Bel Canto VBS1 Virtual Battery Supply
The Next Step in Pure Power Technology
Bel Canto Design, Ltd., manufacturers of analog and digital source components and amplifiers pulls the cover off their latest achievement, the VBS™ Virtual Battery Supply offering all the advantages of a 12 volt lead acid battery without the lead, the acid, or the battery! It offers smoother, even-tempered, well-adjusted DC than previously available.
Bel Canto’s Gourmet Power
The Bel Canto 24/192 differential DAC is the heart of the system, the Bel Canto Digital Control Center. We make sure the DCC dines on gourmet power! Rather than depending on extra-cost power conditioners to do the job, John Stronczer builds value into his designs with supplies that curb the crackling storms riding the AC mains.
Consider: More than likely your power is shared with fellow apartment-dwellers or houses sharing the same utility transformer. Every device in your home and theirs with an on/off switch sends spiky transients and noise through the system while spraying RFI around creating distortion. Air conditioners are prime culprits; lighting dimmers are distortion-producing machines, not to mention cheap wall-wart chargers greedily feeding only at the top and bottom of the 60Hz AC wave causing ripples of distortion when they all “bite” at once. Surges, phase distortion, over-and under-voltage conditions… imagine all that going on while you’re trying to listen!
Bel Canto’s current 120 volt power supplies are praised for their low noise and instantaneous power delivery. Put that down to custom power supply rectification and filtering that vastly increases energy storage, lowering noise and reducing sensitivity to power line fluctuations. But pushing the leading edge of eco-friendly, efficient power supplies, Bel Canto debuts its newest development, the VBS1.
VBT™ The Next Step In Pure Power Technology
Our Virtual Battery Technology is the next step forward in low-energy-profile, extremely low noise, ultra-efficient, integrated pure power supply designs, providing all the advantages of a 12 volt lead acid battery without the lead, the acid, or the battery for smoother, even-tempered, well-adjusted DC than previously available.
The extreme isolation and tight regulation of 100 Joules of energy storage plus high current capacity provide unmatched transparency, dynamics, low frequencies gravitas, and even greater image palpability. Bel Canto spoils you for life!
The VBS1’s power supply transformer is surrounded by common-mode and differential-mode filtering plus massive energy storage making for extremely quiet, well-regulated and isolated 12 volt DC power for the circuits to feed on. The VBS1 provides over 100dB of isolation and filtration starting below 100Hz up through the audio band and beyond into the RF region. For more, see Nuts and Bolts below!
What about the current DAC3 with its 120V supply? Continue with the fine sound you enjoy now, or if you have lust in your heart for extending your listening pleasure, if you understand that it’s all about the AC/DC, then you have several upgrades to consider.
Send your DAC3 back to Bel Canto for the power supply upgrade board that brings it to 12 volt DACVB specification. Then enjoy better performance with our new wolf-in-sheep’s-clothing, the high performance 12 volt LNS1 (Low Noise Supply 1). Then upgrade to the full VBS1 experience when circumstances permit. If you simply can’t contain yourself, go for the gold and we’ll send your upgraded DACVB back to you along with our new VBS1. (Talk to your dealer or contact us at Bel Canto!)
The Nuts and Bolts
As mentioned, the VBS1’s power supply transformer is surrounded by common-mode and differential-mode filtering plus massive energy storage making for extremely quiet, well-regulated and isolated DC power for much improved sound. The VBS1 provides over 100 dB of isolation and filtration starting below 100Hz up through the audio band and beyond into the RF region. The result is up to 100 times lower noise than traditional linear supplies in the audio frequency band.
The Virtual Battery Supply powers up to three Bel Canto music products equipped with the 12 volt VB internal power supply board for an incredibly high-value upgrade path. These include the CD2 (replacing the compact external 12VDC supply with the new LNS1), the DAC3, PRE3 or PHONO3, or any future Bel Canto product with VB 12VDC input compatibility.
The Sound
Like falling off a log! The extremely high isolation and regulation, the 100 Joules of energy storage and high current capacity of the VBS1 delivers breathtaking results! You’ll find greatly enhanced transparency, palpability, soundstage integrity, bass control, midrange texture, treble extension and sweetness. You loved your DAC3 before? Prepare yourselves!
Available Now!
  • DAC3VB – $2,695
  • VBS1 – $1,495
  • Factory upgrade to 12 volt VB board – $595
Available in September
  • Low Noise Supply LNS1
About Bel Canto
Bel Canto Design has developed award-winning products for more than 15 years using the highest standards of design, engineering and production practices. Included in the Bel Canto line are a series of CD players, DACs, integrated amps, mono and two-channel amplifiers, the e.One Pre3 stereo analog preamp, the companion Phono3 with adjustable cartridge loading, and the new USB Link 24/96 growing a pile of positive reviews, with more products you want on the way.
Our music products are made in Minnesota, and we subscribe to low-impact production methods that put little waste back into the system. Reduced packaging volume and lower transport weight reduces our environmental impact. We reuse or recycle more than 99% of the packing materials found in our incoming parts shipments, and each year we divert massive amounts of cardboard, paper, plastic film, and Styrofoam from landfills. Steel, aluminum, and other metal waste products are recycled and returned to the production stream.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
