kHz35Hz – 50KHz30Hz – 50KHz
Sensitivity87 dB/1W86 dB /1W88 dB /1W88 dB /1W88 dB /1W
Impedance8 Ohm>6 Ohm>4 Ohm4 ohm>6 Ohm
Recommended Amplifier Power> 50 W50W50W50W>50W
Finish Black high gloss lacquerBlack or white piano lacquerBlack or white piano lacquerBlack or white piano lacquerBlack or white piano lacquer
Dimensions (HWD)229 x 599 x 400 mm
8.90 x 23.58 x 15.75 inches
42 x 20 x 39 cm
16.5 x 7.9 x 15.4 inches
110 x 30 x 55 cm
43.3 x 11.8 x 21.7 inches
129 x 34.5 x 60.7 cm
50.8 x 13.6 x 23.9 Inches
164.1 x 37.8 x 56 cm
64.6 x 14.8 x 22 Inches
Weight 18.75 kg
41.34 lbs
12.9 kg
28.4 lbs
36.4 kg
80.2 lbs
55 kg
121 lbs
79 kg
174 lbs
borresen-center3-speaker-rear
The Bottom Line
Børresen may be known for building some of the most expensive loudspeakers on the planet, but the brand has been making a deliberate move toward more accessible territory with its X Series, priced from $5,000 to $20,000 per pair. The Center3, at $7,000 each, fits squarely within that range and extends the lineup into home theater for the first time.
While not officially labeled as such, some dealers have already referred to it as the “X Center,” and that tracks. The Center3 shares much of the engineering DNA and visual identity of the X Series, with a few trickle-down elements from Børresen’s more ambitious designs. It’s clearly intended to anchor a matching front stage, not act as a one-off upgrade.
At $7,000 for a 23 inch wide center channel, this is still a serious investment, but it’s not out of line with other high end options from brands like Wilson Audio. In that context, the Center3 is less about sticker shock and more about system matching and performance expectations.
The Center3 is unique because it brings Børresen’s core technologies including its ribbon tweeter, iron free driver philosophy, and serial crossover design into a dedicated center channel for the first time, finally giving existing owners a proper home theater solution. This is not a casual upgrade. It’s for listeners already invested in the Børresen ecosystem or those building a no compromise front stage who care about tonal consistency and dialogue precision as much as musicality. If you are not running matching speakers, it is likely overkill. If you are, it is the missing piece.
borresen-center3-speaker-angle
Price & Availability
The Børresen Center3 is available from Authorized Dealers for $7,000 (€6,000). Prices may vary by market.
For reference, here is info and prices for the Børresen X-Series Speakers
For more information: audiogroupdenmark.com
Sonus faber IsoAcoustics GAIA Titan Neo Loudspeakers Isolation Feet
A/V Furniture & Accessories
IsoAcoustics GAIA-TITAN Neo series of speaker isolation feet are designed for extra large speakers weighing 320 to 620 lbs each.
2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black 2026 Pro-Ject Audio Debut Carbon The Original Turntable Satin Black
Pro-Ject revives the Debut Carbon for $649 with a carbon tonearm and Ortofon-made cartridge. Is it worth saving $50 over the EVO 2?
2026 Acoustic Energy 500 Series Loudspeakers 2026 Acoustic Energy 500 Series Loudspeakers
Acoustic Energy redesigns its 500 Series with Corinium drivers, new cabinets, and four models starting at £650. Is the upgrade worth it?
2026 Schiit Magni 6 Headphone Amplifier 2026 Schiit Magni 6 Headphone Amplifier
Splurge Audio Video Hi-Fi Tech Gifts 2026
Aavik U-301 Unity Amplifier combines streaming, DAC, preamp and 300-watts per channel in a $17,000 all-in-one component.
Triangle Solstice replaces Esprit with new horn tweeters, French made drivers, revised cabinets, and stereo to home cinema options.
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Are Aavik’s R-x88 Series the ultimate phono stages for MC and DS Audio optical cartridge users, or just Danish analog excess?
Daily Deals
Focal Omada bookshelf, floorstanding, and center speakers are on sale through June 21, 2026. Save up to 35% while supplies last.
Center Speakers
Wharfedale Heritage Centre Channel finally delivers a matching center speaker for Linton, Super Denton, and Heritage Series home theater systems.
