Monitors
Blaupunkts Largest Overhead Monitor Packs High Resolution 15.4-inch LCD Display in a Remarkably Low-Profile Chassis
IVMR-1542 features WXGA widescreen resolution, single-cable installation, and highest video performance available with chassis depth of just 2-3/8 inches
Blaupunkt has introduced the IVMR-1542, a 15.4-inch WXGA resolution in-car video monitor that features an incredibly low profile chassis depth of just 2-3/8 inch (5.97 cm). The monitor’s TFT active matrix display boasts a video resolution of 1280 x 800 in a 16×9 aspect ratio, a built-in wide angle (+/- 45 degrees) IR transmitter for wireless headphones, and a powerful suite of integration and control options that will appeal to installers and consumers alike. The IVMR-1542 has been selected as one of three Blaupunkt products to receive an Innovations 2005 Design and Engineering Showcase award at the 2005 Consumer Electronics Show.
The IVMR-1542 monitor delivers unparalleled integration capabilities, whether combined with other Blaupunkt multimedia system components, or equipment from other manufacturers. All input and output connections are incorporated in a single 13-pin DIN cable to simplify installation. When used in conjunction with Blaupunkt Generation 2 video signal controllers, this cable handles power, audio and video input, source selection, volume control, menu, and IR remote control signal exchange for complete system function. A “breakout cable” is also included, which provides conventional RCA and stranded wire connections for integration with conventional equipment from other manufacturers.
The IVMR-1542 also features IR pass-through capability, which relays IR signals received by the faceplate sensor to an IR output line. This allows the monitor to function as a remote sensor for devices equipped with a 3.5mm IR input, such as a Blaupunkt DVD-ME R, ME2, or ME3 DVD player in the trunk or under the seats.
Like all monitors in the Blaupunkt video line, the IVMR-1542 uses a superior quality TFT active matrix LCD display that is guaranteed for 15,000 hours of use. The monitor provides a wide viewable angle of 120 degrees horizontal and 105 degrees vertical.
The Blaupunkt IVMR-1542 includes a full-featured handheld remote control, and will be available in February at a suggested retail price of $1099.95.
Blaupunkt, the mobile electronics division of The Robert Bosch Corporation, designs and manufactures high quality and high performance car audio, video and navigation products for sale worldwide. For Blaupunkt dealer locations and product information, call 1(800)
950-BLAU [2528] or visit the company’s web site at < www.blaupunktusa.com>.
In North America, the Bosch Group manufactures and markets automotive original equipment and aftermarket products, industrial automation and mobile products, power tools and accessories, security technology, packaging equipment and household appliances. Bosch employs more than 23,300 associates in more than 80 facilities throughout North America and reported sales of $6.6 billion in 2003. For more information, visit www.boschusa.com.
For high resolution image files, please visit http://www.gspr.com/blau/ivmr_1542.html
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
