BLU VIVO 8L Selfie Centric Smartphone for $150
Blu VIVO 8L Smartphone
Unlocked budget smartphone shoppers have a new option from BLU Products to consider. The BLU VIVO 8L is designed for selfie aficionados thanks to its 20-megapixel front camera with flash. Other features include a 5.3-inch HD (1280 x 720) 277ppi display with curved Corning Gorilla Glass, Fingerprint Sensor, and a 13-megapixel rear camera. The $150 Android phone won’t win a spec war, but could be acceptable for everyday use.
Oddly, Blu has chosen a confusing naming convention. The VIVO 8L is smaller in size and less powerful than Blu’s flagship 2017 model VIVO 8 (without the L) that costs $100 more.
The BLU VIVO 8L is powered by the 64-bit MediaTek 6753 chipset that offers 1.3GHz Octa-core processor paired with 3GB of RAM to be able to run multiple apps simultaneously, quickly browse the web, or enjoy smooth rendering of graphics. 32GB of built in internal memory for all your storage needs. Add on another 64GB with the external MicroSD slot for maximum capacity.
The BLU VIVO 8L’s 20-megapixel Super Selfie camera offers F/2.0 aperture and 1/2.8 inch sensor with 5P lens which provides more clarity for selfies. The 4-cell technology used allows 4 times the amount of incoming light to take the best pictures in low-light conditions. The rear 13-megapixel camera comes with a Sony IMX258 sensor, F/2.0 aperture, 1/3 inch sensor with 5P lens, real-time HDR, and Phase Detection Autofocus (PDAF) with Laser Focus for twice the focus rate and accuracy.
Specifications:
  • Network: (GSM/GPRS/EDGE) 850/900/1800/1900 MHz, (4G HSPA+ 42Mbps) 850/900/1700/1900/2100MHz, (4G LTE Cat 4 Up to 150Mbps) FDD 1/2/3/4/7/12/17/28
  • Display: Curved 5.3-inch HD (1280×720), 277 ppi, Corning Gorilla Glass 3
  • Processor: MediaTek MT6753, 1.3GHz Octa-core Cortex-A53 with Mali-T720 graphics GPU
  • OS: Android 7.0 Nougat
  • Camera:
    • Rear – 13.0 megapixel with 5P Lens, Laser Focus, Phase Detection Autofocus, LED Flash, (1.12mm pixel size, 1/3 inch sensor, 2.0mm aperture) HD 1080p@30fps video recording
    • Front – 20.0 megapixel, Wide Angle, LED Flash, (1.0mm pixel size, 1/2.8 inch sensor, 2.0mm aperture) HD 1080p@30fps video recording
  • Connectivity: Wi-Fi a/b/g/n, GPS, Bluetooth v4.1, Hotspot, NextRadio, Micro-USB
  • Security: Encrypted Fingerprint Scanner
  • Memory: 3GB RAM and 32GB Internal Memory, MicroSD expandable up to 64GB
  • Dimensions: 150.5 x 74.4 x 8.0 mm I 161g
  • Battery: Non-Removable Li-Polymer 4,000 mAh
  • Available Colors: Midnight Black
https://www.youtube.com/watch?v=9Ifc_-qxStI
Price and Availability
BLU VIVO 8L is now available for $149.99 at Amazon.com.
Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
