Beoplay P2 Pocket Speaker Packs a Punch
Beoplay P2 Bluetooth Speaker in hand (sandstone color)
2017 New Product Release:
B&O PLAY just released their the smallest and most intelligent wireless Bluetooth speaker called the Beoplay P2. The $170 go-anywhere portable speaker claims to punch out rich, clear and crisp 360-degree audio for the same spacious sound in any direction. It was designed by Cecilie Manz and comes in premium materials such as pearl-blasted aluminium and real leather, with customizable and intuitive control features via Beoplay App. Beoplay P2 is rounded, smooth and fits perfectly in the palm of your hand. A basic geometrical shape with a defined rim separates the pearl-blasted anodized aluminium top from the soft and warm polymer that make up the underside. The curvature of Beoplay P2 has undergone endless fine tuning to give it a highly tactile and refined appearance.
Bang & Olufsen looked to the Beoplay A1 for the reproduction of bass out of such a small product. They elaborated on Beoplay A1’s mid-woofer and designed a new one for Beoplay P2 using an anodized aluminium cone structure. The tweeter in Beoplay P2 is the same 3/4″ fabric soft dome used in Beoplay A1 assuring excellent detail and smooth reproduction of the highest frequencies. The DSP is advanced, highly capable and enables use of high slope filters and advanced character control to facilitate the excellent personal sound amplification experience in Beoplay P2. Two 15W RMD Class D Amps are used with a peak power of more than 2 X 50-watts drive it all.
Beoplay P2 has a built-in microphone for taking calls out loud, and the rimmed design on the speaker’s bottom edge enables the microphone to provide uniform 360 speech sensitivity. This enables the person listening to recognize voices perfectly, no matter where people are speaking in proximity to the microphone.
“We decided to remove all switches and buttons for a beautiful exterior and a simple and magical user experience that can be customized in Beoplay App. With just a double tap or shake, you can play, pause and skip track, launch your favourite voice assistant, change sound profile in ToneTouch and you can set up Beoplay App to wake you up with the same music that concluded a beautiful evening – reliving your latest goosebump moment as you wake up and get ready to chase the next,” says Director of Concept and Design in B&O PLAY Matthias F. Ørum-Hansen.
As an extra accessory to protect Beoplay P2, you can purchase a black leather sleeve. The Beoplay P2 sleeve provides a layer of protection to keep your Beoplay P2 safe when you are on the go, while still maintaining the beautiful and authentic B&O PLAY design.
https://www.youtube.com/watch?v=5alIctpqNms
Some other things to know:
  • A full recharge takes 2 hours
  • 10 hours of playtime expected
  • USB Type-C cable required for charging
  • Bluetooth 4.2, ADK 4.0
  • 68 Hz – 21.000Hz Frequency Range
  • Tap and shake interactions which can be customized in Beoplay App
  • Press the B&O PLAY button on the bottom side to turn power on/off
  • Compatible with Beoplay App
Price and Availability
The Beoplay P2 comes in Black, Sand Stone and Royal Blue and is available for $169 (US) as of April 27, 2017. The Beoplay P2 Sleeve is $39.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
