Center Speakers
Axiom Audio VP180 Center Speaker Announced (2010)
Axiom Audio has announced the new VP180, a definitive no-compromise center channel that delivers the same extended deep bass, tonal neutrality and spatial transparency as Axiom’s critically acclaimed M80 and M60 tower speakers.
The VP180 uses six drivers: two 6.5-inch aluminum-cone woofers, two 5.25-inch aluminum midranges, and two 1-inch titanium dome tweeters in a horizontal array. The ported, bass-reflex 4-ohm (nominal impedance) VP180 is said to produce the same deep bass, excellent vocal tonality and clarity, and extended high frequencies as two M80 towers, summed in mono.
The VP180 weighs in at 56 pounds (26 kg), so sturdy support for this monster is mandatory. Dual custom aluminum stands are offered as a $240 option for the pair with shipping starting on July 15th. A magnetic grille and bi-wiring/bi-amping connections are standard.
The VP180 is available at AxiomAudio.com for $695.
VP180 Specifications
Enclosure: Triple Vortex / Reflex
Max Amp Power: 400 Watts
Min Amp Power: 10 Watts
Freq Resp +/-3dB (Hz): 34 Hz — 20 kHz
Freq Resp +3dB- 9dB (Hz): 25 Hz — 20kHz
Impedance (Ohms): 4 Ohms
SPL in Room1w/1m(dB): 95 dB
SPL Anechoic 1w/1m(dB): 91 dB
X-Over 150 Hz & 2.7 kHz
Tweeter: Dual 1″
Woofer: Dual 5.25″
Sub Woofer: Dual 6.5″
Dimens. H W D (inches): 9.25″ x 39.5 ” x 17″
Dimens. H W D (mm): 235 x 1003 x 432
Weight (lbs) each 56.8 lbs
Weight (kg) each 25.76 kg
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Hi-Fi Components
The venerable Canadian manufacturer has been acquired by Colquhoun Audio and joins Bryston and Axiom Loudspeakers under the family tent.
New Bryston CEO, James Tanner will manage operations and fortify relationships with A/V specialty dealers.
Are you ready for some home theater excitement? The Axiom Audio Epic 80 home theater 5.1 speaker package delivers. Retailing for $2,413 (US), this...
Axiom Audio today announced a Kickstarter campaign to launch a revolutionary portable, wireless, multi-room Wi-Fi speaker called AxiomAir. The $800 speaker is expected to be...
Save $80 by pre-ordering the new Axiom Audio AxiomAir N2 wireless speaker that's both multi-room ready and portable.
Each of these subwoofers proves you don’t have to spend a lot to get low frequency bass effects for movies and music. But does...
New Subwoofer Mines the Deepest Regions of Bass To most humans and animals, the distant rumbles of ultra-low bass frequencies signal impending danger. Dogs...
Axiom’s newest addition, the $1,100 Epicenter EP400 DSP subwoofer will launch in March! Next month, Axiom will introduce the Epicenter EP400, a new, compact...
