Earbuds & In-Ear Headphones
Beats Studio Buds + Offer Improved Call and ANC Performance
Improved battery life, ANC performance, and much better call quality for $169.99. But are the new Beats Studio Buds+ that much better?
Beats Studio Buds + Colors with Charging Case
Wireless earbuds have become a commodity and there are no shortage of options at almost every possible price point. Consumers can’t seem to exist without them and there is no question that Apple and Beats control a huge slice of that multi-billion dollar segment. The successor to Beats Studio Buds have arrived in the form of the Beats Studio Buds +; the new earbuds claim major improvements to Active Noise Cancellation (ANC), call performance and battery life. The upgrades, along with a new transparent color option raise the cost to $169.99 (that’s $20 more than before).
Beats Studio Buds + Clear True Wireless ANC Earbuds
Did Nothing inspire Beats Studio Buds + transparent earbud design?
Three new acoustic vents are designed to improve audio precision and gently relieve pressure for a more comfortable all-day fit. Each bud is equipped with a proprietary two-layer transducer that flexes to deliver cleaner bass and ultra-low distortion. And with four ear tip options (XS, S, M & L) to fit a wider range of ears, Beats Studio Buds + create a comfortable acoustic seal for the best listening experience while also securing your earbuds in place.
For Apple Music users, Studio Buds + automatically play spatial audio for available tracks mixed in Dolby Atmos so you can enjoy true multidimensional sound and clarity. However, they don’t offer the personalized spatial audio with head tracking offered in AirPods Pro 2nd Gen.
Beats Studio Buds + Clear True Wireless ANC Earbuds in White worn in-ear on Woman
At the touch of a button, you can easily switch between Active Noise Cancelling (ANC) and Transparency modes. With 3x larger microphones, new venting, and a powerful processor, the Studio Buds + deliver up to 1.6x more powerful ANC and up to 2x better Transparency mode performance than its predecessor.
Upgraded microphones, an intelligent voice-targeting algorithm and an entirely new acoustic architecture enable high-quality call performance. The powerful microphones actively filter out background noise while enhancing the clarity of your voice.
Beats Studio Buds + True Wireless ANC Earbuds Colors
Enhanced Apple and Android Compatibility
While Beats Studio Buds+ are designed to work for both Android and iOS users, their features sets are not identical.
Apple Compatibility:
  • One-touch pairing – easy, one-touch setup instantly pairs with every device in your iCloud account5
  • “Hey Siri” – simply say “Hey Siri” to activate your voice assistant6
  • Find My – locate your lost earbuds on a map based on the last known connected location
  • Over-the-air updates – receive software updates and new features automatically
Android Compatibility:
  • Google Fast Pair – connect quickly with a single tap, and automatically pair to all Android or Chromedevices registered to your Gmail account
  • Audio Switch – seamlessly transition audio between your Android, Chromebook, and other compatible devices
  • Find My Device – easily locate your lost buds with Google Find My Device
  • Beats app – unlock access to product customization, software updates, and new features to get the mostout of your headphones
Beats Studio Buds + Clear True Wireless ANC Earbuds in Black worn in-ear on Woman
Connection and Customizable Controls
Class 1 Bluetooth technology offers extended range and exceptional cross-body performance, meaning reliable connectivity and fewer dropouts.
Simple, customizable on-ear controls allow you to manage music, toggle listening modes, take calls and activate voice assistant using the ‘b’ button. Additionally, you can set the press-and-hold action to use one earbud to control volume up and the other earbud to control volume down.
Battery Life and Case
With up to 36 hours of total battery life including 27 hours from the sleek, pocket-sized charging case and up to 9 hours from the earbuds, Beats Studio Buds+ are ready to go whenever you are. Find yourself low on battery? A 5-minute Fast Fuel charge provides an hour of additional use so you get more music, podcasts, and calls between every charge.
Designed with the Environment in Mind
Beats Studio Buds+ packaging is 95% fiber-based using recycled material and virgin wood from responsibly managed forests.12 The driver magnet is made of 100% recycled rare earth elements, while the solder of the main logic board is made of 100% recycled tin. Studio Buds+ is mercury-, berylium-, PVC-, and BFR-free.
Pricing and Availability
Beats Studio Buds+ are available now for $169.99 at Amazon (U.S.) or $229.95 at Amazon.ca (Canada).
Related Reading:
Networking
In-Wall Speakers
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
At $299, the Bose Ultra Open Earbuds offer excellent situational awareness, support for Snapdragon Sound, and one surprising feature.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Behind the scenes, Fraunhofer makes audio products sound better and easier to use. Find out what their latest innovations bring to the table.
With enhanced adaptive noise cancellation and a new driver design, Technics latest True Wireless Earbuds will give Bose, Sony and Sennheiser a run for...
At $279 or $399, the Beyerdynamic AMIRON 300 wireless ANC earbuds and AVENTHO 300 wireless over-ear headphones with ANC and head tracking are available...
