Audioengine’s HD4 Next Gen Wireless Speakers Get Bluetooth 5.3, AptX Upgrades
For 2025, the Audioengine HD4 Next Gen wireless speakers add Bluetooth 5.3, aptX Adaptive, and USB-C connectivity for less than $450.
Audioengine HD4 Next Gen Home Music System in Walnut with Black Grilles Lifestyle
Powered speaker system specialists Audioengine have introduced the latest addition to their lineup: the HD4 Next Gen Music System. Building on the success of the original HD4 released in 2021, the HD4 Next Gen refines and enhances the original design, reinforcing Audioengine’s commitment to high-quality analog audio reproduction, handcrafted craftsmanship, and simple, user-friendly setup.
Designed for seamless connection to turntables and for streaming high-resolution music from your digital library, the HD4 Next Gen delivers full-range sound in a compact form — perfect for desktop setups and personal listening. There are no apps, no passwords, and no learning curve — just plug in your components and start listening.
Featuring analog inputs, a built-in DAC (PCM 5100A) for digital sources, and a dedicated headphone output, the HD4 Next Gen is engineered to deliver the perfect balance of analog warmth and digital convenience.
Audioengine HD4 Next Gen Home Music System in Walnut No Grilles
Amplifiers & Speaker Drivers
The HD4 Next Gen features Class A/B amplifiers that preserve the natural sound signature Audioengine is known for. Each system includes one active and one passive speaker, both equipped with custom aramid fiber woofers and silk dome tweeters, housed in handcrafted real wood cabinets. The result is well-controlled bass, clear mids, and smooth highs, delivering accurate performance across formats from vinyl to Bluetooth.
Pro Tip: All amplification and inputs are located in the active speaker, which connects to the passive speaker using the included speaker cable.
Built-in Headphone Amplifier
In addition to speaker playback, the HD4 Next Gen includes a built-in headphone amplifier (OPA1602) designed to drive high-impedance headphones and in-ear monitors with clarity. Whether using speakers or headphones, the HD4 Next Gen offers a practical and versatile desktop audio solution.
Wireless Streaming with Bluetooth aptX Adaptive
Now equipped with Bluetooth 5.3 and aptX Adaptive, the HD4 Next Gen supports high-resolution 24-bit audio streaming while maintaining a stable connection. AptX Adaptive dynamically adjusts bit rates in real time to minimize dropouts and maintain consistent sound quality. Compared to standard Bluetooth codecs, it automatically optimizes performance based on the listening environment. The HD4 Next Gen offers a Bluetooth range of up to 100 feet, depending on conditions.
Connectivity
Audioengine HD4 Next Gen Home Music System Rear View Main Speaker
The HD4 Next Gen offers flexible input options, including RCA/3.5mm analog, USB-C, and Bluetooth 5.3, allowing easy connection to turntables, mobile devices, and computers.
For users who want to add low-end extension, the HD4 Next Gen allows connection of a subwoofer video the RCA analog outputs. Audioengine recommends pairing it with their S6 or S8 subwoofers, but any powered subwoofer can be connected.
Build Quality
In line with Audioengine’s design approach, the HD4 Next Gen is built with quality materials and careful engineering. Its real wood cabinets, custom drivers, and analog amplifiers are intended to deliver detailed sound in a compact, simplified system.
Custom Finishes
The HD4 Next Gen Home Music System is available in Satin Black, Real Walnut Veneer, and Hi-Gloss Piano White. Each unit is handcrafted and finished using a detailed 13-step process, ensuring a high-quality, visually refined product that matches its audio performance.
Comparison
Audioengine HD4 Next Gen vs HD4 Speakers
HD4 Next Gen Music System (2025)HD4 (2021)
Product TypeWireless Powered Speaker SystemWireless Powered Speaker System
Price$429$399
Amplifier TypeClass A/B Class A/B
Power Output30W RMS per channel (measured in compliance with 16 C.F.R. § 432.3), 60W per channel (AES)
120W total peak power (AES)
Headphone AmplifierOPA1602 with 300mW power output @32ΩOPA2134 with 2.0 V RMS power output @32Ω
Drivers4″ aramid fiber woofers
0.75″ silk dome tweeters with neodymium magnets
Crossover FrequencyN/AN/A
Enclosure MaterialReal woodReal wood
Inputs3.5mm stereo mini-jack, RCA L/R, Bluetooth, USB-C3.5mm stereo mini-jack, RCA L/R, Bluetooth, USB
Bluetooth Version5.35.0
Bluetooth Codec SupportAptX Adaptive, aptX LL, aptX, AAC, SBCaptX HD, aptX LL, aptX, AAC, SBC
OutputsRCA variable line-out, subwoofer outputRCA variable line-out, 3.5 mm mini-jack headphone out
Frequency Response ±1.5 dB  60 Hz – 22 kHz60 Hz – 22 kHz
SNR (Signal to Noise Ratio)>95 dB>95 dB
THD+N<0.05%  <0.05%
Crosstalk<50 dB  <50 dB
Input Voltages110-240 V 50/60 Hz auto-switching 110-240 V 50/60 Hz auto-switching
FinishSatin Black, Walnut, Hi-Gloss Piano WhiteSatin Black, Walnut
Dimensions9″ (23 cm) x 5.5″ (14 cm) x 6.5″ (16.5 cm)9″(23 cm) x 5.5″ (14 cm) x 6.5″ (16.5 cm)
WeightLeft (active) – 7 lb (3.2 kg)
Right (passive) – 5.2 lb (2.4 kg)
In the BoxBluetooth antenna
Banana Connector Speaker Cable
AC power cord
3.5mm/ RCA audio cables
USB-C cable
Quick start guide
Protective microfiber bags for speakers and cables
Bluetooth antenna
AC power cord
USB cable
Quick start guide
Audioengine HD4 Next Gen Home Music System in White Lifestyle Without Grilles
The Bottom Line
Audioengine continues its reputation for delivering reliable, high-quality wireless powered speakers with the HD4 Next Gen, offering impressive sound and versatile connectivity at a price under $450. The inclusion of Bluetooth 5.3 and aptX Adaptive enhances its wireless performance, while USB Type-C connectivity allows direct connection to smartphones.
However, the absence of HDMI-ARC limits its convenience for TV audio integration. Also, HD4 Next Gen does not have an internal MM phono pre-amp, which means that you will need to use a turntable with its own or an external phono preamp between the turntable and the HD4 Next Gen’s analog inputs.
Despite the above connection omissions, the HD4 Next Gen remains a strong option for those seeking excellent desktop audio in a compact, user-friendly package.
Pricing & Availability
The Audioengine HD4 Next Gen Home Music System is available for $429 at Amazon, select retailers and direct from Audioengine.
iFi Go Pod Air Wireless IEM Adapter Collage
Earbuds & In-Ear Headphones
At $249, the iFi GO Pod Air brings wireless hi-res audio to your IEMs without the weight of its predecessor. Same hi-res magic, now...
iFi Up Travel Bluetooth DAC iFi Up Travel Bluetooth DAC
Dongle DACs
Transform your travel audio from ‘meh’ to ‘oh wow’ with the iFi UP Travel. Hi-res Bluetooth, crystal-clear calls, and a design so sleek, you...
DALI V-16 F Subwoofer DALI V-16 F Subwoofer
DALI's flagship 16-inch subwoofer is a 1500-watt beast built to match its KORE and EPIKORE speakers, offering low distortion extension down to 18Hz.
We are Rewind GB-001 Boombox We are Rewind GB-001 Boombox
Rediscover retro cool with the We Are Rewind GB-001 boombox—Bluetooth-enabled, rechargeable, and built for modern mixtape lovers. Vintage vibes, modern tech, all in one...
PMC prophecy9 Speakers Lifestyle PMC prophecy9 Speakers Lifestyle
Discover PMC's latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Mother's Day Gift Guide 2025 for Audio Video TV Lifestyle Projectors and Gadgets
Upgrade Mom's home audio and video experiences this Mother's Day with 10 gift ideas she'll absolutely love -- and you might too.
Digital Music Systems
Bluesound updates the NODE, while adding a less expensive NODE NANO at $299 and new flagship NODE ICON at $999.
The WiiM Sound smart speaker and WiiM Sub Pro deliver budget-priced multi-room wireless music streaming. Should Sonos be worried?
HDTV 4K & 8K TV
Digital Trends claims ownership of Caleb Denison's new YouTube channel called CalebRated leading to all videos being removed from public view.
The Gryphon Antileon Revelation Amp offers a powerhouse at $45,500. Want more? Go Mono for double the price. Arriving August 2025.
Meze Audio's 105 SILVA is a bold statement in design and sound, making the rest of the industry sweat. With its striking looks and...
REL’s T/9X SE Subwoofers in French Racing Blue and Green With Envy™ debut at High End Munich 2025—because why should audiophiles settle for boring...
A/V Furniture & Accessories
New and improved acoustic isolation feet that simply make loudspeakers sound better. Just choose the size closest to the weight of your speaker.
No streamer. No HDMI. No phono. Just raw power, a sharp DAC, and zero patience for excuses. The WiiM Vibelink Amp isn't here to...
