Bang & Olufsen BeoVox 1 In-Wall Speakers Announced
Invisible sound from Bang & Olufsen
BeoVox 1 combines elegant discretion with excellent sound performance and numerous new placement options.
Bang & Olufsen is now fulfilling the wish of many of our customers by launching BeoVox 1, a passive loudspeaker that can be placed in places where active loudspeakers fall short. Product Manager Michael Jensen explains: “We have had many customer requests for a loudspeaker solution that can be used in bathrooms and other wet rooms or outside on the terrace. A lot of customers have asked for a complete Bang & Olufsen solution that integrates with their BeoLink system and Beo4 remote control, and we have not been able to meet this demand with our active loudspeaker range until now”.
Being a built-in loudspeaker, BeoVox 1 also fits nicely and discreetly in hallways or rooms where you do not have much space. It can be completely concealed in the walls or in the ceiling. It’s extremely well suited for places where the primary activity is not listening to music, but where you’d still like to have music either as secondary entertainment or background sound.
Acoustic performance dedicated to placement
BeoVox 1 has been optimised acoustically for its placement in the walls or ceiling. In its construction, we have selected high-quality speaker units and applied a carefully designed cross-over network to attenuate and improve its performance so the sound dispersion in the treble area is optimised. The edges of the loudspeaker units are carefully curved to avoid diffractions which otherwise might have a negative effect on the sound performance.
A small switch next to the treble unit allows you to increase the treble performance to three different levels to compensate for its placement in the room. Treble is typically very directional, and if you place BeoVox 1 very high up, you may want to increase or attenuate the treble performance to get the best experience.
Design supports acoustic performance
Most in-wall speakers are either round or square, but Bang & Olufsen has chosen an elegant, discrete, oval design for BeoVox 1, applying typical Bang & Olufsen craftsmanship in its execution. The customer can choose between a black and white front grill, so BeoVox 1 matches most wall or ceiling decor. The hole pattern has been designed to ensure optimum acoustic performance, and of course you will see no “half or cut” holes at the edges.
“Another front grill detail is the painting process we apply”, explains Acoustic Engineer Jens Rahbek. “When applying paint to the surface, we have chosen to use a rotary atomizer painting system which ensures close spray-pattern control, so paint is only applied to the surface and does not penetrate into the holes. This is done to have full control of the acoustic performance, as the size of the holes has a great effect on the loudspeaker’s performance.”
Technical specifications
Designer David Lewis
Loudspeaker system Two-way passive system
1″ treble unit
6.5″ mid-range/bass unit
Frequency range 50-20,000 Hz
Dimensions (H x W x D) Visible size is 25 x 29.5 x 2.3 cm
In-wall depth is approx. 8.3 cm
Colours Black and white
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Loudspeakers
Bang & Olufsen bets big on Union Square’s comeback, opening its largest store in a San Francisco still digging out from years of crime...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
Bang & Olufsen turns 100 with the Beolab 90 Titan Edition—a $200,000+ statement in aluminum and ego that proves audiophile excess is alive and...
Bang & Olufsen claims Canvas The HiFi Frame (left) infringes on their Beovision Contour TV (right) design, but do they have case?
Bang & Olufsen marks 100 years with The Centennial Collection, reimagining the Beoplay H100, Beosound A5 and A9--stylish, nostalgic, and light on innovation.
Four Season’s Yachts elevates comfort and style on their luxury cruise line with LG's Transparent TV and Bang & Olufsen sound.
