Head Units
Audiovox AVDBR1 In-Dash Blu-ray Head Unit
Audiovox announced the industry's first automotive in-dash Blu-ray Disc player that plays any Blu-ray Discs as well as traditional DVDs and CD Audio Discs. The AVDBR1 head unit is installed under the seat or in a storage compartment in the vehicle and connects to any monitor by using either the HDMI, composite or component output.
The AVDBR1 has been road tested to tolerate the vehicle's environment and its small size allows for multiple horizontal and vertical mounting options in the vehicle. A blue accent light is used to illuminate the slot load disc area and button array. The unit is powered from a 2-pin, 12-volt connector to the vehicle's accessory power source and comes with a full function wireless IR remote control. An 18 foot long IR extension is also included to allow for operation of the system via remote control, while the unit is concealed, under a seat, storage compartment, trunk, or cargo area. The infrared sensor will accept the IR commands from a remote and relay it back to the unit. Note: WiFi capable — for wireless media streaming (firmware upgrade available 2011).
Price and Availability
The Audiovox AVDBR1 In-Dash Car Blu-ray Player will be available in the spring of 2011 for $349.99.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
