Bang & Olufsen BeoSound 35 All-in-One Wireless Music System
Bang & Olufsen Beosound 35
Bang & Olufsen today announced BeoSound 35, an all-in-one, high-end wireless speaker system with an easy-to-use touch interface and integrated access to music and radio streaming services speaker. The one meter wide speaker, which resembles a soundbar on a pedestal, is designed to fill the entire room with a well-balanced sound, whether placed on a table or a wall. The pentagonal circumference allows you to cleverly tilt the music system for convenient access, so wherever you place it, you will easily be able to directly touch and control it.
The characteristic design of the BeoSound 35 presents a slim-line shape based on a light pentagonal structure with a front covered by black fabric – and an impressive one-meter wingspan. Still, the elegant proportions of the sound system allows it to smoothly blend in to any part of your home interior.
BeoSound 35 works as an independent music system with integrated access to TuneIn radio stations, Spotify and Deezer or whatever drive you have for your music collection.
BeoSound 35 features an intuitive, touch sensitive edge with essential function buttons found directly under the elegant OLED display. In fact, you do not have to be able to see the display when managing the BeoSound 35. The music system can be operated through your BeoRemote One or the BeoMusic App and will integrate seamlessly as part of a BeoLink Multiroom system in your home. BeoSound 35 also works with AirPlay, Bluetooth and DLNA based devices.
Bang & Olufsen Beosound 35 - Front open
The designer behind BeoSound 35 has struggled to make this high-end music system as light in its visual expression as possible. This is achieved through a design that is slightly thinner at the ends and this was possible due to the acoustic construction of placing the small treble drivers here. At the center of the loudspeaker there is more volume, which is required for bass drivers. By this, BeoSound 35 is a true case of form follows function.
Price and Availability
BeoSound 35 will be available in Bang & Olufsen stores mid-April, 2016 at a recommended retail price of $2,785.
Bang & Olufsen Beosound 35 - back
FEATURES
BeoLink Multiroom
If you are looking to design a wireless multiroom setup around BeoSound 35, you have the opportunity to combine it with a range of our BeoLink Multiroom products. BeoLink Multiroom technology is integrated and ready.
One-touch-go easy local operation
Primary operation directly on BeoSound 35:
Start music / Volume / Mute / Source selection / Previous / Next / Stand-by / Join BeoLink Multiroom
Adaptive Bass Linearisation (ABL)
Continuously adapts the bass response to the input signal, resulting in a signi cantly improved bass performance, without the risk of damaging the driver.
Room adaptation
Wall, corner and free standing option via the setup menu. Control the bass response depending on placement in the room.
Thermal protection
The temperature of the speaker driver is constantly monitored to keep the speaker performing well at all times.
SPECIFICATIONS
Designer
Torsten Valeur, David Lewis Designers
Power consumption
Standby: 0.5 watt
Networked Standby (LAN): 2.2 watt
Networked Standby (Wi-Fi): 3.6 watt
On mode: 19 watt
Typical: 50 watt
Effective frequency range
45 – 22.000 Hz
Connections
Wi-Fi/WLAN 802.11 b/g/n (2.4 GHz & 5 GHz)
Bluetooth 4.0
Ethernet 10/100 Mbit/s
OPTICAL
RCA
Supported audio formats
MP3, WMA, AAC, ALAC, FLAC, WAV, AIFF.
Standard sample rates up to 192kHz, stereo and up to 24bit.
WMA lossless is not supported
Weight & Dimensions (w/o stand/bracket)
6.2 kg
100 x 13.1 x 12.5 cm W x H x D
Power amplifiers
2 x 80 watt class D for woofers
2 x 80 watt class D for tweeters
Display
256 x 64 OLED, grey scale
Streaming formats
Apple AirPlay
Bluetooth Audio
DLNA enabled products
Remote control options
BeoRemote One
BeoSound Essence Remote
BeoMusic App
Beo4
Placement options
Table stand or wall mounted
Speaker drivers
2 x 4″ woofer
2 x 3⁄4″ tweeter
Colors
Front cover: Black
Cabinet: Aluminium
Integrated Music Services
Spotify Connect* Deezer*
QPlay 2.0*
TuneIn Internet radio*
*market dependent
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Beoplay H95 are the best Bang & Olufsen wireless headphones ever built which include advanced noise cancellation and 38 hours of battery life.
Digital Music Systems
Bang & Olufsen partners with TIDAL to ensure the highest quality music playback and simplify usability within one app.
Impress Mom this year with the latest top-rated tech gifts this Mother's Day that are guaranteed to be useful all year long.
CD Players
Bang & Olufsen's coolest CD player of the 90s returns as a limited edition Beosystem for a cool $55,000.
