Car Speakers
BMW 6 Series Bang & Olufsen High-End Surround Sound System
BMW announced it will offer an optional high-end surround sound system designed by Bang & Olufsen for its new BMW 6 Series Convertible (as well as the previously announced BMW 6 Series Coupe).
With 12 active loudspeakers driven by 1,000 watts of power, the Bang & Olufsen high-end Surround Sound system for the BMW 6 Series Convertible has all the power it needs to deliver rich, convincing sound. Each of the five tweeters is paired with a mid-range loudspeaker to deliver a homogeneous loudspeaker set-up, while the two potent subwoofers located under the front seats are directly mounted to the body of the car. This BMW-patented design eliminates vibrations from the subwoofers to produce an even cleaner sound performance.
BMW 6 Series Bang & Olufsen Surround Sound System - Dash
The patented Bang & Olufsen Acoustic Lens Technology also plays its part, distributing sound horizontally with 180 degrees of dispersion to give the best possible acoustic experience from anywhere in front of the speaker. On closer inspection, the acoustic lens cover reveals an additional mid-range loudspeaker that delivers perfectly balanced sound throughout the cabin.
Under the skin, the all new system also incorporates Dynamic Sound Optimization, which uses sound data gathered from a microphone mounted in the cabin to constantly adjust the sound according to conditions outside the car, such as rain and changing road surfaces.
For the BMW 6 Series Convertible, an additional sensor automatically instructs the Digital Signal Processor (DSP) of the sound system to adapt the sound performance to suit the altered ambient cabin conditions, whenever the soft top is raised or lowered.
BMW 6 Series Bang & Olufsen Surround Sound System - Door
In addition, two distinct sound modes integrated into the all new system create two quite different sound experiences. Studio Mode produces a wonderfully vibrant sound stage that reproduces sound as the artist intended, while the new Expanded Mode widens the sound stage to give passengers the impression that they are in a much larger space.
High-end design
The new design of the new Bang & Olufsen high-end Surround Sound system for the BMW 6 Series Convertible is more than a match for the great sound. With a clean, yet distinctive style that is perfectly integrated into the BMW interior design approach, the new system has a range of impressive design features that discerning consumers have come to expect, as well as some that are unique to this model, such as the Floating Frame solid aluminum grills. Special mountings separate grill from frame, giving the illusion that the grill is floating in mid-air. This space between the grill and frame also houses small LEDs that cast light subtly into the cabin when the system is activated.
The combination of light and sound is most impressively demonstrated when the system is activated. A loudspeaker cover in the center of the dashboard silently lifts to reveal the large acoustic lens while the embedded LED lights simultaneously turn on — a process we call Light Orchestration.
BMW 6 Series Bang & Olufsen Surround Sound System - Rear
Also unique to the new system is the 'Perl Glanz' (Pearl Gloss) color and large-diameter, machine-drilled holes that appear in perfect alignment from any angle. As well as maximizing airflow through the grills, the large holes and overall grill appearance perfectly match the edgy, clean interior lines of the BMW 6 Series. For an added touch of refinement, the Bang & Olufsen name has been laser engraved onto the surface of the majority of the grills.
A framework for the future
The Bang & Olufsen high-end Surround Sound system for the BMW 6 Series Convertible is a perfect match of clean, high-end design and impeccable levels of quality. It balances the integration of proven technology and innovation to deliver a system that meets the exacting standards of a car as prestigious as the BMW 6 Series Convertible.
Availability
The Bang & Olufsen high-end Surround Sound system is available as an upgrade option in both the BMW 6 Series Coupe and BMW 6 Series Convertible. The BMW 6 Series Coupe will first arrive in October 2011 in BMW showrooms across the country, followed by a late fall arrival for the BMW 6 Series Convertible with the B&O high-end Surround Sound system option.
Related
Bang & Olufsen BeoSound DBS for Aston Martin
Bang & Olufsen Sound System in Aston Martin DBS Volante
Bang & Olufsen BeoSound Rapide for Aston Martin
More: B&O news and reviews
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Beoplay H95 are the best Bang & Olufsen wireless headphones ever built which include advanced noise cancellation and 38 hours of battery life.
Digital Music Systems
Bang & Olufsen partners with TIDAL to ensure the highest quality music playback and simplify usability within one app.
Impress Mom this year with the latest top-rated tech gifts this Mother's Day that are guaranteed to be useful all year long.
CD Players
Bang & Olufsen's coolest CD player of the 90s returns as a limited edition Beosystem for a cool $55,000.
