Bang & Olufsen Introduces the Colorful Beoplay EX Wireless ANC Earbuds
Stylish, functional and waterproof Bang & Olufsen noise-cancelling wireless earbuds hit the market for $399. What’s not to like?
Bang & Olufsen Beoplay EX Wireless Earbuds in Gold Tone with Case
The Danish luxury audio brand, Bang & Olufsen has just introduced its third wireless earbud called the Beoplay EX. The $399 ANC earphones have an AirPod-like design in some rather attractive color options. They join the Beoplay EQ and Beoplay E8 Sport earphones ($350) — the latter of which made our list of best wireless earbuds last year.
At first glance, the Beoplay EX seem to combine the best features of its existing models. The Beoplay EX boasts Adaptive Active Noise Cancellation and a fully waterproof design for use in the office, on the move, in the gym or at home.
Bang & Olufsen Beoplay EX earphone colors
The Bang & Olufsen’s new shape has created space for a 9.2 mm speaker driver in Beoplay EX; the biggest ever used for a true-wireless device by the brand. This results in a significant upgrade in the power of each audio moment, without compromising on comfort. Listening can last all day, as Beoplay EX has up to 20 hours of total playtime including charging in the case, and 6 hours of playtime with ANC turned on.
Call quality is also said to be improved. Each earphone has three microphones, beamforming technology and own voice functionality built in, to ensure a seamless call experience.
Bang & Olufsen Beoplay EX Wireless Earbuds Colors Inner
Design
Beoplay EX differs most notably from previous Bang & Olufsen earphones in the shape of its design. Designed by Thomas Bentzen, the stem-based shape has been adopted and transformed into a finished offering that is equal parts stylish and comfortable. The housing of the earphone placed inside the ear, is smaller than ever before, and ensures a comfortable and stable fit that can be worn for hours without readjustment.
The practicality of this new shape is matched with the signature Bang & Olufsen aesthetic, perfected over 96 years of craftmanship and design innovation. From the mirror-like glass interface which catches the light at the perfect moment, to the surrounding brushed aluminum ring, Beoplay EX creates a statement for the wearer whether they opt for the slick Black Anthracite, opulent Gold Tone or striking Anthracite Oxygen finish. Beoplay EX comes complete with a matching brushed aluminum charging case, which is conveniently pocket-sized, making it the perfect travel companion.
Bang & Olufsen Beoplay EX Wireless Earbuds in Gold Tone in Case
Beoplay EX in Gold Tone
With the latest in Bluetooth 5.2 technology and background noise reduction, Beoplay EX makes it easy to go wireless and connect with the office, friends and family in any location. With Multipoint connectivity, the earphones can also connect to two devices at the same time, allowing wearers to listen to music from one and make calls with the other. Beoplay EX is also sweat and IP57-certified dust resistant and waterproof, making it an extremely durable personal sound solution.
Bang & Olufsen Beoplay EX in Anthracite Oxygen
Pricing & Availability
The Beoplay EX in Anthracite Oxygen (Blue/Black) is available now for $399 at bang-olufsen.com and internationally priced at 399 EUR / 349 GBP / 2998 CNY.
The Gold Tone color option will be available from May 27, 2022 with the Black Anthracite (all-black) color becoming available from June 2022, each for the same price.
Specifications
  • Frequency Response: 20 – 20,000 hz
  • Impedance: 32 Ohm
  • Sensitivity: 108 +/- 2 db, 1mW @1kHz
  • Bluetooth: Bluetooth 5.2 · AAC, SBC, aptX Adaptive
  • Speaker Drivers: 9.2 mm Electro-dynamic drivers with neodymium magnets
  • Microphone
    • 6 Digital MEMS Mics in total
    • 3 Digital MEMS Mics in each earphone
  • Buttons
    • Touch controls: Play/Pause/Skip track/
    • Answer calls ANC/Transparency mode/
    • Volume up/Volume down
  • Battery
    • Earphones: Up to 6 hours with ANC
    • Earphones + charging case: Up to 20 hours with ANC
  • Battery Size
    • Charging case: Capacity 600 mAh
    • Earphones: Capacity 70 mAh
  • Charging Time
    • Earphones: ~ 1.5 hours in charging case
    • Charging case: ~ 2 hours via USB-C / ~2.5 hours wireless charging
  • Weight: 65g (2 x 6g earbuds + 53g case)
  • Dimensions (WxHxD)
    • Earphones: 22.5 x 34.8 x 22.66 mm
    • Charging case: 66.15 x 28.1 x 48.15 mm
Beoplay Comparison
Beoplay E8 SportBeoplay EQBeoplay EX
MSRP$350$399$399
MODEL YEAR202120212022
NOISE ISOLATIONPassive Noise CancellingAdaptive Active Noise CancellationAdaptive Active Noise Cancellation
DRIVER TYPEElectro-dynamic, 5.7 mm diameterElectro-dynamic, 6.8mm diameterNeodymium, 9.2 mm diameter
DRIVER SENSITIVITY107dB ± 3dB, 1kHz @-3 dBFS (max volume) with Bluetooth playback107dB ± 3dB, 1kHz @-3 dBFS (max volume) with Bluetooth playback108 dB +/- 2 dB 1kHz @ 1mW (0.178V)
FREQUENCY RANGE20 – 20,000 Hz20 – 20,000 Hz20 – 20,000 Hz
IMPEDANCE16 Ohm17 Ohm +/- 2.55 @ 1KHz 32 Ohm +/-3.2 @ 1KHz
CUSTOMIZABLE SOUND EQPresets available and fully customizable through Bang & Olufsen AppPresets available and fully customizable through Bang & Olufsen AppPresets available and fully customizable through Bang & Olufsen App
Design
DESIGNERBang & OlufsenThomas BentzenThomas Bentzen
FITTrue wireless In-ear
Fit for sport
True Wireless In-earTrue Wireless In-ear
EARGELS4 pairs of silicone tips (XS,S,M,L)
3 pairs of silicone earfins (S, M, L)
Comply™ Foam tips (M size)
COMPLY™ Isolation ear tips series 200 (Size M)
4 pairs of silicone ear tips (XS,S,M,L)
MATERIALSAluminium
Polymer
Silicon
Hard anodised Aluminium in space craft grade quality
Polymer
Silicone
Aluminium
Tempered Glass
Polymer
Silicone
DUST AND WATERPROOF RATINGIP57 rating: fully dust protected and can withstand immersion in water up to 1 meter for up to 30 minutes.IP54 (dust and splash/sweat resistant)IP57 (dust and waterproof)
DIMENSIONS (MM)Earphones: 23 W x 25 H x 21 D
Charging case: 70.6 W x 33.5 H x 35.6 D
Earphones: 24 W x 22 H x 27 D
Charging case: 77 W x 40 H x 26 D
Earphones: 22.5 W x 34.8 H x 22.7 D
Charging case: 66.2 W x 48 H x 22.1 D
WEIGHTEarphones:
Right (Primary): 6.4 g
Left (Secondary): 6.4 g
Charging case:
55 g (without earbuds)
Earphones:
Right: 8g
Left: 8g
Charging case: 50 g  (without earbuds)
Earphones:
Right: 6g
Left: 6g
Charging case: 53 g  (without earbuds)
Battery
BATTERY LIFEUp to 7 hours
Up to 30 hours with charging case at moderate volume
Up to 6.5 hours with ANC
Up to 7.5 hours without ANC
Up to 20 hours with charging case at moderate volume
Up to 8 hours without ANC
CHARGING TIMEEarphones: approx. 2 ½ h
Charging Case (USB-C): 2  h
Charging Case (Qi Wireless): 2 ½ h
Charging for 20 minutes gives approximately 1½ hour playback.
Earphones: approx. 1 ½ h
Charging Case (USB-C): 1.40  h
Charging Case (Qi Wireless): 1.50 h
Charging for 20 minutes gives approximately 2 hours playback.
Earphones: approx. 1.5 h
Charging Case (USB-C): 1.45  h
Charging Case (Qi Wireless): 2.15 h
Charging for 20 minutes gives approximately 1.75 hours playback.
BATTERY SIZEEarphones:
Right (Primary) 60 mAh
Left (Secondary) 60 mAh
Charging Case: 450 mAh
Earphones:
Right (Primary) 85 mAh
Left (Secondary) 85 mAh
Charging Case: 340 mAh
Earphones:
Right (Primary) 70 mAh
Left (Secondary) 70 mAh
Charging Case: 380 mAh
Connectivity
BLUETOOTHBluetooth 5.1Bluetooth 5.2Bluetooth 5.2
SOUND CODECSSBC, AAC codec, Aptx classicSBC, AAC codec, aptX™ AdaptiveSBC, AAC codec, aptX™ Adaptive
MICROPHONE4 – With beamforming signal processing6 x MEMS, omni-directional (beam directional for speech)6 x MEMS, omni-directional (beam directional for speech)
INPUTS AND OUTPUTS1.25 m USB-A to USB-C cable for Charging
Qi Wireless Charging
0.50 m USB-A to USB-C cable for Charging Qi Wireless Charging
5V DC / 500mA USB-C or 400mA Qi charged
CERTIFICATIONSGoogle Fast Pair
Made for iPhone (MFi)
Microsoft Swift Pair
Supports Apple watch interface
Google Fast Pair
MULTIPOINT2 active devices simultaneously2 active devices simultaneously
MSRP$350$399$399
MODELBeoplay E8 SportBeoplay EQBeoplay EX
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
In-depth review of the Bowers & Wilkins true wireless noise cancelling earbuds covers everything you need to know.
The updated Bowers & Wilkins Pi7 S2 and Pi5 S2 True Wireless Earphones featured longer battery life, upgraded drivers, and superior sound quality.
Technics adds Auracast support to the EAH-AZ100 earbuds, enabling easy Bluetooth LE audio sharing and broader compatibility without changing the sound or the price.
Bang & Olufsen’s Beosound Premiere brings Dolby Atmos and Wide Stage tech to a smaller, $5800 “budget” soundbar—luxury sound for anyone who still has...
$1,500 Beo Grace earbuds from Bang & Olufsen push luxury, style, and audio performance but don’t forget the optional $400 leather pouch.
For 2024, Apple is introducing 4 new AirPods. Find out what's new and surprisingly what hasn't changed.
