Beyerdynamic’s MMX 200 Wireless Gaming Headset is Itching For A Fight With the Audeze Maxwell
Beyerdynamic’s first wireless gaming headset debuts for $249, featuring up to 50 hours of battery life, meta voice microphone and replaceable parts.
Beyerdynamic MMX 200 Wireless Gaming Headphones in Black and Grey
And we’re perfectly fine with that. The gaming industry is significantly larger than our little slice of the pie and Sony’s recent acquisition of Audeze is all the proof you need that it has become one of the most logical gateway drugs for the next generation of audiophiles.
High-end headphones and gaming are a match made in heaven and if you think the bean counters at Sony authorized a multi-million dollar acquisition of one of the premier manufacturers of headphones in the world because some executives in Tokyo wanted access to unlimited pairs of LCD-5 headphones — you need to get out and visit your local GameStop or Best Buy to understand just how large of an opportunity this is for manufacturers like Beyerdynamic and Audeze.
The Audeze Maxwell are a fantastic option for those looking to combine gaming and music listening and it should not surprise anyone to learn that gaming headsets have become over 40% of Audeze’s business — which aside from the technology that it has engineered over the past decade, is what attracted Sony’s attention in the first place.
Audeze, however, is not alone in this market.
MMX 200 wireless
Beyerdynamic MMX 200 Wireless Gaming Headphones in Black with mic boom front view
Beyerdynamic MMX 200 wireless
Beyerdynamic is adding the MMX 200 wireless to its lineup of popular gaming headphones for $249. The debut wireless gaming headset draws on nearly 100 years of Beyerdynamic’s pro-audio experience with headphones and mics – used by some of the most revered professional gamers in history.
Beyerdynamic’s existing MMX lineup of wired gaming headsets provides gamers with studio-level sound for a competitive advantage. MMX 200 offers that same competitive advantage – now in a fully wireless package without compromise.
Wireless Performance
The MMX 200 wireless uses dynamic 40mm high-performance drivers that deliver powerful bass, clear mids, and detailed highs – perfect for recreating every in-game effect with vivid audio playback.
At its core, MMX 200 uses custom-built, sensitive drivers to increase impulse response and detail across the extended frequency range. An integrated digital signal processor (DSP) adds an additional layer of processing to the closed-back headphones, creating an even more powerful sound for the ultimate gaming experience.
Beyerdynamic MMX 200 Wireless Gaming Headset in Black Collage
A detachable boom mic with an integrated 9mm capsule is included and was designed with an electret condenser capsule to provide higher max sound pressure levels (SPL), wider response, and less noise – all while being more power efficient than other gaming mics.
World-class gamers have relied on classic beyerdynamic studio headphones for years, despite not being purpose-built for gaming,” said beyerdynamic’s CEO Andreas Rapp.
“With MMX 200, we’ve used all of our collective experience and expertise to create a dedicated wireless gaming headset that’s also the perfect companion for gamers while not gaming.”
Connectivity & Comfort
Like gamers, remote and virtual workers rely on constant connectivity to get the job done.
The versatile MMX 200 wireless includes the latest in audio codecs, Bluetooth 5.3, a low-latency wireless adapter, and a Hybrid Mode for simultaneous analog and Bluetooth connection.
Beyerdynamic MMX 200 Wireless Gaming Headphone controls labeled in Black
The high-quality materials and components, light but sturdy clamping force, and 28mm earpads with memory foam padding were designed specifically for the MMX 200 because typical users spend hours each day wearing them
And, a large capacity battery will keep gamers gaming for more than 35 hours, with real playtime for closer to 40-50 hours, including idle periods.
MMX 200 wireless can be charged while in use, so it’s always working when you are. The minimalist design and focus on quality audio and connectivity features give gamers and at-home workers exactly what they need to perform at their best – no distracting gimmicks or battery-draining RGB lights. Like the other MMX headphone models, each component – from earpads to mics, battery and cables – is specifically designed to last, and is easily replaceable when the time comes.
The wireless headphones come with several other dual-purpose features, perfect for both gaming and home-office use. With a single press of the volume wheel, MMX 200 wireless mutes its mic and indicates its status with an LED light on the boom arm. A longer push puts the headset into Augmented Mode (transparency mode), turning the closed-back headphones into an ambient noise-enabled headset, making it comparable to an open-back gaming headset. Pressing the multifunction button once will answer incoming calls while in Bluetooth mode or using the LLWA. Triple pressing the multifunction button switches from LLWA connection to Bluetooth, enabling connectivity with other devices.
Price & Availability
The all-new Beyerdynamic MMX 200 wireless gaming headset is available starting today in black or grey for $249 at Amazon
To learn more, visit north-america.beyerdynamic.com
1 Comment
1 Comment
  1. Leo
    October 7, 2023 at 12:48 am
    This is not Beyers first gaming headset, they had one with manual bass control ports.
    It’s not even a competition to Maxwells you get 2.4ghz connection for pc / Xbox /PS5 plus Bluetooth and analog.
    Audio passthrough so you can hear the outside world with them at full volume.
    Two different audio bridges one for team chat/music one for game sound/music with individual sound control for each which does not overlap ever.
    On top of massive planar magnetic drivers which produce audiophile sound and massive base.
    Oh and they also have a removable boom mic and built in mics so you can take BT calls while you are listening to music and don’t have your boom mic plugged in.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
Over-Ear Headphones
For under $600, the DT 1770 Pro MKII closed-back studio headphones are a more refined and textured update of a classic studio can.
Over-Ear Headphones
Are the Beyerdynamic DT 1990 Pro MKII the Best Studio Headphones Below $1,000 for Only $599?
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
At $499, the beyerdynamic DT 70 series IEMs are specifically tuned for studio professionals, drummers, guitarists, or pianists.
At $279 or $399, the Beyerdynamic AMIRON 300 wireless ANC earbuds and AVENTHO 300 wireless over-ear headphones with ANC and head tracking are available...
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
