Bang & Olufsen Beoplay H95: New Flagship Wireless ANC Headphones
Beoplay H95 are the best Bang & Olufsen wireless headphones ever built which include advanced noise cancellation and 38 hours of battery life.
Bang & Olufsen Beoplay H95 Wireless Noise Cancelling Headphones
2024 Updates:
95 Year Anniversary Model
To celebrate 95 years of innovation in sound, design and craftmanship, Bang & Olufsen set out to create the finest wireless headphones the Danish audio specialist has ever built. Today, the company announced the new $800 Beoplay H95: the highest quality in sound, long lasting comfort, truly effective noise cancellation, a beautiful chassis, the highest quality materials and the most satisfying user experience in a Bang & Olufsen wireless headphone to date.
“Beoplay H95 is a distillation of the best elements of Bang & Olufsen sound, design and craftsmanship – an enhancement within the headphone category that elevates our 95 years heritage of high standards.” Christoffer Poulsen, Bang & Olufsen SVP of Product Management
Comfort
Comfort and fit are essential to truly enjoy sound quality. Beoplay H95 comes with an oval, over-ear design with soft lambskin ear cushions that provide a luxurious and superior fit for long-term wear, while an innovative and intuitive user interface is provided through a combination of touch control and mechanical dials.
Through research and experimentation, the Bang & Olufsen engineers created an earpad design that fits nicely around the ears and is no bigger than necessary. This shape, formed in soft memory foam, also creates good contact to the skin, which is important to block the noise from outside. The head-band design has been completely revamped for a cleaner look, with top-grain cowhide, custom-knitted textile, and softly padded with memory foam for comfort.
A brushed aluminium framework contrasts with the texture of the leather headband giving a minimalist and refined appearance. Magnetically detachable lambskin ear cushions feel as good as they look, and the adaptive memory foam inner padding, combined with rotating and tilting earpieces that ensure perfect fit, provide the ultimate in comfortable listening and passive sound cancellation.
Beoplay H95 Wireless Headphones in Grey Mist
Beoplay H95 (Grey Mist)
Design
Beoplay H95 is designed around a set of customized 40mm titanium drivers with neodymium magnets mounted in ported enclosures, while the sound design is implemented using filters in a proprietary digital signal processing (DSP) engine developed by Bang & Olufsen. The headphones build on its impressive passive noise reduction with the most advanced Active Noise Cancellation (ANC) of any Bang & Olufsen headphone, which is both adjustable and adaptive. The ANC performance is entirely based on digital processing and uses both a feed-forward and feedback microphone to reduce noise as much as possible. The tuning and testing of the ANC processing was done under real life conditions as well as Bang & Olufsen’s Virtual Acoustic Laboratory (VR Lab) in Struer, where the engineers are able to emulate a variety of different noise conditions ranging from airplanes, train stations, office spaces and street noise.
Touch Controls
Bang & Olufsen has pioneered touch interfaces on aluminium surfaces. Today, the Danish audio company is taking this a step further by adding a precise aluminium dial to each side of Beoplay H95. Inspired by the focus rings on the lenses of high-end cameras, the dials move with precision and just the right amount of smooth resistance. Each dial has a fine, linear texture that confirms contact. It is a high-touch element that feels natural to use, and it makes sound preferences quickly accessible. The dial on the right controls volume, while the dial on the left adjusts ANC and transparency.
Features
The new Beoplay H95 headphones build on its impressive passive noise reduction with the most advanced Active Noise Cancellation (ANC) of any Bang & Olufsen headphones, which is both adjustable and adaptive. The ANC performance is entirely based on digital processing and uses both a feed-forward and feedback microphone to reduce noise as much as possible.
Beoplay H95 comes with market leading battery time with up to 38 hours of listening in one charge – even with ANC turned on. If you need to keep in touch with family or work colleagues, four voice microphones give superb clarity when making calls. Beoplay H95 uses beam forming mics and advanced noise reduction technology to capture the voice as clearly as possible, while simultaneously reducing the influence of background noise. This also includes extensive side-tone processing that gives a more natural feeling of speech. Moreover, Beoplay H95 comes with a user-adjustable transparency mode to allow the user to hear surroundings without removing the headphones.
ACC and aptX Adaptive
To further bring an unrivalled listening experience, Beoplay H95 comes with ACC and aptX Adaptive – the next generation dynamically adjustable audio codec, designed to deliver robust, low-latency, low-bit rate, high quality wireless audio — while Bluetooth 5.1 secures optimal connectivity.
Folds Flat for Travel
Beoplay H95 is easily and elegantly transportable. The aluminium mono arms, a Bang & Olufsen signature element, are sculpted with refined surfaces and upgraded with additional pivoting hinges so the headphones fold flat and inwards to a very small size that fits neatly into a compact aluminium-shelled carrying case. Lined with matching textile inside, the headphones are protected from knocks as you go from one place to another. The case is classic Bang & Olufsen – built to last from beautiful materials and meant to be featured – not hidden to truly complement the Beoplay H95 headphones.
Accessories
Accessories included in the box are a flight adapter, charging cable and audio cable. Each has have been given a touch of refinement with matching aluminium housing and woven fabric cords with a leather strap to make tangled cables a thing of the past.
Beoplay H95 Headphones with Numbered Charging Case
Online exclusive: Beoplay 95 with numbered engraved case
Pricing and Availability
Beoplay H95 will be available September 10, 2020 for $800 in Black and Grey Mist.
International pricing is 800 EUR, 700 GBP, 900 CHF, 6000 DKK.
To celebrate the 95th anniversary, limited edition Beoplay 95 headphones will be available only from bang-olufsen.com in numbered format from 1 to 95, beginning August 27, 2020.
2024 Update: Limited edition models are no longer available. The price of Beoplay H95 has increased to $999 USD, check price on Amazon. New colors have been added since the original launch.
On September 3, 2024, Beoplay H95 was replaced by the Beoplay H100.
Related reading: Bang & Olufsen Beoplay H95 Review
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Technics latest wireless headphones boast up to 60 hours of battery life and feature 8 mics for noise-cancellation whether listening to music or talking...
Bang & Olufsen's top-of-the-line luxury wireless noise cancelling headphones feature Dolby Atmos with head-tracking in a stunning new design.
Digital Music Systems
Bang & Olufsen partners with TIDAL to ensure the highest quality music playback and simplify usability within one app.
