BenQ Releases the CinePrime Series W5800 4K UHD Laser Projector
At $5,999, the BenQ W5800 4K Laser DLP Projector uses proprietary HDR-PRO technology for enhanced details on screens up to 200-inches.
BenQ W5800 Projector Front
The affordable home theater projector category has been dominated by BenQ, Epson and Optoma, while Sony and JVC have been innovating in the high-end projector range beginning around $10K. However, as technology improves BenQ has become the top-selling consumer projector brand by maintaining a steady value proposition. With that in mind, BenQ has announced the launch of its newest 4K home theater projector, the W5800.
What is the BenQ W5800 and Who is it For?
The BenQ W5800 is a 4K Ultra HD Laser projector that is targeted to the dedicated home theater enthusiast for use in a dark room. The W5800 incorporates DLP technology with support from a Laser/Phosphor Light Engine to project images ranging from 60 to 200 inches in size.
Priced at $5,999, the W5800 is now BenQ’s most expensive home theater projector, and double the price of its predecessor, the HT5050 which was a lamp based projector. Is the W5800’s laser light engine and higher brightness worth the extra cost? Let’s dig into the details.
BenQ W5800 Features
4K UHD Resolution: The W5800 incorporates a .47-inch 1080p resolution DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments. The chip contains 2.1 million pixels (very tiny mirrors). However, to display 4K, 8.3 million pixels are required. As a result, the pixels on the 1080p chip are shifted both vertically and horizontally at 240Hz (240 times per second). This is so fast it is classified as a 4K image once displayed on the screen.
DLP 4K Pixel Shifting
Laser Light Source: To project the 4K UHD resolution images onto a screen (or a wall) the Benq W5800 incorporates a Laser/Phosphor Light Engine which delivers up to 2600 ANSI lumens of light output for bright large screens. With the ability to project images on up to a 200-inch screen, the  W5800  provides more than enough light for home theater viewing.
BenQ W5800 Light Engine
Screen Size: With a 1.6:1 zoom ratio users can view a 150-inch image with the projector placed 16.6 feet from the screen. If you want the maximum recommended screen size of 200 inches the minimum required projector-to-screen distance is 22 feet.
BenQ W5800 Projector Distances
Projector Position: The W5800 can be mounted on a table or shelf or on the ceiling at the front or rear of the screen (provided the screen is compatible with rear projection). To aid in projector setup, the W5800 has both vertical and horizontal keystone correction and 2D motorized lens shift. Lens shift allows users to move the projector’s lens physically without affecting image clarity and is preferred over the use of keystone correction. However, there may be setup situations that require the use of both options.
2D Lens Shift
Tech Note: The W5800 does not have Lens Memory that would allow it to automatically detect and adjust content aspect ratio while maintaining Constant Image Height. This means that the aspect ratio and image height must be changed manually.
CinematicColor: This feature offers color accuracy with enhanced visual details that allow the W5800 to achieve 100% DCI-P3. Color standard.
Factory Calibration: Calibrating a projector to get reference performance can be intimidating for those who don’t want to spend the extra money to get it done. With that in mind, BenQ provides calibration at the factory for each projector and provides buyers with a calibration report.  This supports users with 100% Rec. 709 Delta E<2, grayscale tracking Delta E<2, and an optimized DCI-P3 color table for more accurate color right out of the box.
Color Accuracy
HDR-Pro Technology: This feature provides enhanced dynamic contrast through a variety of technologies.
  • Blue Laser Dimming and Dynamic Black Technology increase contrast range in HDR mode, making light and dark scenes more dynamic and vivid.
  • Local Contrast Enhancer automatically adjusts the gamma for each independent scene, improving 4K HDR imagery.
  • HDR10+ technology adds dynamic metadata to HDR10 source files, which is used to optimize each frame of the HDR video.
Tip: Projection distance and placement can vary from screen to screen. To compensate for this the W5800 features a HDR brightness function that allows for customized brightness levels depending on the projection size.
High Dynamic Range and Wide Color Gamut
Filmmaker Mode:  This feature supports 24P playback that accepts high-definition sources at 24 fps without judder in HDR mode to preserve consistent image quality.
From Houston Wei, senior director of BenQ North America: “The W5800 captures the essence of display with our CinematicColor technology, guaranteeing that colors are accurately reproduced as presented,…BenQ is thrilled to deliver an unparalleled experience by creating an immersive and captivating experience for our users with a projector that achieves 100% coverage of DCI-P3 color gamut with CinematicColor and HDR-PRO technologies.
Audio Support
While a growing number of projectors incorporate a modest speaker system, the W5800 does not have this feature. As a home theater projector, it is expected that users would most likely have a soundbar or AV receiver/speaker setup.  To feed audio from the projector to an external audio system the W5800 incorporates HDMI-eARC and Digital Optical (S/PDIF) outputs.
BenQ W5800 vs HT5550
BenQ W5800 vs. BenQ HT5550 Projectors
According to BenQ the W5800 is the successor to the HT5550 which was originally released in 2019. After 5 years it was time for an update.
Some of the new features on the W5800 over the HT5550  include:
  • Laser/Phosphor light source instead of lamp light source
  • Filmmaker Mode to further optimize movie viewing
  • HDR10+ expands HDR capabilities
  • Horizontal Keystone provides an additional image setup adjustment
  • Factory Calibration provides desired mage performance out of the box.
  • HDMI-ARC/eARC makes connecting to an external soundbar or home theater audio system easier.
Comparison
CinePrime W5800CinePrime HT5550
Price$5,999$2,699
$1,999
Projection SystemDLP DLP
Light SourceLaser/Phosphor Lamp
Light Source Life Hours20,000 (normal)
25,000 (eco)
4000 hrs (normal)
10000 hrs (SmartEco)
15000 hrs (LampSave)
10000 hrs (ECO)
Resolution (Via Pixel Shift)4K UHD (3840×2160)4K UHD (3840×2160)
Light Output (ANSI lumens)26001800
Native Aspect Ratio16:916:9
Contrast Ratio (Full On/Full Off) 2,000,000:1
(with Light Source Dimming)
100,000:1
Color Display 1.07 Billion (30 bit)1.07 Billion (30 bit)
Throw Ratio1.52~2.451.36 ~ 2.18
Zoom Ratio1.6x1.6x
Lens SpecsF/# 2.1 ~ 3.0 , f 16.0 (Wide) ~25.7 (Tele) mmF/# = 1.81 – 2.1, f = 14.3 – 22.9 mm
Projection Offset (Full-Height)0%0%
Keystone CorrectionVertical ± 35 degrees; Horizontal ± 35 degreesVertical ± 40 degrees
Lens ShiftVertical ±50%Horizontal ±21%± 60%± 23%
DCI-P3 Coverage100%100%
Rec. 709 Coverage100%100%
Picture Modes3D, Bright, Bright Cinema, Cinema, HDR, HDR10, HDR10+, HLG, ISF Day, ISF Night, User3D, Bright, Cinema (Rec.709), D. Cinema, HDR, HLG, ISF Day, ISF Night, Silence, User, Vivid TV
Filmmaker ModeYes
HDMI Input 2  HDMI-1 (2.0b/HDCP2.2), HDMI-2 (2.0b/HDCP2.2)2 HDMI-1 (2.0a/HDCP2.2), HDMI-2 (2.0a/HDCP2.2)
LAN (RJ45)1 (10/100 Mbps)1 (10/100 Mbps)
3D Sync Out (VESA Standard)1
USB Type A23
USB Type B1 (for service only)1 (mini – service only)
RS232YesYes
Wired Remote InNo Yes (3.5mm Mini Jack)
DC 12V TriggerNoYes (3.5mm Mini Jack)
SpeakerNo
HDMI-ARC/eARCYes
Digital Optical (S/PDIF)YesYes
Operating Temperature0~40℃0~40℃
Power SupplyAC 100 to 240 V, 50/60 HzAC 100 to 240 V, 50/60 Hz
Typical Power Consumption (110V)Max 450W/ Normal 380W/ ECO 240W330W
Stand-by Power Consumption<0.5W<0.5W
Network Stand-by Power Consumption<2W<2W
Acoustic Noise (Typ./Eco.)(dB)30/27Typ./Eco.)(dB)32/26
Dimension (HWD – mm)525.2 x 145.7 x  392.2349 x 168 x 492
Dimension (HWD – inches)20.7 x 5.7 x 15.49213.74 x 6.61 x 19.37
Net Weight (kg)10.5 kg6.5 kg
Net Weight (lbs)23.1 lbs14 lbs 5oz
Included Accessories Remote Control (RCV024) w/ Battery:
Power Cord  1.8m (by region):
HDMI cable: 3.0m
Quick Start Guide:
Warranty Card (by region)
Lens cover
Remote Control (RCV016) w/ Battery
Power Cord 3.0m (by region)
User Manual CD
Installation Guide
Warranty Card
Lens cover
Universal Ceiling Mount (CM00G3)
BenQ W5800 Remote Control
Initial Impression
The BenQ W5800 is designed to appeal to home theater enthusiasts. Several significant image quality features are designed to enhance the movie viewing experience, such as a bright Laser/Phosphor light engine, ISFccc certification, factory pre-calibration, HDR10+, and Filmmaker mode. The W5800 even includes 3D display capability (3D sync receiver and glasses are optional).
However, it is interesting that the W5800 does not include Lens Memory, which would be of benefit making automatic aspect-ratio adjustments. BenQ doesn’t seem to be pushing the W5800 as a gaming projector as they have not included gaming information (such as response time) in their promotional material.
Pricing & Availability
The BenQ W5800 is available for $5,999 at BenQ, and we expect more retailers to start carrying it soon.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
