Audioengine Introduces HD4 Wireless Speakers with aptX-HD
At $449 a pair, Audioengine’s latest wireless speaker seeks to provide better bang for the buck for listening in smaller sized rooms.
Audioengine HD4 Wireless Speakers on a shelf
Audioengine, the company known for their desktop powered speakers, is introducing a new model to its legacy HD-series named the HD4. At $449 a pair, the HD4 sits in the middle of the HD-series range between the HD3 ($349) and HD6 ($699), both in terms of price and performance.
The company says the HD4 speakers offer versatile, high-fidelity audio for smaller spaces with excellent music reproduction that surrounds you with a sense of presence that most compact systems often miss. They can be used in a desktop environment with a laptop of PC or on a bookshelf.
Audioengine HD4 Wireless Speakers Front
As with all the speakers in the HD-series, the HD4 features Bluetooth aptX-HD for enhanced wireless fidelity from devices (mainly smartphones and laptops) that support the aptX-HD technology. Although it should be noted Apple has never supported aptX or the improved aptX-HD in any of their products, so there’s no extra benefit if you’re wirelessly connecting an iPhone, iPad or MacBook. Nonetheless, many Android phones do support aptX-HD, which can improve wireless sound quality when the music source is of higher quality.
Besides wireless, HD4 offers wired connections via USB input from a computer, a stereo mini-jack, and RCA inputs and output. The left speaker has a convenient volume/power knob on the front and also contains the internal amplifier. So to connect up the right speaker you’ll need to run a speaker cable (included) into it. Like many wireless speakers, they’re not completely wire-free.
Audioengine HD4 Wireless Speakers Rear
Features
  • Quick and easy setup
  • No network setup, no passwords, no hassle
  • Versatile playback in any room, from any app or device
  • High-fidelity stereo sound for desktops and small spaces
  • Modern, compact design that fits in and fills up any room
  • Low-latency Bluetooth aptX-HD, extended-range wireless streaming
  • Analog input for easy turntable connection
  • Aramid fiber woofers and silk dome tweeters
  • Built-in power amps wrapped in precision tuned, hand-built and  finished wood-veneer cabinets
Specifications Comparison
HD3HD4HD6
MSRP$349.00$499.00$699.00
Power output60W peak power total (15W RMS / 30W peak per channel), AES120W peak power total (30W RMS / 60W peak per channel), AES150W peak power total (50W RMS, 75W peak per channel)
Drivers2.75″ aramid fiber woofers, 3/4″ silk dome tweeters4″ Aramid fiber woofers, 3/4” silk dome tweeters5.5″ aramid fiber woofers, 1″ silk dome tweeters
Frequency response65Hz-22kHz +/-2.0dB60Hz-22kHz +/-1.5dB50Hz-22kHz +/-1.5dB
DACOPA2134AKM AK4396
Inputs3.5mm stereo mini-jack, stereo RCA, USB, Bluetooth3.5mm stereo mini-jack, USB, RCA L/R, Bluetooth3.5mm mini-jack, RCA L/R, digital optical (SPDIF) Bluetooth aptX
BluetoothAAC, aptX, aptX HDaptX HD, aptX with very low latency, aptX, AAC, SBCAAC, aptX, aptX HD
OutputsRCA variable line-out, 3.5mm mini-jack headphone outDual RCA variableVariable line-out w/2.0V RMS max output, 47ohm output impedance
Input voltages110-240V 50/60Hz auto-switching110-240V 50/60Hz auto-switching115/240V, 50/60Hz manually-switchable
Amplifier typeDual analog class A/B monolithicDual analog class A/B monolithicDual analog class A/B monolithic
SNR>95dB (typical A-weighted)>95dB (typical A-weighted)>95dB (typical A-weighted)
THD+N<0.05% at all power settings<0.05% at all power settings<0.05% at all power settings
Crosstalk<50dB<50dB<50dB
Analog input impedance5K ohms unbalanced48Kohms unbalanced (mini-jack and RCA inputs)
Weight (LEFT speaker)4 lbs (1.8kg)17.5 lbs (8kg)
Weight (RIGHT speaker)3.4lbs (1.5kg)12.5 lbs (5.5kg)
Dimensions, each speaker (HWD):7” x 4.25” x  5.5”6.5” x 5.5″ x 9”11.75″ x 7.25”  x 10”
ColorsSatin Black, High-Gloss White, WalnutSatin Black, WalnutSatin Black, High-Gloss White, Walnut, Cherry
Price & Availability
The Audioengine HD4 wireless speakers are available now for $449 at Amazon, direct from audioengineusa.com and from over 400 authorized worldwide resellers.
NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
FiiO FX17 IEM FiiO FX17 IEM
Earbuds & In-Ear Headphones
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
