Bang & Olufsen Beosystem 3000c: $30K for Vinyl and Streaming—Luxury Markup Included
Bang & Olufsen’s $30,000 Beosystem 3000c fuses vintage vinyl charm with modern wireless flair—and yes, you’re paying a massive premium for nostalgia dressed in walnut and brushed aluminum. Only 100 made, because exclusivity sounds better at that price.
Bang & Olufsen Beosystem 3000c Stereo System
In the grand tradition of charging princely sums for things your parents hid in the attic instead of fixing, Bang & Olufsen has unveiled the Beosystem 3000c – a $30,000 masterclass in making “vintage” sound posh.
Limited to just 100 sets (because exclusivity sells better than vintage sound quality), this lovingly resurrected Beogram 3000 turntable from 1985 now comes bundled with the Beolab 8 wireless speakers – for those who like their analog ritual dipped in Wi-Fi and walnut.
Painstakingly refurbished at B&O’s Factory 5 in Struer (by what we can only assume are Danish elves wielding pearl-blasting wands), the 3000c now sports re-anodised aluminium, a solid walnut back cover, and the sort of floating silhouette that’ll make mid-century modern fanatics weep into their oat milk lattes.
And let’s not forget the Beolab 8s – sculpted from acoustic-grade aluminium and finely slatted walnut, like the dashboard of a vintage Bentley if it could stream Spotify Connect. Together, they form a system that promises “deep, dynamic sound” whether you’re spinning dusty Dire Straits LPs or streaming Taylor Swift in high-res.
bang-olufsen-recreated-limited-edition
This is the third installment in Bang & Olufsen’s Recreated Classics series—a high-design resurrection program where iconic products get pulled out of retirement, pampered like vintage race cars, and sent back into the world with a fresh coat of Danish smug. The Beosystem 3000c blends hand-crafted walnut with re-anodised aluminum, combining preserved and polished original materials with modern upgrades courtesy of B&O’s artisans in Struer, Denmark—because nothing says timeless like a 1980s hi-fi dressed up for 2025.
From Mads Kogsgaard Hansen, Head of Product Circularity & Portfolio Planning: “Through our Recreated Classics series, we honour the cultural impact of vinyl listening while showcasing the long-lasting value of Bang & Olufsen products, even beyond their first lifecycle,….The Beosystem 3000c invites our customers to rediscover their vinyl collections and enjoy the emotional richness of music as it was meant to be heard, while effortlessly integrating into how we listen today.”
Beogram 3000 Revitalized: Vintage Cool Meets Danish Overengineering
beosystem-3000-turntable
The original 1985 Beogram 3000 was a sleek exercise in Danish precision—tangential tracking, floating form, and just enough buttons to make you feel in control without overthinking things. It was compact, elegant, and unmistakably B&O: a turntable that whispered, yes, I cost more than your first car.
Fast-forward to the 21st century, and the Beogram 3000 gets the Struer spa treatment as part of the Beosystem 3000c. Still unmistakably ‘80s chic, but now with a precision-machined walnut back panel, a remastered aluminium control panel, fresh fabric cables, a new dust lid, and a cartridge ready to outlive your streaming subscription. The aluminium bits? Pearl-blasted and brushed back to their former glory by the folks at Factory 5—because if you’re going to reissue history, you may as well do it with Scandinavian flair and obsessive attention to finish.
Here are some core specifications.
Beogram 3000
Bang & Olufsen ModelBeogram 3000
Product TypeTurntable
Speeds33 – 45 rpm
Speed Deviation< +/- 0.2
Wow and flutter, DIN< +/- 0.06 %
Rumble DIN Weighted > 80 dB
Rumble DIN Unweighted> 55 dB
Link compatibilityData Link
Power Supply110 – 240 V
Power Consumption< 10 W
Dimensions (WHD)42 x 7.5 x 32.5cm
16.5 x 2.95 x 12.8 in
Weight5.3 kg/11 lbs 11oz
Beolab 8: The $30K Flex Wrapped in Danish Aluminum and DSP Wizardry
Because when you drop thirty grand on a system, you’re not just buying speakers—you’re buying the kind of soundstage that makes your friends reconsider their life choices and your accountant ask questions. This isn’t just B&O showing off, it’s B&O reminding everyone else why they still get to charge car money for loudspeakers–which should raise more than a few eyebrows.
Bang & Olufsen Beolab 8 Wireless Speakers
The Beolab 8 wireless stereo speakers wear the same tailored walnut and pearl-blasted aluminum threads you’d expect from Bang & Olufsen—because if you’re spending this kind of money, your speakers better match your Danish credenza.
But the Beolab 8 isn’t just another pretty face in a brushed-metal tux. Like its more expensive siblings, it packs serious tech under that minimalist shell—DSP smarts, acoustic lens wizardry, and enough wireless versatility to make even the most cable-averse minimalist smile. And yes, it’s more than capable of doing justice to that freshly revived Beogram 3000—even if most people will just use it to stream their “Jazz Vibes” playlist on a Tuesday night.
Let’s be clear: the Beolab 8 isn’t your average Bluetooth speaker. It’s what happens when Bang & Olufsen decides your living room deserves the same acoustic tech they put in their $100K setups—wrapped in pearl-blasted aluminum and walnut, of course. Starting at $7,200 per pair (yes, per), the Beolab 8 is a compact wireless speaker with a serious superiority complex—and the hardware to back it up.
Surround Sound Setup? Easy.
Got a B&O TV from 2006 collecting dust? No problem. Beolab 8 plays nice with both vintage and modern gear via Powerlink and Wireless Powerlink. It’ll gladly step into your surround sound rig as a rear speaker and instantly become the most competent thing in the room—no offense to your soundbar.
Stereo? Like You’ve Never Heard Before.
Pair two Beolab 8s and you’re in for a stereo soundstage that doesn’t just fill the room—it reads the room. A built-in mic listens to your space and adjusts the sound accordingly. Narrow beam for late-night listening that won’t wake the baby. Wide beam when you’re entertaining and want to flex. And yes, the LEDs actually show you what mode you’re in, because B&O doesn’t do guesswork.
Placement? Pick Your Poison.
Tabletop, floor stand, wall mount, or ceiling mount—they’ve engineered a way to place this thing everywhere but inside your soul. Each mounting option is more sculptural than the last. It’ll look expensive because it is.
Streaming? Of Course.
Wi-Fi 6, Bluetooth 5.3, Apple AirPlay, Google Cast, Spotify Connect, TIDAL Connect—if it streams, the Beolab 8 probably already speaks its language. And with B&O’s Mozart platform inside, it’s not just future-proof, it’s future-arrogant. Think of it as the speaker equivalent of that guy who installed fiber in 2012—because he knew.
Beolab 8 Specifications
Beolab 8
Product TypeWireless Powered Speaker
Power Amplifiers1 x 50-watt, class D for tweeter
1 x 50-watt, class D for mid-range
1 x 200-watt, class D for woofer
Speaker Drivers1 x 0.6” tweeter
1 x 3.0” mid-range
1 x 5.25” woofer
Maximum Sound Pressure Level (SPL) @1M 101 dB SPL (single speaker)
104 dB SPL (pair)
Bass Capability SPL @ 1M84 dB SPL (single speaker)
90 dB SPL (pair)
Frequency Response28 – 23,000 Hz
Advanced Sound FeaturesActive Room Compensation, Beam Width Control, Thermal Protection, Adaptive Bass Linearization
Beolink SurroundWirelessly connect your speakers to a Beosound soundbar or Beovision to enjoy a true surround sound experience
Integrated Music ServicesBang & Olufsen Radio, TIDAL, Deezer
Streaming ServicesGoogle Cast., Apple AirPlay,  Bluetooth audio streaming,  Spotify Connect, TIDAL Connect, Deezer Connect, HomeMedia
Multiroom AudioApple AirPlay, Google Cast, and Beolink Multiroom technologies are integrated and ready for you to create a wireless Multiroom setup with Beolab 8.
Supported Audio FormatsMP3, WMA, AAC, ALAC, FLAC, WAV, AIFF, OGG, HLS Standard sample rates up to 192 kHz, stereo and up to 24-bit Note: WMA lossless is not supported
Wireless ConnectionsDual band WLAN 2.4 & 5 GHz
IEEE 802.11 b/g/a/n/ac/ax
Bluetooth 5.3
Wireless Power Link (24 bit / 48 kHz)
Digital Power Link (24 bit / 48 kHz)
Wired Connections2 x Ethernet 10/100 Mbit (for Internet and Digital Power Link)
1 x USB-C
1 x Powerlink (RJ45) 2 channels
Remote ControlBeoremote One BT
Beoremote Halo
Bang & Olufsen Ap
Recommended Room Size10 – 50 m²
Placement OptionsTable
Shelf
Floor
Wall mounted
Ceiling
MaterialsAluminium Fabric / Wood Polymer
Product Dimensions (WHD)On a table or shelf: 16.5 x 29 x 17.2 cm / 6.5 x 11.4 x 6.77 in
On the floor: 30.0 x 114.0 x 30 cm / 12 x 44.9 x 12 in
Wall mounted: 16.5 x 27.9 x 21.5 cm / 6.5 x 10.98 x 8.46 in
On ceiling: 17 x 36 x 23.1 cm / 6.69 x 14.2 x 9.09 in
WeightSpeaker only: 4.1 kg / 9lbs
In the BoxBeolab 8 Wireless Speaker
Power cable
Quick start guide
Speaker bracket (the part that connects the speaker to the stands)
Back covers (Left and Right)
beosystem-3000c-system-left
The Bottom Line
The Beosystem 3000c is the third installment in Bang & Olufsen’s Recreated Classics series—following the restored Beogram 4000c turntable and the glass-smooth Beosystem 9000c, complete with a resurrected Beosound 9000 CD player.
Now comes the Beosystem 3000c, which fuses the classic 1985 Beogram 3000 turntable with a modern pair of Beolab 8 wireless speakers. It’s a marriage of analog soul and digital swagger, hand-assembled in Denmark with just enough walnut and pearl-blasted aluminum to make Scandinavian design blogs cry with joy.
Only 100 units are being made, and at $30,000 a pop, it’s a masterclass in charging a luxury tax for nostalgia. You’re essentially paying $10K for the gear, and $20K for the vibe—but let’s be honest: if you’ve come this far, you’re probably not looking at the receipt anyway.
This is the system for people who want beautiful sound, beautiful design, and a subtle way to tell guests, “I spent a lot of money on this, and you should feel something about it.”
Bang & Olufsen calls it “elevated listening.”
Buyers will call it worth it—or at least, too late to return.
Availability & Pricing
The Beosystem 3000c (26,000 EUR – about $30,000 US) is made to order and available from select Bang & Olufsen stores and bang-olufsen.com from 27th May 2025.
4 Comments
4 Comments
  1. Anton
    May 27, 2025 at 9:33 am
    “Buyers will call it worth it—or at least, too late to return.”
    Pretty much sums it up.
    Great ending. $30,000??
    • Ian White
      May 27, 2025 at 9:52 am
      Anton,
      I did add that to Robert’s otherwise very good article. And I find the price somewhat disturbing.
      IW
  2. ORT
    May 29, 2025 at 9:53 pm
    Alas, poor Yorx. I knew its Hell…
    …As for B&O (Body & Odor?)? A turntable by any other name would play as sweet. I have bought and played records on a (I think) Crosley C6B-MA with a nondescript aftermarket acrylic platter that played as well as *GASP* my Pro-Ject ‘tables, albeit even with the platter it wasn’t as pretty.
    And my review was removed on spAmazon. So I returned both the ‘table and the acrylic platter. There is quality to be had at all price levels but sometimes I think we be livin’ in the Faketrix given the FM that some manufacturers foist upon us. The physical content just isn’t there for a great many products and turntables are just one of ’em.
    The troof of my words is far from sour grapes nor the favorite whine pressed from such grapes by frAudiophiles when it comes to the musicalifragelisticexpealidociousness of their dross.
    I say, “Let them be broffended!”, for like the late, great Rodney Dangerfield in “Back to School” I shall continue to rage against the dying of the light!
    thORTone Melon
    • Ian White
      May 30, 2025 at 10:16 am
      ORT,
      Bang and Crosely are in the top 3. 🙂 “Dad…more like a C.”
      Thorton Melon
Ruark MR1 MK3 Desktop Speakers with iMac
Ruark MR1 Mk3 desktop speakers deliver high-res sound, versatile connectivity, and compact design. Add the RS1 subwoofer for deep bass without taking up space.
Nothing CMF Buds 2 Cases all colors Nothing CMF Buds 2 Cases all colors
Earbuds & In-Ear Headphones
Nothing’s CMF Buds 2 earbuds feature Dirac Opteo technology for superior sound clarity, deeper bass, and hybrid ANC—all in an affordable, durable package perfect...
beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile
Beyerdynamic DT 990 PRO X adds detachable cable, 48-ohm impedance, STELLAR.45 drivers, and improved comfort—all for just $199.
Clearaudio Compass Turntables in Black and Silver with lid up front Clearaudio Compass Turntables in Black and Silver with lid up front
Discover the Clearaudio Compass, a German-engineered entry-level turntable built for audiophiles. Precision, style, and performance—ready to shake up Rega, Pro-Ject, and VPI.
Sennheiser BTD-700 with Momentum4 Headphones Sennheiser BTD-700 with Momentum4 Headphones
Dongle DACs
Sennheiser BTD 700 Bluetooth dongle boosts wireless audio with aptX Lossless, low latency, and Auracast—plug & play high-def sound for any device.
Pro-Ject Travel Set in Black and Silver Pro-Ject Travel Set in Black and Silver
Take real hi-fi on the road—no, not some tinny Bluetooth box. The Pro-Ject Travel Set is proper stereo, not sound for peasants. Fits in...
Father's Day Gift Guide 2024 Best Tech and HiFi Gifts
Upgrade Dad's digital lifestyle with gifts he'll enjoy all year and beyond this Father's Day. New Hi-Fi, Headphones, Home Theater and more!
The $349 Beosound A1 3rd Gen adds sound upgrades, fresh colors, and the same IP67 waterproof build—still one of the most stylish portable Bluetooth...
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Beoplay H95 are the best Bang & Olufsen wireless headphones ever built which include advanced noise cancellation and 38 hours of battery life.
Digital Music Systems
Bang & Olufsen partners with TIDAL to ensure the highest quality music playback and simplify usability within one app.
Impress Mom this year with the latest top-rated tech gifts this Mother's Day that are guaranteed to be useful all year long.
