Netbooks
Averatec N1231 Netbook
10-inch Netbook with 3 to 6 Hours of Battery Life
TriGem USA just announced the Averatec N1200 Series netbook, the thinnest, lightest 10.1-inch netbook on the market today. The netbook weighs in at 2.2 pounds, measures less than one-inch thick, and offers up to six hours of battery life with the extended battery model. The N1200 will be offered in different models to match a customer’s computing needs and budget requirements, with prices ranging from $329 to $379.
Three models will be offered and feature various configurations based on either the Windows XP Home or Windows 7 Starter operating systems. Extended battery models will also be available to increase battery performance from three to six hours.
To achieve this design, the engineering team at TriGem incorporated materials and components typically found on more expensive ultra-slim notebooks. Cutting-edge technologies such as ultra-slim LED LCDs along with super-slim 7mm hard drives are some of the key components which enable the N1200 Series netbook to be less than one-inch thick. Magnesium-alloy casing and the use of lithium polymer battery cells help to keep the weight down to 2.2 pounds, making it the lightest in its class.
“To build a leading-class netbook, you need to think about how it should be built,” said Bob Davidson, TriGem USA senior vice president. “The lines between low-cost netbooks and ultra-portable notebooks are becoming blurred and consumers are no longer satisfied with mere compact clamshell-shaped netbooks. They want all the premium styling and features found in ultra-portable notebooks but at much more affordable prices.”
The new Averatec N1200 Series netbook features a 1.66GHz Intel Atom N450 processor and operating system options for either Microsoft Windows XP Home or Windows 7 Starter. For videoconferencing and video Web chat, the netbook includes a 1.3-megapixel webcam. Storage options include 160GB and 250GB hard drives and the N1200 comes standard with 1GB DDR2 memory which is expandable to 2GB of total system memory.
The Averatec N1200 Series netbook is available for purchase this month at retail partners such as BestBuy.com, TigerDirect.com and OfficeMax.com.
TriGem’s products are backed by a one-year limited warranty and one-year of U.S.-based technical support available Monday through Friday, 8 a.m. to 5 p.m. Pacific Time.
Specifications — Model N1200 Series
Model Name N1231EA1E-1S (Silver)
N1231EA1E-1B (Bronze)
N1231EE1E-1 (Silver) N1231FE1E-1S (Silver)
N1231FE1E-1 (Bronze)
Battery (hrs) Up to 3hrs Up to 3hrs Up to 6hrs
Screen Size 10.1″ Wide LED LCD (16:9)
(1024 x 600)
(1024 x 600)
(1024 x 600)
Processor ATOM N450 (1.66GHz) ATOM N450 (1.66GHz) ATOM N450 (1.66GHz)
Chipset Intel NM10 Intel NM10 Intel NM10
Memory 1GB DDR2 1GB DDR2 1GB DDR2
Hard Drive 160GB HDD 160GB HDD 250GB HDD
Optical N/A N/A N/A
WLAN 802.11N 802.11N 802.11N
LAN 10/100 LAN 10/100 LAN 10/100 LAN
Bluetooth None None Bluetooth
Video Solution Intel Integrated Intel Integrated Intel Integrated
Webcam 1.3 megapixel 1.3 megapixel 1.3 megapixel
Operating System Windows XP Home Windows 7 Starter Windows 7 Starter
Audio High Def. Audio High Def. Audio High Def. Audio
Weight/Dimensions 2.2lbs/10.7″x6.5″x.9″
(without the feet)
(without the feet)
2.46lbs/10.7″x6.5″x.1.0″
(without the feet)
MSRP $329.99 $349.99 $379.99
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
