Loudspeakers
BG Radia IC-201 In-Ceiling LCR Speaker
BG Radia launched a new LCR loudspeaker designed for high performance in-ceiling applications. The IC-201 ($1,000 each) provides an ideal solution for creating true soundstage imaging where the only practical mounting option is in the ceiling. Using the company's proprietary planar ribbon technology, the IC-201 is manufactured in the USA at BG's Carson City, Nevada headquarters and is backed by a limited lifetime warranty.
Measuring a compact 13 1/8″ x 11 5/8″ and weighing only 8 lbs, the IC-201 is a two-way architectural design using quality steel and aluminum construction. Mounting is made easy in any standard depth wall or ceiling using BG's optional back box. The IC-201 comes standard in black or white and can be painted to match any decor.
The driver complement of the IC-201 combines four Kevlar woofers with Neodymium magnets with a single Neo3 planar ribbon tweeter utilizing a 45° down angle. Even in an in-ceiling installation, the company's new LCR produces true soundstage imaging with detailed, lifelike sound. Consistent with BG's legendary planar ribbon designs, the IC-201 maintains the same tonal quality and spectral balance as its other Radia models.
BG Radia IC-201 In-Ceiling LCR Speaker with grill
“The goal of any high performance sound system is to deliver a clear and detailed soundstage that appears to emanate from the front of the room. However sometimes the front or side walls are not available for in-wall speakers with the ceiling left as the only real custom option. Our solution is the IC-201; an in-ceiling LCR that delivers the accurate detailed sound audiophiles have come to expect from BG and with true soundstage imaging.”
— Mark Fielder, President of BG Radia
Key Features of BG Radia IC-201
  • Proprietary BG Planar Ribbon technology for lifelike sound
  • 45° down-firing angle for realistic soundstage imaging
  • Spectral balance perfectly matches other BG Radia models
  • Fits standard-depth walls or ceilings. Optional back boxes available
  • Quality steel and aluminum construction for rugged reliability.
  • Bezels and grilles can be custom painted to match any decor
  • Made in USA, limited lifetime warranty
Price and Availability
The IC-201 will be shipping in October 2010 for $1,000 each.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
