The Audioengine S6 Compact Subwoofer is For Your Desktop?
The Audioengine S6 Compact Subwoofer is their smallest, but a perfect match for your desktop home office audio system.
Audioengine S6 Subwoofer on desktop
Audioengine has announced its latest compact-powered subwoofer, the S6 for $299.
Measuring only 10-inches high and 8.7-inches wide, this subwoofer is great for use in small spaces and with compact audio systems, such as the Audioengine A1-MR Wireless Multiroom Home Music System. It can also be used as an add-on subwoofer for other branded compact audio systems that have compatible subwoofer connections.
We’ve used the Audioengine A2+ speakers for over two years at home on the desktop and the S6 was badly needed to fill out the bottom octaves.
Audioengine S6 Subwoofer Two Drink Can Size
Audioengine S6 Subwoofer with and without grille
The S6 incorporates a front-firing 6-inch driver in a sealed cabinet design that can pump out bass as low as 33Hz and features adjustable volume and crossover controls, as well as a switchable phase switch so you can match it with the rest of your system.
Tip: Although the S6 isn’t wireless out of the box, you can use it as a wireless subwoofer with the purchase of the Audioengine W3 Transmitter/Receiver Kit ($149).
Specifications
  • Cabinet Construction: 15 mm MDF (Medium Density Fiberboard)
  • Amplifier Type: Class D
  • Power Output: 140 watts RMS, 210 watts peak.
  • Driver: 6-inch Front Firing
  • Inputs: 3.5mm, RCA/LFE inputs.
  • Outputs: None
  • Additional Connection: USB Charging Port for smartphones and other compatible devices.
  • Input Voltage: 100-240 V 50/60 Hz auto-switching
  • Signal-to-Noise Ratio (SNR): >100 dB (typical A-weighted)
  • Frequency Response: 33Hz – 132Hz ±1.5dB
  • Crossover Frequency: Adjustable from 40Hz to 130Hz
  • Phase: Adjustable from 0 to 180 degrees.
  • Protection: Output current limiting, thermal over-temperature, power on/off transient protection
  • Power Consumption: Less than one watt (idle) – Auto-Sensing Standby Mode
  • Dimensions (HWD): 10-inches (25.2 cm) x 8.7-inches (22.2 cm) x 10-inches (25.3 cm)
  • Weight: 15.4 lb (6.98 kg)
  • Total Shipping Weight: 18.2 lb (8.26 kg)
  • Shipping Box Dimensions (LWH): 13-inches (33 cm) x 13-inches (33 cm) x 14-inches (35.6 cm)
Audioengine S6 Subwoofer Rear Connections
What’s In The Box
Here are the accessories included with the S6 compact subwoofer:
  • 1 S6 Subwoofer
  • 1 Subwoofer Setup Guide
  • 1 Detachable AC power cord
  • 1 3.5 mm audio cable
  • 1 RCA Audio Cable
  • 1 Microfiber Subwoofer bag
  • 1 Microfiber cable bag
Audioengine S6 Subwoofer with Grille
Pricing and Availability
The S6 compact subwoofer is available now for $299 from Amazon or direct from Audioengine. The S6 is available in its original Space Grey finish or Limited Edition Matte White and Matte Black finishes.
Other Audioengine Subwoofers are also available:
1 Comment
1 Comment
  1. vincent mchale
    January 25, 2022 at 5:35 pm
    Guess you can’t go from your amp to the sub and then out to the main spkrs?
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
