Belkins New PureAV Hybrid AVU1500 UPS with PureFilter Technology Provides Safe, Clean Backup Power to Your Home Entertainment System
Contact:
Melody Chalaban
Public Relations Manager
(310) 604-2347
(310) 864-2425 mobile
melodych@belkin.com
FOR IMMEDIATE RELEASE
The AVU1500 is both a full-featured power conditioner and a highly advanced UPS that compensates for a temporary or total loss of power
(Indianapolis, IN and Compton, CA) – September 8, 2005 – Belkin Corporation announces its new PureAV Hybrid AVU1500 UPS with PureFilter Technology that safeguards the recordings and settings on your personal video recorder, satellite receiver, or any other home theater component that may need backup power. Combining PureAV’s unique PureFilter Technology with the power of a 1500VA, 1000-watt, battery-backup unit, the AVU1500 cleans, protects, distributes, and provides backup power to your entire system. The AVU1500 will be shipping in North America in November 2005. It will also be on display at the CEDIA 2005 Show in Indianapolis, IN, September 9–11, at 1347 RCA Dome.
PureAV Hybrid AVU1500 UPS with PureFilter Technology (AP51300-10) — ESP $1199.99
Many types of power disturbances can affect your home theater experience. Power surges and AC power-line “noise” are common household occurrences that can damage your expensive audio video equipment and reduce the quality of your sound and picture. Also, as the population grows and the demand for power increases, power brownouts and blackouts are becoming more common. These sudden power losses can cause the loss of system settings and digital recordings. More importantly, sudden power loss leads to improper equipment shutdown, which ultimately results in damage to your valuable equipment.
Features
• Phase 4 PureFilter Technology isolates and eliminates AC line “noise”
• Uninterruptible Power Supply provides backup power for DVRs, Media Center PCs, or any device for which you want to preserve system settings
• Automatic Voltage Regulation maintains constant voltage by increasing low voltage and decreasing high voltage without the aid of the battery
• Unique IR Blaster allows projectors or projection TVs to cool their lamps and prevent damage from excessive heat before shutting down
• SmartStage Shutdown Technology shuts down your equipment in stages, prolonging battery life and reserving power for the most critical devices
• 13 outlets
• 8000 joules
• $500,000 Connected Equipment Warranty
• Hot-swappable replaceable battery
About PureAV
PureAV by Belkin provides the highest-quality connectivity solutions necessary to unleash the performance of all your audio video devices. The development of this premiere AV solution results from Belkin’s 20-plus years of leading-edge experience in digital connectivity and power protection. Designed to extract the full potential of your components, PureAV integrates technology and high-quality performance with a modern, clean elegance previously obtainable only at a premium price. PureAV products include power protection, interconnects, and digital wireless solutions. They are available through www.pureav.com as well as through a network of major distributors, resellers, and superstores.
Belkin Corporation, the global leader in connectivity solutions, launched its PureAV line in January 2004. Since then, the line has received numerous design awards from iF, I.D., CES, Business 2.0, and others. It has also garnered much praise from respected experts and publications in the AV field
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
