AVM’s PH 8.3 Phono Stage Can Handle 4 Cartridges: AXPONA 2023
Do you currently run 4 different phono cartridges but wish there was a single phono preamp that could handle all of them in one box? Meet the AVM PH 8.3 Phono Preamp.
AVM PH 8.3 Phono Stage Front and Rear
Yes. You read that correctly. The AVM PH 8.3 Phono Stage can handle 4 separate cartridges; which makes it one of the most versatile $14,000 USD phono preamplifiers in the world.
Bluebird Music, a distributor of high-performance audio products since 2000, is announcing the North American availability of the AVM (Audio Video Manufaktur) PH 8.3 External Phono Stage (aka Phono Preamp).
To kick things off, Bluebird Music is showing the AVM PH 8.3 at the 2023 Axpona (Audio Expo North America) from April 14th-16th which is being held just outside of Chicago.
AVM PH 8.3 Phono Stage Silver Front
Features
The PH 8.3 is AVM’s new reference tube phono stage. This external phono preamp is designed to provide vinyl record lovers with world-class sound quality.
Tip: The tubes used are dual triode AVM 803 T’s.
The PH 8.3 combines the musicality of AVM’s exclusive with cutting-edge flexibility and control.
The PH 8.3 incorporates DC-coupled circuitry, paired with five separate power supplies and all-passive equalization. This supports operational stability with very low distortion.
The PH 8.3 allows three types of inputs: (MC XLR, MC RCA, and MM RCA) that are installed modules. Up to 4 inputs can be installed as desired, so any combination can be selected from the types listed.
Tip: MC stands for Moving Coil and MM stands for Moving Magnet. This refers to the type of phono cartridge that sends the signal from a turntable to the phono preamp.
On the plug-in input modules, the incoming signals are amplified immediately after the input at line level (approx. to 150mV), with MM by 40dB, with MC by 60dB. All equalization or adjustments are then made with these enlarged signals, so the distortion issues of all subsequent stages become less important in comparison.
The PH 8.3 automatically recognizes which modules are plugged into which slots or as combinations and adapts all functions such as the menu structures. The inputs can also be named individually. Inputs are galvanically isolated from each other.
Gain and cartridge loading is adjustable via remote control.
Inputs can be named individually and are isolated from each other.
The PH 8.3 has a set of both XLR and RCA analog outputs for connection to a compatible amplifier or AVR.
AVM PH 8.3 Aluminium Remote Control
Technology
Users can remotely select from RIAA or four other equalization curves, maximizing performance from vintage records.
The PH 8.3 equalizes the phono signals passively and analogously and not in an amplifier stage. This has the advantage that each of the three time constants can be set individually.
This makes it possible to use 5 other common LP equalizations (RIAA, TELDEC, NARTB, EMI, COLUMBIA, DECCA) in addition to the RIAA curve that is widespread today. These curves differ in the corner frequencies & time constants used when cutting the record.
These separation characteristics are inverted by the PH 8.3 with better than +/- 0.1 dB accuracy. This is done through a complex matching procedure of the built-in resistors (matched to 0.1%) and the film capacitors (matched to 0.5%).
A  switchable subsonic filter is used to dampen rumbling noises down to 30Hz/12dB/octave.
The level (gain) can be adjusted in 5dB steps to measure different pick-up systems. Mono/stereo and the phase can also be inverted to optimize sound measurement which is desirable for older recordings. All adjustments can be  made from the listening position using the remote control supplied
5 independent power supply units supply all stages of the PH 8.3 individually and effectively exclude unwanted mutual interference of the amplifier stages by other assemblies.
The silent switching power supplies deliver high-precision supply voltages, practically independent of the mains voltage. In contrast to large transformer power supplies, no acoustically negative magnetic fields are generated with these power supplies.
Price and Availability
The retail price of the PH 8.3 is $13,995 (US) and $17,995 (Canadian). and is available through the Bluebird Music dealer network in both black and silver finishes. For more information, visit avm.audio.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
A new turntable, phono stage, cartridge or speaker could be the upgrade you've been looking for or the perfect gift for any vinyl lover.
The iFI GO Pod appears to be a rather viable methodology for turning your favorite pair of wired IEMs into wireless earbuds. What makes...
The EAT E-Glo 2 tube phono stage delivers reference-level analog performance with balanced MC inputs and classic all-tube design. Worth the $11,000 price?
At $2,899, Cyrus Audio makes a bold claim about its 40 PPA which supports MC and MM cartridges with balanced XLR outputs and upgraded...
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
