Loudspeakers
Axiom Launches New Architectural Loudspeaker Series
W Series of In-Wall/On-Wall Hybrid Speakers Integrate High Performance with High Style
Dwight, Ontario, October 19, 2005 – Axiom Audio, www.axiomaudio.com, the award-winning loudspeaker manufacturer known for delivering outstanding performance and value to its customers has developed an in-wall loudspeaker line that delivers no-compromise sonic performance.
The Problem: Many current in-wall speakers rely on the cavity behind the wall for speaker loading but have widely variable performance because the sheetrock wall surface vibrates with the rear output from the drivers, producing deeply colored and inaccurate sound. And if no in-wall cabinet is included, the driver’s rear output will produce distorted sound in the neighboring room.
The Solution: Overcoming these drawbacks, Axiom’s new Architectural W2, W3, and W22 on-wall/in-wall hybrids feature fully integrated carefully tuned enclosures that recess into the wall, combined with an attractive exterior finished baffle that keeps the speaker’s drivers well away from the sound-degrading effects of the wall surface. And that proprietary enclosure means that the uncolored wide-range sound and bass loading will remain consistent no matter which wall you install the speakers in.
The integral enclosure uses a unique porting system that lets the three bookshelf in-wall models deliver neutral, wide-range transparent sound with tonal balance that’s virtually indistinguishable from the sound quality of Axiom’s highly-praised separate bookshelf models (the M2i, M3ti and M22ti). The slim profile is a perfect complement to today’s modern thin-panel plasma and LCD TV screens, keeping pace aesthetically and sonically with the hi-res video image of HDTV.
Contacted at Axiom’s plant in Dwight, Ontario, Axiom founder and President Ian Colquhoun remarked, “These new in-wall/on-wall hybrids are a breakthrough. They sound as good as our regular bookshelf models, which means that our customers can now enjoy the benefits of an in-wall design without compromising sound quality. I’m really proud of the fact that our integrated enclosure design avoids the tonal imbalances that characterize most conventional in-wall speakers.”
A separate metal frame with self-compressing screws locks the outer speaker enclosure firmly to the sheetrock of the wall, which results in a smooth custom look, thereby eliminating the traditional box from the room by burying the loading portion inside the wall. The W series’ unobtrusive appearance solves home decorating problems by freeing up floor space, and will prove popular with custom installers and interior designers. The W series’ attractively finished front baffles come in five handsome seamless finishes (Boston Cherry, Light Maple, Mansfield Beech, Black Oak, and Eggshell White) and are also available in 12 custom finishes by special order, providing unprecedented choice at this price point.
The integral recessed wall-mount enclosure extends less than 3.5 inches into the wall, so the W series speakers mount easily in any standard 3.5-inch stud wall. A mounting template is supplied with the speakers to aid installation.
Axiom’s “W” Architectural Series On-Wall/In-Wall speakers are priced as follows: $220 each for the W2, $245 each for the W3, and $325 each for the W22.
Axiom is a world leader in psycho-acoustical research, which provides the scientific basis on which all Axiom loudspeakers are designed and engineered, including careful acoustical measurements and uncompromising double-blind listening tests.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
