BenQ W1500 Wireless DLP Projector
BenQ W1500 Wireless Projector
World’s First Wireless Full-HD 1080p 3D Projector With Built-in 5-GHz WHDI Technology
BenQ today announced the W1500 wireless full-HD (FHD) home entertainment 3D DLP projector supporting the Wireless Home Digital Interface (WHDI). Designed to provide complete source connectivity without the need for cabling, the W1500 enables simple installation, easy operation, 3D support, and full mobile device integration. The projector delivers an amazing one billion stunning colors with Colorific image quality for accurate, crisp, and long-lasting color, in addition to BenQ’s world-leading SmartEco lamp-saving technology to deliver a hassle-free home theater experience at a lower total cost of ownership (TCO).
The world’s first wireless projector with built-in 5-GHz WHDI technology, the W1500 projects uncompressed full-HD 1080p 2D or 3D content from sources such as Blu-ray and DVD players, set-top boxes, and gaming consoles without the need for HDMI cables (up to 65 feet away). The projector also supports wireless connectivity with any mobile device such as an iPad or Apple TV. The result is future-proofed setups and a simpler installation process by enabling complete freedom of projector placement.
For the total 3D experience, the projector supports HDMI, full 3D timing, NVDIA 3DTV Play, and 2D to 3D conversion. With the W1500, BenQ is introducing its newly redesigned 3D glasses, which are optional. To add convenience for portable applications, the W1500 features 2x 10-W speakers, audio inputs and outputs, as well as SRS Wow audio sound, vertical lens shifting, and 1.6x big zoom capabilities. For installations where space is at a premium, the projector’s short-throw ratio of 84 inches at 6 feet from the screen ensures maximum flexibility for any environment.
SmartEco technology automatically adjusts lamp power based on input content, providing optimal contrast and brightness output while saving energy. As a result, the W1500 increases lamp life up to 6,000 hours without any image-quality compromise. In “Eco Blank” mode, the projector blanks out the screen whenever projection isn’t needed, saving up to 70 percent of lamp power while a “No Source Detected” mode automatically lowers brightness to 30 percent when no display has been detected for more than three minutes. In “Standby” mode, the W1500 lowers power consumption to less than 0.5 W during periods of inactivity.
Price and Availability
The BenQ W1500 FHD wireless projector is available now $2,299.
Specifications
Projection System Single 0.65′ DC3 DLP DMD
Native Resolution 1080p (1920 x 1080)
Brightness* 2200 ANSI lumens
Contrast Ratio 10000:1
Display Color 1.07 Billion Colors
Lens F=2.45-3.07 , f=15.78-25.12mm
Aspect Ratio Native 16:9 (5 aspect ratio selectable)
Throw Ratio 1.07-1.71 (84″@2M)
Image Size (Diagonal) 40″-300″
Zoom Ratio 1.6:1
Lamp Type 240W
Lamp (Normal/Economic Mode)* 3500/5000/6000 hours
Keystone Adjustment 1D, Vertical ± 10 degrees
Projection Offset 110%~130%
Resolution Support up to WUXGA
Horizontal Frequency 15K-102KHz
Vertical Scan Rate 23-120Hz
Lens Shift Vertical 110%-130%±5%
Interface Computer in (D-sub 15pin) x 1
HDMI (v1.4a) x 2
Composite Video in (RCA) x 1
S-Video in (Mini DIN 4pin) x 1
Component Video in x 1
Audio in (Mini Jack) x 1
Audio L/R in (RCA) x 1
Audio out (Mini Jack) x 1
DC 12V Trigger (3.5mm Jack) x 1
Speaker 10W x 2
RS232 (DB-9pin) x 1
HDTV Compatibility 480i, 480p, 576i, 567p, 720p, 1080i, 1080p
Video Compatibility NTSC, PAL, SECAM, SDTV(480i/576i), EDTV (480p/576p, HDTV (720p, 1080i/p 60Hz)
Accessories (Standard) Remote Control w/ Battery (full type, RCV011)
Carry bag
Power Cord (by region)
User Manual CD (24L)
Quick Start Guide (28L)
Warranty Card (by region)
Lens cover
VGA (D-sub 15pin) Cable
WHDI Wireless Dongle Kit box
Accessories (Optional) 3D Glasses P/N: 5J.J7K25.011
Spare Lamp Kit P/N: 5J.J9E05.001
Ceiling Mounting Kit P/N: 5J.J4N10.001
3D Support and Compatibility Frame Sequential: Up to 480i
Frame Packing: Up to 24 Hz 1080p
Side by Side: Up to 60Hz 1080i
Top Bottom: Up to 24Hz 1080p
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
