BenQ HT6050 Home Theater Projector Announced
BenQ HT6050
BenQ today announced their new flagship, professional-grade home theater 1080p Full HD projector, the HT6050. This $3800 DLP cinema projector claims to deliver true digital cinema-grade image and color reproduction. It features Rec. 709 color to reproduce the color palette exactly as the movie studios intended, dynamic iris to produce phenomenal contrast levels, state-of-the-art TIR light engine for exceptional brightness uniformity, BenQ’s exclusive CinemaMaster suite of image enhancing features and a choice of 5 optional all-glass, precision-crafted lenses.
Rec. 709 is the international HDTV standard that guarantees the accurate reproduction of HD cinematic color as the director intended. With a 6X speed RGBRGB color wheel, the HT6050 is calibrated for cinematic quality to deliver refined colors that are the truest possible reproduction of the original video palette. Generating industry-leading levels of contrast ratio performance, the HT6050 produces deep, true blacks and its high native contrast clearly resolves subtle layers and fine details in dark scenes for a truly awe-inspiring visual experience.
Furthermore, BenQ has taken extreme measures to guard against stray light leakage from the light tunnel affecting contrast and obscuring fine details with a special black paint that seals the projector’s light engine to boost contrast and render all dark scene details superbly. Featuring class-leading high fill factor, the HT6050 shines more light into each pixel, improving definition for small text and fine details, while eliminating the “screen door effect” for stunning image realism.
Along with HD cinematic color quality, the HT6050 uses BenQ’s exclusive CinemaMaster advanced audio and video processing suite to enhance video content with smoother motion, more true-to-life color saturation, sharper pixel detail and improved flesh tones. It boasts stunning 1080p resolution with 2,000 ANSI lumens and a 5000:1 contrast ratio. It’s equipped with five optional big zoom lenses from 0.77:1 to 5:1 with -20~60% vertical and ± 5% horizontal lens-shifting. Along with its flexible placement design, integrators have more image-adjustment settings for faster setup.
Featuring a newly designed cooling system, the HT6050 delivers whisper-quiet operation without distracting fan noise interrupting the viewer’s movie-going experience. Its dual HDMI connectivity (HDMIx1, HDMI/MHLx1) means one cable can stream video and audio to the HT6050 without multiple wires cluttering the space. Customers also have even more content options. With a simple MHL cable or dongle, customers can directly stream full HD content from any MHL-enabled smartphone or tablet to the big screen. Its auto power on/off with HDMI-CEC option helps customers save power by allowing them to turn off a Blu-ray player through the HT6050 remote.
BenQ HT6050 back
The HT6050 is ISFccc-certified by the Imaging Science Foundation (ISF), enabling viewers to enjoy a professionally calibrated picture with two optimized modes — ISF Day and ISF Night. The projector also features BenQ’s renowned SmartEco energy-saving technology to automatically adjust lamp brightness based on content to project richer blacks and increase contrast for tiny text and subtle details. The HT6050’s full HD 1080p optical system uses only the highest-grade glass for superior light penetration and realistic image quality. Proprietary low-dispersion lens coatings minimize chromatic aberration, so viewers can enjoy their favorite HD content in brilliant clarity.
The HT6050 also offers an optional full HD wireless kit, which is a perfect add-on to stream uncompressed 1080p content, including 3D from a central location to the projector. Easy setup pairs with the projector automatically, while zero latency performance gives viewers smooth video and gaming with virtually no lag. Four powerful antennas provide up to 100 feet of wireless coverage and Dynamic Frequency Selection switches channels for smooth, sharp streaming, even through walls.
“The new HT6050 projector uses the latest DLP DarkChip3 technology and a unique color wheel design to deliver HD cinematic color right out of the box,” said J.Y. Hu, vice president at BenQ America Corp.
Price and Availability
The BenQ HT6050 home theater projector is now available via BenQ Integrators’ Choice distribution partners and retails for $3,799.
Specifications
  • Projection System: DLP
  • Native Resolution: 1080p (1920 x 1080)
  • Brightness: 2000 ANSI Lumens
  • Contrast Ratio: 50000:1
  • Display Color: 1.07 Billion Colors
  • Aspect Ratio: Native 16:9 (5 aspect ratio selectable)
  • Lamp Type: 280W
  • Lamp Mode: (Normal/Eco/SmartEco)* 2500/3500/6000 hours
  • Keystone Adjustment: Vertical ± 30 degrees
  • Resolution: Support VGA(640 x 480) to WUXGA_RB (1920 x 1200) *RB = Reduced Blanking
  • Horizontal Frequency: 15~102KHz
  • Vertical Scan Rate: 23~120Hz
  • Color Wheel Segment: 6-Segment (RGBRGB)
  • Color Wheel Speed: 6x (50Hz), 4x (60Hz)
  • Dimensions: (WxHxD) 16.9” x 6.5” x 12.6” / 431 mm x 167 mm x 321 mm
  • Weight: 19.4 lbs / 8.8 kg
  • Power Supply: AC100 to 240 V, 50 to 60 Hz
  • Power Consumption: Normal 370W, Eco 290W, Standby <0.5W
  • Audible Noise: 31/28 dBA (Normal/Economic mode)
  • Languages: English/ Spanish/ French (28 Languages)
  • UPC: / Part # 8400460-3374-3 / 9H.04J77.27A
  • Limited Warranty: 3-Year Parts/Labor; 1 Year or 2,000 hours of lamp life
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
