Avantgarde Acoustic’s MEZZO G3 Horn-loaded Speakers: HIGH END Munich 2024
Art or speaker? The MEZZO G3 is available in two versions: semi-active and fully active with unique iTRON power amplifier while taking up less space than the flagship TRIO.
Avantgarde Mezzo G3 Loudspeakers with Red Horns
High End Munich 2024 concluded in mid-May, but there were still a number of new introductions that we feel warrant some commentary.
Avantgarde Acoustic, based in Germany, debuted their new MEZZO G3 Loudpeaker at the show. The main distinguishing feature of the MEZZO G3 is its iconic horn design that has been a mainstay of the brand for over 30 years.
For those old enough to remember the Uno, Duo, and Trio models that made the German brand rather successful in the 1990s, the MEZZO G3 feel somewhat understated from an industrial design perspective and that will likely make them an easier sell for many.
Avantgarde Mezzo G3 Loudspeakers Side Angle
Our experience with the aforementioned models was always somewhat of a mixed bag; proper alignment of the drivers and positioning of the loudspeakers were critical to getting the maximum amount of performance out of them.
EIC Ian White recalls more than a few Avantgarde demonstrations with very expensive amplification that were shockingly poor considering the extremely high price of admission.
Get everything correct, and the older models could absolutely vanish in your listening room and deliver a rather immediate and forceful sounding presentation.
Get it wrong — an absolute mess that would have a hard time making a case for itself against most systems today under $10,000. And that includes everything.
The new MEZZO G3 look and feel rather different.
Avantgarde Acoustic Mezzo G3 Loudspeakers with Red Horns at High End Munich 2024
The MEZZO G3 loudspeaker system is the result of years of research. It is designed to deliver great sound while also having an artistic, decorative, that dominates, rather than blending into, a room environment. Among the line up it fits between the flagship TRIO and the DUO GT.
The MEZZO G3 is available in two versions: semi-active and fully active. The fully active version incorporates a unique iTRON power amplifier.
Tech Note: Semi-active means that the tweeter and midrange are passive (need to be connected to an external amplifier), and there is a built-in amplifier to power the subwoofer. Fully active means that the iTRON power amplifiers power the tweeter and mid-range in addition to the already included subwoofer amplifier.
Whether you choose the semi or fully-active version, the MEZZO G3 is designed to deliver a first-class sound experience.
From Holger Fromme: “We are incredibly proud to introduce the MEZZO G3 to the world,…Our team has worked hard to develop a speaker system that not only sets audiophile standards but also makes a statement in terms of design and craftsmanship. The High End in Munich offers the perfect stage to present this special loudspeaker to the world.
Avantgarde Acoustic Mezzo G3 Loudspeakers with Galactic Glow Horns
MEZZO G3 Core Features
Building on the efforts of the Avantgarde engineering and design team here are some core feature highlights of the MEZZO G3:
  • Enlarged horn-loaded bass reflex system for optimal bass power and performance. The bass reflex system incorporates two down-firing 120mm (4.7-inch) diameter tubes.
  • New generation Evolution drivers for increased dynamics, lower distortion, and even purer sound.
  • Innovative XT3 tweeter with new ‘Long Throw’ Horn, extended super tweeter frequency range, and extremely low distortion. The variable phase of the XT3 tweeter can be adjusted via a provided rotary knob.
  • Coplanar arrangement of the acoustic center of all drivers/ This supports audio and spatial coherence.
  • NatureCapPlus, Avantgarde’s unique, proprietary new pure copper super-capacitor, supports additional sound listening refinement.
  • Equipped as standard with the E-Fuse circuitry, an electronic fuse for an even more precise dynamic reproduction.
  • iTRON Current Drive (optional) provides a fully active configuration for precise control of the driver output.
  • AirGate: This technology filters out high-frequency distortion.
  • Coplanar Driver Alignment: This means that all the speaker drivers are on the same plane. The distance between each of the drivers and the listener is the same.
  • NatureCapPlus Capacitors with PolarizationPlus circuitry: The crossover incorporates capacitors that are larger than previous iterations with a special high-grade foil and an adapted circuit layout.
Avantgarde Acoustic Mezzo G3 Loudspeaker White Dwarf Color
Multiple lacquer or wooden veneer finishes for the bass cabinets and new color and design options are available to provide the best look for your room.
Specifications
  • Frequency Range (Tweeter/Midrange): 170-28,000 Hz
  • Frequency Range (Subwoofer): 18-350 Hz
  • Power Handling: 100 Watts
  • Sensitivity (1 Watt/1 m): > 107 dB
  • Crossover Frequencies: 170/3,500 Hz
    Nominal Impedance: 18 Ohms
  • Recommended Amplifier Power: > 10 Watt
  • Recommended Room Size: > 20 sqm
  • Horn Type: Spherical
  • Horn Aperture Angle: 180 Degrees
  • Tweeter Horn Diameter: 25 mm (1-inch)
  • Midrange Horn Diameter: 170 mm ( 7-inch)
  • Bass Driver: 2 x XB12
  • Bass Driver Size: 300 mm / 12 inches
  • Bass Driver Voice Coil Diameter: 153 mm
  • Flux Density: 1.15 Tesla / 480 mm
  • Pole Plate: Low-carbon steel
  • Membrane Material: Paper/carbon fiber compound
  • Dimensions (WxDxH): 670 mm x 720 mm x 1,714 mm (26.4 x 28.3 x  67.48 inches)
  • Weight: 135.5 kg / 298 lbs
Bass Amplifier
  • Output power (RMS): 1x 1000 Watt
  • Digital Crossover: DSP
  • Equalizer: 8 Band EQ
  • Digital Room Adjustment
  • Inputs: 1x SPKR + 1x XLR
iTRON Electronics (Optional – full active version)
  • iTRON voltage/current converter technology: patented
  • Fully balanced circuit: yes
  • Single-ended circuit” yes
  • Zero Feedback: yes
  • Without negative feedback: yes
  • Power: 2 x 100 Watt
Modular Technology
This facilitates future electronic system upgrades if needed. This also means that if you initially purchase the semi-active version of the MEZZO G3, you can upgrade to the fully active version at a later date. Special connections are provided to facilitate the upgrades.
Price & Availability
The MEZZO G3 (semi-active version) is available for around $108,600/pair USD.
The MEZZO G3 with the inclusion of iTRON (fully active version), has an approximate price of around $132,800/pair USD.
Avantgarde Acoustic loudspeakers can be auditioned and purchased through Authorized Dealers in many color combinations.
For more information: avantgarde-acoustic.de
Related Reading
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Daily Deals
Didn't get that A/V receiver you wanted for Christmas? No worries. Onkyo's 9.2-channel TX-RZ30 just dropped to the lowest price we've seen.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Loudspeakers
Bang & Olufsen bets big on Union Square’s comeback, opening its largest store in a San Francisco still digging out from years of crime...
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
