Headphones
beyerdynamic Tesla T1 Headphones
High-end headphone generates significantly more sound pressure through redeveloped high-performance motors
beyerdynamic Tesla T1 Headphone Driver
beyerdynamic changes the game in high-end headphone design and performance. As stated by Alan Feckanin, Business Unit Manager for Consumer Products: “The T1 is a very special headphone with its engineering qualities, audio reproduction and price to performance unlike any other high-end headphone. Design, comfort and audio presentation are unparalleled.”
First of its kind
After years of research, engineers at beyerdynamic have managed to develop a revolutionary sound converter, a milestone in headphone design. The new T1 headphone is the first model to break through the one-tesla barrier of magnetic induction. (The unit for measuring magnetic flux density is named the tesla, in honor of one of the world’s greatest visionaries and inventors in the late 19th and early 20th centuries. When Nicola Tesla, a contemporary of Eugen Beyer, died in New York in 1943 at the age of eighty-six, he had filed well over 100 patents.) Measured in tesla (T), magnetic induction plays a central role in the development of headphones. It indicates the ability of a sound converter to transform an electrical audio signal into sound waves and thus convert electricity into sound. Featuring twice the sound pressure of standard headphones, a highly effective, innovative driver in the T1 makes it possible to produce high-performance headphones using minimal moving mass in a 600-ohm coil. This system generates currently unequalled impulse performance. The T1 is the first model in a new generation of headphones.
Today is the future
As the flagship of beyerdynamic’s Premium Line, each headphone is individually finished by hand in Heilbronn, Germany. The T1 positions itself as a top-of-the-line product and as the star of the beyerdynamic headphone range from both a technical and a visual perspective. Vivid materials and structures accentuate the high quality of the headphones while still remaining true to a familiar, understated style. T1 proves it is unsurpassed in its class as a result of its aluminium components, a specially woven wire mesh, a leather headband and high-tech acoustic materials. A translucent, non-woven, acoustic material allows a discreet insight into its revolutionary inner workings.
The T1 is the flagship model in the Premium Line 600-ohm impedance products from beyerdynamic. This new driver technology gives the T1 an enormous boost in efficiency. It provides the listener with almost double the volume as traditional headphones. The increased efficiency also leaves the T1 with greater power reserves for dynamic, undistorted sound and lossless conversion of electric signals into sound waves. The extremely lightweight 600-Ohm voice coil provides transparency and perfect impulse fidelity.
Technical highlights:
The new T1 is headphones can play almost twice as loud as standard headphones. They are also significantly more efficient. That allows the new high-end headphones to offer greater performance reserves for dynamic, undistorted sound, making no compromises as its converts the electric signal into acoustic vibrations.
It took an incredible effort by beyerdynamic’s engineers to achieve those objectives using the extra-light 600-Ohm coils that the company prefers for their lightness yet perfect sound fidelity. Traditional extra-filigree drives tend to suffer from low efficiency rates. That prevents them from achieving real loudness when faced with underpowered headphone outputs, especially the popular 32 Ohm headphones that have become common in this age of the MP3. Yet the engineers didn’t completely re-develop the driver just to increase its efficiency. They also achieved higher maximum volumes compared with previous 600 Ohm models — an impressive 7 decibels.
That master achievement comes thanks to a new magnet system. The neodymium magnet had previously been positioned in the centre of the coil, which severely limited its size due to the flat design of the earpieces. The developers have now repositioned the magnets into a ring around the coil, allowing for a more than doubling of the magnetic flux density to approx. 1.2 Tesla. Even crossing the magical threshold of one Tesla for a pair of headphones would have been an admirable feat.
At the same time, the new configuration of the magnet system enables a central ventilation hole through the pole cores to prevent sound-disrupting resonances and cancellations. The diaphragm has also been redeveloped. It consists of a two-ply compound foil. The material is light-weight yet capable of high interior absorption of break-up vibrations, making a significant contribution to the transparent, nuanced and distortion-free sound of the T1.
For improved front positioning of the imaginary sound stage, as well as to increase the outside-the-head localisation of the overall playback, beyerdynamic’s engineers curved the earpieces such that acoustic baffle follows the contour of the human ear cup. This better accommodates the wearer’s individual acoustic “fingerprint” than transducers that sit directly on the ear and point into the ear canal.
beyerdynamic Tesla T1 Headphone Plug
The high-quality, symmetrical 6-pole cable brings even more sound improvements. It possesses two parallel sets of identical twin wires, each separately insulated. That lowers the cable capacity even while providing greater immunity from interference fields and crosstalk. The result: more of the original signal can be transmitted to the headphones.
The casing is also designed to satisfy the highest expectations. The open earpieces, covered through an elegant metal grate, are shielded from disruptive sonic reflections and protected against moisture through Acoustexx, a high-end acoustic mesh. As with all premium products from beyerdynamic, the new T1 is produced by qualified craftsmen who even in this age of globalisation continue to work from their headquarters in Heilbronn. Attention is given to even the smallest details, such as the hand selection of transducer system pairs to ensure not just top production quality, but also audibly better balance for the left and right channels
Specifications
Transducer type Dynamic
Operating principle semi-oben
Connector Gold vaporized stereo jack plug 6.35 mm
Weight without cable 350 g
Frequency response 5 – 55,000 Hz
Nominal impedance acc. to IEC 60268-7 600-ohm
Nominal SPL acc. to IEC 60268-7 102 dB
Nominal THD acc. to IEC 60268-7 < 0.05%
Power handling capacity acc. to IEC 60268-7 300 mW
Sound coupling to the ear Circumaural
Average pressure on ear acc. to IEC 60268-7 2.8 N
Cable length 3 m / double-sided balanced cable (6-core)
beyerdynamic is a German manufacturer of high quality audio products for over 80 years. The Company specializes in headphones, headsets, microphones, conference systems and gaming products for the global audio market. The U.S headquarters is located in Farmingdale, NY and the main office is in Heilbronn Germany.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Beyerdynamic DT 990 PRO X adds detachable cable, 48-ohm impedance, STELLAR.45 drivers, and improved comfort—all for just $199.
Beyerdynamic returns to the DJ market with the DJ 300 PRO X and PRO X CLUB, offering modular 2-in-1 design, studio-grade sound, and durable...
We compare the sound quality, fit, voice calling and usability from 8 open-ear fit wireless earbuds priced from $70 to $299.
Definitely not inexpensive, but the Beyerdynamic XELENTO Remote and Wireless IEM models promise very high-end earphone performance.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Wireless neckband earbuds still exist. The Beyerdynamic Blue BYRD now feature ANC and support for aptX Adaptive and Qualcomm cVc making them ideal for...
