AuthorPOINT 3.8 – Presentation Software for Rapid E-learning
Raleigh, NC Feb. 28, 2007
authorPOINT 3.8 has been released. Rapid e-learning presentations can be easily created in this improved SCORM compliant e-learning tool as it offers advanced functionality for instructors, teachers and presenters.
authorPOINT is a rapid e-learning presentation creation tool, which installs within PowerPoint as a toolbar and captures PowerPoint presentations when an instructor is presenting. It comes with the option to embed presenters’ video through a web cam as they present, or integrate video and audio as required.
Presentations created with authorPOINT can be saved in Flash or Windows Media formats. Further, the Flash file can be uploaded to a dedicated server on authorSTREAM which provides the presenter with a unique URL to deliver streaming Flash presentations.
authorPOINT 3.8 now offers advanced functionality for tutors and presenters with excellent PowerPoint capture; a new, improved Flash player; and optimized slide-size. The result is a better synchronization of slides in the final video outputs, and very reliable video output.
Interestingly, authorPOINT offers output to Windows Media format also, which is free without any limits in the trial version; this means that if your need is to convert PowerPoint to Windows Media video format, then you need not pay for this functionality. You can simply download the free trial here: Download authorPOINT
authorPOINT offers two download options: You can either download and run the “Smart Installer”, which checks your system for installed components, and downloads only the required ones, or you can download the full package of all required components needed to run authorPOINT.
Enhancements in authorPOINT 3.8:
· Very stable PowerPoint-capture process.
· New Flash player ensures better sync of slides in Flash output.
· Single slider for each slide in the flash player output.
· Size optimization of slides in Flash player output. Scroll option for large slides and center alignment for small slides is now supported.
· Very reliable presentation-to-video build function.
· New improved PowerPoint to flash conversion.
For details regarding system requirements and other information, please refer to technical details available here: authorPOINT 3.8 Release Notes
About authorGEN Technologies: Presentation Software for e-learning and services to enable virtual learning communication in online education are the playing fields of authorGEN since 2002.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
