BlackBerry Torch 9850 / 9860 Smartphones
RIM announced the BlackBerry Torch 9850 / 9860 smartphones, its first first full-touch models. The new smartphones will be powered by the new BlackBerry 7 operating system, that RIM claims browses the web 40% faster than its previous generation phones. The 9850 / 9860 smartphones feature a new 3.7-inch capacitive touchscreen display, the largest ever on a BlackBerry smartphone, and trackpad for easy navigation.
The 9850 model is the CDMA model and will be carried by Sprint, while the 9860 is the GSM/HSPA model likely be offered from T-Mobile or AT&T. Otherwise the features and specs are just about indentical, except the the 9850 achieves a slightly longer batter life.
Key Specifications
  • 3.7-inch touch display
  • 1.2GHz processor
  • BlackBerry 7 OS
  • 5-megapixel camera, flash, HD video recording
  • 4GB onboard memory, expandable up to 36GB via microSD
  • Autonomous and simultaneous GPS enabled with preloaded BlackBerry Maps application
  • 802.11 b/g/n enabled
  • World phone capable
  • Size: 120mm x 62mm x 11.5mm
Price and Availability
To be announced at a later date.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
