Monitors
BenQ RL2450HT LED LCD Monitor
BenQ introduced the 24-inch RL2450HT LED LCD monitor designed for gamers by gamers. It is the only professional gaming monitor purpose-built around the StarCraft II engine.
The RL2450HT was engineered in conjunction with ZOWIE GEAR, a manufacturer of high-end professional gaming gear, as well as with input from the world-class StarCraft II professional gaming team, STARTALE, which is sponsored by BenQ. The resulting monitor provides unprecedented levels of command, control, accuracy, and enjoyment for top-level RTS gamers.
The BenQ RL2450HT was engineered exclusively for gaming with a 60Hz frame rate refresh rate for smooth movement, an LED light engine for great color and low power consumption, and a 2ms G2G response time with 12 million to 1 contrast ratio. Proprietary BenQ enhancements on the RL Series professional gaming monitors give gamers a competitive edge over players on other gaming monitors. The RL Series RTS Mode maximizes StarCraft II visibility and optimizes color, while its Black eQualizer enables total visibility by allowing gamers to adjust the screen brightness without over-exposing white levels, in turn revealing critical combat details with improved visibility in darkened areas. The RL Series Display Mode allows gamers to interchange between monitor screen sizes, while the Smart Scaling feature gives them the freedom to manually scale the screen to any custom size from 17 to 24 inches, depending on their preferences. In addition, the unit’s adjustable height stand allows for optimal screen positioning.
Features
  • Black eQualizer
  • Height Adjustment Stand
  • RTS Mode
  • Display Mode
  • Smart Scaling
  • 2ms GTG
  • HDMI
  • 12M:1 dynamic contrast ratio
Price and Availability
The BenQ RL2450HT is available now for $349.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
