Beats Pill+ Bluetooth Wireless Speaker (2015)
Beats Pill+ Portable Bluetooth Speaker in Black or White
Three years after the original Beat Pill launch and four months after a recall on the Beats Pill XL, the company now owned by Apple is introducing a new portable Bluetooth speaker called the Beats Pill+ in either black or white for $230.
Beat Pill+ White Top
The Beats Pill+ is slightly larger than the original Beats Pill speaker, allowing for a bigger and fuller sound. The stereo active 2-way crossover system creates an optimized sound field for dynamic range and clarity across all genres of music. Tweeter and woofer separation uses the same acoustic mechanics found in professional recording studios around the world.
Beat Pill+ White Front
With its clean and sophisticated design, Beats Pill+ speaker looks as good as it sounds. Compact and durable enough to throw in your bag, the Beats Pill+ is designed to go wherever you do. Convenient button controls are now at the top of the speaker so you can manage your music with ease.
Beat Pill+ White Back Flap
The Beats Pill+ speaker has a 12-hour battery life to stay charged on the go. The lightning cable and power supply provide a quick full charge in just 3 hours. Keep track of your power levels with the fuel gauge so you always know how much battery is left and use the USB port to charge out.
Beat Pill+ Black
Beat Pill+ White SideAdditionally, Beats today announced the Beats Pill+ app for iOS or Android devices that provides added features and functionality, and allows you to manage your speaker straight from your fingertips. Using the intuitive interface, you can toggle between different modes of play with a simple tap or allow a friend to simultaneously pair to your speaker. A maximum of two devices can be connected at one time. However, two Pill+ speakers can be used together for stereo (left/right) playback or for doubling up the sound.
Price and Available
The new Beats Pill+ will be available for $229.95 in November 2015.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
Tired of all of those music streaming apps on your smartphone? Apple Music Classical is now available via your desktop browser.
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Android Apps
Android phone users can now download the Apple TV app to subscribe to Apple TV+ and MLS Season Pass.
