BlackBerry PRIV Android Smartphone with Slide-out Keyboard
Blackberry PRIV
For those who want a physical keyboard to go with their Android phone, BlackBerry announced PRIV — their first smartphone powered by Google’s Android operating system (Android 5.1.1 Lollipop) that claims to be more secure. The BlackBerry PRIV features an elegant, slim design with both a slide-out physical keyboard and touchscreen keyboard, 5.4-inch dual-curved Corning Gorilla Glass 4 screen and powerful 18-megapixel Schneider-Kreuznach certified camera.
The BlackBerry PRIV comes with 32GB storage along with micro SD slot that supports up to 2TB (card sold separately). The 3410 mAh battery claims to provide up to 22.5 hours of uninterrupted power. Meanwhile, its exclusive new DTEK warning system app can easily monitor the security level of your phone and know what apps’ access your microphone, location, camera and other personal information.
https://www.youtube.com/watch?v=-evl_MntjFg
Price and Availability
The BlackBerry PRIV will be available November 6, 2015 at AT&T for $699 or via monthly installments starting at about $25/month.
BlackBerry PRIV
TECHNICAL SPECIFICATIONS
  • Baseline Software Support: Android 5.1.1 Lollipop
  • Size (LxWxD): 147 (184 opened) x 77.2 x 9.4mm
  • Weight (w/battery): 192g
  • Model Number: STV100-1
Processor:
  • Qualcomm 8992 with 64 bit Dual-core 1.8 GHz Cortex-A57 and Quad-core 1.44 GHz CortexA53 (Snapdragon 808 Hexa-Core, 64 bit)
  • Adreno 418, 600MHz GPU
Memory:
  • 3GB Low Power RAM
  • 32GB Flash
  • Hot-swappable MicroSD slot (up to 2TB)
priv-sides
Expandable Memory:
  • MicroSD slot located on top of device, accessible via pin-eject tray
Display:
  • Curved 5.43”
  • 2560 x 1440 resolution
  • 540 DPI
  • WQHD Plastic AMOLED
  • High Brightness Mode for Outdoor Readability
  • 24-bit color depth
  • 16:9 aspect ratio
  • Corning Gorilla Glass 4
Rear Facing Camera:
  • 18MP Auto-Focus
  • Optical Image Stabilization (OIS)
  • Phase Detect Auto Focus (PDAF), Fast focus lock
  • HDR
  • 6-element f2.2 lens
  • Back Side Illumination (BSI2) Stacked Sensor
  • Dual Colour, Dual 2 mm2 LED Flash – Enhanced photo color balance
  • 4k Video Recording: 30 fps, 1080p HD video recording at 60 fps, 6DOF video stabilization combined with OIS for incredibly
  • smooth video
  • 4x digital zoom
  • Continuous & touch to focus, face detection, image stabilization
  • Panorama, Burst, Live Filters
  • Multi-Frame Low Light Enhancement
Front Facing Camera:
  • 2MP Fixed-Focus, f2.8
  • Large 1.75um pixel size
  • Image & video stabilization
  • 720p HD video recording
  • 2x digital zoom
  • Wide Selfie Mode (also known as Selfie Panorama)
Dedicated Keys: Volume Up/Down, Mute, Lock(Power On/Off)
Notification: Tone, vibrate, on-screen or LED indicator; notification options are user configurable
Touch Capabilities:
  • 10-point multi-touch
  • Supports Passive Stylus
  • Glove Mode
  • Capacitive Touch Keyboard: Allows navigation gestures, fine cursor control, swipe to select word predictions, swipe back
  • for word deletion
Navigation: Capacitive Touch, capacitive 4-row keyboard (slider)
User Interface: Gesture control plus touch sensitive physical keyboard with gesture support
Keyboard:
  • Physical Sliding Keyboard, with support for:
    • Contextual auto-correction
    • Contextual next word prediction
    • Personalized learning engine
    • Keyboard Security: Password protection, Screen lock, and Sleep mode
Voice Input/output:
  • Integrated speaker and 3 microphones
  • BlackBerry Natural Sound enabled: Receiver cavity microphone monitors what the user hears and adjusts in real time for best performance. The system monitors speaker motion in real time to ensure maximum loudness without distortion
  • Virtual Back Volume Speaker – high surface area material in the speaker cavity provides higher loudness in a more compact space
  • Hands-free headset capable
  • Bluetooth headset capable
  • Integrated Hands-Free Speakerphone
Headset : 3.5 mm stereo
Ports and Connectivity:
  • USB 2.0 Connector with SlimPort enabled
  • USB 2.0 fully supported with standard microUSB 2.0 cable (included in box)
  • Cabled-Video Out, 4k @30 fps, supported with standard SlimPort adaptor (not included in box). SlimPort adaptor cables exist to support the following video protocols: HDMI, VGA, DisplayPort 1.1, DisplayPort 1.2, DVI
  • • NFC
Power Adapter
  • +5V DC / 1.3A AC power adapter, OMTP Compliant
  • QC2.0 Enabled – Compatible with QC2 Chargers
  • Dual mode Wireless Charging capable for Powermat (PMA) and Qi
Battery:
  • 3410 (typ) 3360 (min) mAh 4.4V 680 Wh/L integrated non-removable battery
  • Fast charge enabled
Battery Life:
  • Mixed Usage: Up to 22.5 hours
Network
  • FD-LTE 1, 2, 3, 4, 5, 7, 12, 17, 20, 29,30
  • HSPA+ 1, 2, 4, 5/6, 8
  • Quad band GSM/GPRS/EDGE
Wi-Fi:
  • 802.11 b/g/n for 2.4GHz
  • 802.11 a/n for 5GHz
  • 802.11 ac for 5GHz
  • 4G Mobile Hotspot
  • Wi-Fi Direct 2×2 MIMO
Bluetooth Support: Bluetooth 4.1 Low Energy (LE)
GPS
  • Assisted, Autonomous and Simultaneous GPS
  • Pre-loaded Google Maps
  • E911 supported
Advanced Sensors : Accelerometer, Magnetometer, Gyroscope, Time of Flight (ToF) Proximity, Ambient Light, Altimeter, Activity Monitor
SIM Interface
  • Nano SIM card (4FF)
  • Supports 1.8V and 3.0V cards
Recommended Temperature Parameters
  • Handheld – Operating: 0 to 35°C / 32 to 95°F
  • Handheld – Storage: -20 to 35°C / -4 to 95°F
  • Travel charger – Operating: 0 to 35°C / 32 to 95°F
  • Accessibility: HAC Rating: M3 T4
BlackBerry PRIV Front Closed
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Roundups
The Priv will likely be BlackBerry's last smartphone. It is a tweaked, suped-up Android phone that just happens to have the BlackBerry name, which...
