beyerdynamic T1 & T5 Tesla Hi-Fi Headphones (3rd gen, 2020)
Now in their 3rd generation, the T1 (open-back) and T5 (closed-back) high-end over-ear headphones offer audiophiles precise spatial sound in a high-quality design.
beyerdynamic-t1-t5-3rd-gen-headphones-2020
Closed or Open-Back
beyerdynamic today introduced third generation T1 (open-back) & T5 (closed-back) high-end Tesla headphones. Priced at $999 each, these two new over-ear headphones claim to offer audiophiles optimum sound neutrality through proprietary Tesla transducers with maximum efficiency.
Tesla transducers developed by beyerdynamic are individually measured and matched in pairs to guarantee maximum sound precision and natural reproduction. The special arrangement of the drivers also guarantees precise spatial perception so the music appears in front on center stage, just like at a concert.
beyerdynamic T1 (open-back) 3rd generation Headphones (2020)
The new third-generation open-back T1 headphones are said to deliver spatial sound that gets a gentle bass boost for a warmer sound experience. The closed-back T5 improves realism especially in the upper mid, making both voices and instruments more clearly and distinctly perceptible, like being at a live performance.
beyerdynamic T5 (closed-back) 3rd generation Headphones (2020)
Both headphones are powered by transducers based on beyerdynamic’s legendary Tesla technology. Developed and manufactured at the beyerdynamic headquarter in Heilbronn, the Tesla transducers deliver high sound reproduction even if the source is a less than perfect music player. Both models are Hi-Res Audio certified and guarantee a high-resolution sound playback. Every piece of music is reproduced with all its detail – no other headphones get that close to the original recording.
German Craftsmanship
With both headphones, sound technology meets high-end materials and design. The T1 and T5 both have yokes of anodized, brushed aluminum; their headbands are covered with Alcantara® which gives them a very special elegance.
The T1’s housing cover looks stunning with a precise and elegant perforated pattern that was machined in the lacquered stainless steel using a complex production process. The T5 is based on the design of its sister headphone. As a closed model, its housing cover is an elaborate structure with brushed and lacquered aluminum.
Both models have earpads that ensure that the sound is perfectly balanced and make them incredibly comfortable to wear. This is achieved thanks to a memory foam filling of their earpads, which adapt to the head’s shape through heat and pressure. Breathable soft velour covers for the T1’s earpads, making them fit snugly around the ears. The earpads of the T5 are made from synthetic leather, which helps to shield from external noises.
The T1 and T5 have textile-covered cables that are plugged in at both ends. The cover makes the cables more flexible and a pleasure to handle. Because they have removable cables, they can be easily replaced. The textile sheathing also protects the high-purity OCC7N copper conductors, which ensure the best possible signal transmission. Both headphones can be enjoyed at home with mobile devices due to their 32 Ohm impedance.
Features
Price & Availability
The beyerdynamic T1 open-back ($999 at Amazon) and T5 closed-back ($999 at Amazon) are available September 1, 2020.
T1 Specifications (open-back)
TransducerDynamic, Tesla
Operating principleOpen
Frequency response5 – 50,000 Hz
Nominal impedance32 ohms
Nominal SPL100 dB (1 mW)
Power handling capacity300 mW
Max. SPL124 dB (300 mW)
Sound coupling to the earOver-Ear
Weight (without cable)360 g
ConnectorGold-plated 3‑pole mini stereo jack 3.5 mm
& adapter 6.35 mm (1/4”)
Scope of delivery3.0 m detachable cable, double-sided, textile-braided, OCC 7N copper conductorsHardcase
Recommended retail price$999 (USD)
T5 Specification (closed-back)
Operating principleClosed
Scope of delivery1.4 m detachable cable, double-sided, textile-braided, OCC 7N copper conductorsHardcase
Recommended retail price$999.00 (USD)
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Over-Ear Headphones
For under $600, the DT 1770 Pro MKII closed-back studio headphones are a more refined and textured update of a classic studio can.
Over-Ear Headphones
Are the Beyerdynamic DT 1990 Pro MKII the Best Studio Headphones Below $1,000 for Only $599?
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
At $499, the beyerdynamic DT 70 series IEMs are specifically tuned for studio professionals, drummers, guitarists, or pianists.
At $279 or $399, the Beyerdynamic AMIRON 300 wireless ANC earbuds and AVENTHO 300 wireless over-ear headphones with ANC and head tracking are available...
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
New products from Apple, Beats, JBL, Sony and Hisense are sure to be atop everyone's wishlist this Holiday season. Order now to beat the...
