Digital Music Systems
AVM’s CS 8.3 Black Edition Streaming Receiver: Just Add Speakers
The AVM CS 8.3 Black Edition Streamer Receiver will take a huge bite out of your wallet, but it comes with everything except loudspeakers.
AVM CS 8.3 Top
German manufacturer, Audio video Manufaktur (AVM) has been building handcrafted luxury products in Germany since 1986 and while it took a few decades for their outstanding products to establish a foothold in North America — the wait has certainly been worth it.
All of their design and engineering is done in house, and having inspected under the hood of a number of their components, the parts and build quality is second to none. When you ask consumers to spend almost $18,000 on a streaming receiver with a built-in CD player — it better offer more than just off-the-shelf components and mid-tier sound quality.
The new CS 8.3 Black Edition takes its place as AVM’s best-sounding All-In-One. It features a specially selected version of the latest ESS DAC, a new upgraded tube specially made for the Black Edition, upgraded internal wiring, upgraded speaker binding posts and special Black Edition casework.
The Black Edition features the new top-of-the-line ESS SABRE 9038 PRO fully balanced double-quad DAC. AVM uses only the best 2% pre-selected DACs then applies additionally temperature-stabilized high-precision clocks.
The DACs are powered by a double regulated highly refined separate power supply. The circuits are channel-separated on their own circuit boards for perfect channel separation performance.
AVM CS 8.3 Rear
This additional efforts improve the signal-to-noise ratio considerably compared to the already outstanding CS 8.3 standard version. In addition, these converters can also process DSD128 (5.6MHz) signals. The sampling electronics allow adjustable sampling rates on the SPDIF inputs (44.1-192kHz) and enable the selection between two filter characteristics (smooth / steep).
In this process, the clock of the digital signals is completely regenerated and, due to this effort, jitter is effectively and practically completely eliminated. In addition, the CS 8.3 can also down-sample; this function is important for playlists with different sampling rates and formats from different sources.
The signal routing of the digital signals is consistently impedance controlled. The USB input is XMOS-based, galvanically isolated and always works asynchronously. Without driver up to 96kHz, with suitable driver up to 384 kHz and with DSD128.
CD Playback
The Pure CD drive is supplied exclusively for AVM by the renowned manufacturer TEAC. Worldwide, only AVM is supplied with these unique drives. The special feature of this drive, which is based on a mono-focal laser, is the pure CD playback according to the so-called Red-book Standard with the signal output as SPDIF signal to the following D/A converter stages.
The sound advantage of this drive is thus exclusive to AVM. The drive in the CS 8.3 is also heavily noise-insulated with thick acoustic felt mats. The CS 8.3 is completely software updatable.
In addition, important parts of the digital circuits can be easily replaced, the complete D/A converter board and the XMOS input board are replaceable and the CS 8.3 is thus also hardware upgradeable.
As a matter of principle, they only use 4-layer circuit boards with black coating in the OVATION CS 8.3, the inner layers of which serve as power supply and house the ground lines.
The entire signal path is completely DC- coupled. Three low-noise switching power supplies provide separate power for analog + and – (including so-called low-drop-out controls), one power supply provides power for all digital circuits, whereby the digital audio section is regulated separately.
According to Jay Rein, president of Bluebird Music, “this additional effort improves the signal-to-noise ratio considerably compared to the already outstanding CS 8.3 standard version. The special amplification circuit, designed and refined over several product generations, is extremely faithful to the original performance and the tubes, which are operated gently, are estimated to have a life expectancy of over 20,000 hours.”
The CS 8.3 Black Edition features a custom-made Pure CD drive with mono-focal laser, a 500 watt stereo amplifier, (250 watts into 8ohms) and AVM’s rock-solid X-Stream Engine which supports: Apple AirPlay2, Spotify Connect, Roon Ready, TIDAL Connect, Qobuz, UPnP, Webradio. Multiroom & Party Sync Mode, Bluetooth 4.2, 384kHz/32bit, DSD128, and offers convenient control via RC X App of iOS & Android.
A high quality class-A headphone amplifier is also included.
AVM CS 8.3 Features
  • All-in-One Streaming CD Receiver with 2 x 500 W (into 4 ohms)
  • Black Edition Tube
  • X-STREAM Engine® for HiRes streaming incl. DSD, controllable over RC X APP
  • USB A for external hard drives (NTFS & FAT)
  • 1 XLR line input, switchable as Hometheatre Thruput
  • Bluetooth 4.2
  • Multiroom function: AVM RoomConneXion®
  • Headphone output 6.3mm on front panel with dedicated Class-A headphone amp
  • Pure CD mechanism with Slot-in (Red-Book standard), exclusive to AVM
  • Digital signal conversion with to selection Double-Quad DAC for max. 384/32 PCM and/or DSD 128 (ESS SABRE 9038 Reference DAC)
  • Tone control and parametric loudness with bypass-function (controllable also over RC X APP)
  • Numerous menu functions (adjustable input sensitivity, individual naming of inputs and more)
  • Minimal stand-by power consumption and auto power down (APD)
  • Compactsize:43cmx13cmx38cm(WHD)
  • Trigger in, ext. IR Sensor, 2 x Trigger out
  • Streaming formats: MP3, WMA, AAC, OGG Vorbis, FLAC (192/24 via LAN), WAV (192/24 über LAN), AIFF (192/24 über LAN), ALAC (96/24 via LAN)
  • Webradio: Airable Internet Radio Service, Internet Radio Station Database (automatic updates)
  • Streaming Services: Spotify Connect, AirPlay, Qobuz, Tidal, HighResAudio, ROON ready, Webradio
  • WLAN & LAN
  • 2 variable outputs (balanced and unbalanced)
  • Digital inputs: 1 x USB (asynchronously galvanically isolated, DSD128/384 kHz), 1 x S/PDIF coaxial, 2 x S/PDIF optical, 1 x AES/EBU)
  • 2 digital outputs (S/PDIF coaxial & S/PDIF optical)
  • Upsampling rate adjustable from 44.1kHz/16bit to 192kHz/24bit
  • 2 switchable digital filters (smooth/sharp)
  • Low-diffusion power supplies, separate for CD-drive and audio electronics
  • Large, blue illuminated graphic display, dimmable
  • Supplied in AVM OVATION Flight Case
Price & Availability
The Black Edition is offered in a new “night black” livery featuring special casework and black knobs, as well as a silver finish with silver knobs. The improved CS 8.3 Black Edition is offered at the same price as the standard CS 8.3 model, which is $17,495, ($22,495 in Canada).
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Hi-Fi Components
High-end manufacturers in Asia and Europe were caught off-guard by the unexpectedly high tariffs levied yesterday but one distributor was already ready.
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
A Wireless and Bluetooth network player that does both TIDAL Connect and Spotify Connect? The $99 Wiim Mini has us very intrigued.
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Ditch those headphones. Immersive music sounds best through speakers. Here's how to make that happen in your home.
Qobuz now offers a limited selection of digital music in DSD and DXD formats from about $20 per album, but should you pay extra...
At $4,699, the Denon AVR-A10H home theater receiver offers significant savings over last year's flagship model.
