New Feature-Rich Digital Products Now Shipping
New! The e.One DAC3.5VB
New! The e.One DAC2.5
New! The e.One DAC1.5
Bel Canto Design, Ltd. unveiled an updated line of Bel Canto digital processors–DCC or DAC Control Centers–topped by the superb new DAC3.5VB that significantly raises the bar for digital playback.
Core DAC Technology
The core DAC technology in Bel Canto’s High Dynamic Range converters is surrounded by Virtual Battery enhancement and the Master Reference UltraClock anti-jitter filter creates a pristine environment for D-to-A conversion, isolated from outside interference from the AC power grid or broadband jitter-induced noise on the digital inputs. The result is Bel Canto’s famously musical, dynamic sound.
Bel Canto, long known for building DACS, amplifiers, source components, creates top-flight system solutions based around their superb 24/192 upsampling DAC. These three new DAC Control Centers represent Bel Canto’s build philosophy: The DAC itself is the heart of today’s systems, not the (noisier) analog preamplifier.
Bel Canto focuses on optimizing each and every source–digital or analog–for the widest dynamic range possible, achievable with our updated core DAC technology. The Two-Stage Master Reference UltraClock anti-jitter circuit, our power supply options and totally transparent 24-bit volume control, our DCC DAC Control Centers provide startling resolution, low noise, and incredible dynamic range reproduction.
The e.One DAC3.5VB
192kHz 24-bit DAC Control Center
Analog input * ST Glass-Fiber Internal Virtual Battery Technology
Top of the e.One line of Bel Canto Dual-Differential DAC Control Centers, the DAC3.5VB integrates all your source components with peak-performance 126dB of dynamic range, providing unprecedented resolution, flexibility and control with a new, intuitive, easy-to-read display and user interface. The heavily-regulated internal VB power supply maintains an optimal electrical environment, dramatically reducing noise.
The core of all Bel Canto’s DAC Control Centers is our jitter-eliminating Two-Stage Master Reference UltraClock. Our 24-bit digital volume control is completely transparent and ensures the highest resolution possible while VB technology delivers the quietest, most isolated power available. Low jitter, low noise, low heat, low power consumption, and effective power line isolation brings music to life with extraordinary nuance and power.
Features
- 126dB dynamic range
- 24/192 digital inputs: AES, ST Glass-Fiber, BNC, Coaxial RCA and TOSLINK
- Two-Stage Master Reference UltraClock anti-jitter circuit
- Low-noise full galvanic isolation on all digital inputs
- Analog input
- Fully-balanced XLR and single-ended RCA outputs
- Virtual Battery technology
- New 8-character alpha-numeric display for Volume, Sample Rate and Input control
- Green, eco-friendly, low-heat, low noise, low power consumption
- RS232 port and remote
The e.One DAC2.5
Analog Input – Independent DAC Headphone Circuit – 24/96 USB Input
The DAC2.5 Dual-Differential DAC Control Center is also designed to integrate all your source components–analog and digital–with five 24/192 digital inputs, an analog input, and a 24/96 USB input. A 1/4″ front-panel headphone jack is driven by its own DAC and amplifier that optimizes both DAC’s performance for main outs or for headphone listening. The DAC2.5 outputs a very healthy 122db dynamic range offering excellent resolution, flexibility and control with a new, intuitive, easy-to-read display and user interface. The advanced internal LNS power supply is accessible via a standard IEC input.
Features
- 122dB dynamic range
- Low noise galvanically-isolated 24/192 digital inputs: AES, BNC, Coaxial RCA and TOSLINK
- Analog input and 24/96 USB input
The e.One DAC1.5
Independent DAC and Headphone Amplifiers * 24/96 USB Input
The DAC1.5 Dual-Differential DAC Control Center features an outstanding 122dB dynamic range and it integrates all your digital source components with five 24/192 digital inputs, one galvanically-isolated 24/96 USB input, and like the DAC2.5, a 1/4″ front-panel headphone jack driven by its own DAC/Amplifier combo that optimizes both headphone and main-out listening. The DAC1.5’s performance provides a complete turn-key package for your dream system. Our core D-to-A technology provides remarkable resolution, flexibility and control with a new, intuitive, easy-to-read display and user interface. The DAC1.5 sports a 12v off-chassis power supply.
Features
- Low Noise 24/192 galvanically-isolated digital inputs: AES, BNC, Coaxial RCA and TOSLINK
- 24/96 USB input
- New configurable display for 24-bit Volume, Sample Rate and Input control
- Green, eco-friendly, low-heat, low noise, low power consumption, IR remote
www.scullcommunications.com/pressresources.html
About Bel Canto
Bel Canto Design has developed award-winning products for more than 15 years using the highest standards of design, engineering and production practices. Included in the Bel Canto line are a series of CD players, DACs, integrated amps, mono and two-channel amplifiers, an analog preamp, a companion phono stage with adjustable cartridge loading, and the USB Link 24/96 USB-to-SPDIF converter with more products you want on the way.
Our music products are made in Minnesota, and we subscribe to low-impact production methods that put little waste back into the system. Reduced packaging volume and lower transport weight reduces our environmental impact. We reuse or recycle more than 99% of the packing materials found in our incoming parts shipments, and each year we divert massive amounts of cardboard, paper, plastic film, and Styrofoam from landfills. Steel, aluminum, and other metal waste products are recycled and returned to the production stream.
Bel Canto Design, Ltd. – Minneapolis MN – USA – info@belcantodesign.com
