Audioengine A2+ Wireless Powered Desktop Speakers Announced
Audioengine just released A2+ Wireless powered desktop speakers for $269 in red, black or white just the original model now with Bluetooth.
Audioengine A2+ Wireless Desktop Powered Speakers in Red
A2+ Speakers Now With Bluetooth
Audioengine’s smallest desktop speakers, the model A2+ are now available in a Bluetooth version called A2+ Wireless. The $269 powered desktop speakers offer a clutter-free way to enjoy audio from your laptop or PC. They’re $50 more than the regular A2+ (wired only) speakers. Although the new speakers add wireless connectivity, the stereo pair still needs to be connected to one another via speaker cable (included), because the amplifier is only housed in left speaker. Wireless setup takes about a minute and no apps to download or wi-fi passwords are needed.
Audioengine A2+ Wireless Desktop Powered Speakers in Black with stands
A2+ Wireless with DS1 stands (not included, cost $29)
Thanks to Bluetooth version 5.0, A2+ Wireless offers up to 100 feet range with no drop-outs and no blips. The implementation of the aptX codec allows for near lossless audio transmission, as long as the source (laptop/tablet) is aptX compatible. Even so, audiophiles may want to attain the best listening experience via its USB cable connection. For further versatility, A2+ Wireless includes an input to add an external subwoofer, as well as extra ports for connecting other audio sources.
Audioengine A2+ Wireless Desktop Powered Speakers in White front / back views
Unlike most small computer speakers, Audioengine 2+ Wireless cabinets are constructed of 18mm-thick high-density fiberboard, rather than plastic. The woofer cones, of high-quality Aramid fiber with custom voice coils and magnets, produce surprisingly low, smooth bass and mid-range.  The tweeters, silk-dome and neodymium fluid-stabilized, provide sweet highs. The amplifier is a class A/B design, for premium sound reproduction. In addition, an auto-standby idle mode is also included to conserve power when you’re not playing music.
Pricing and Availability
Audioengine A2+ Wireless are available for $269 at Amazon or direct from Audioengine. They come only as a pair in black, white or red.
Specifications
  • Type: 2.0 powered (active) multimedia desktop speaker system
  • Amplifier type: Dual class AB monolithic
  • Power output: 60W peak power total (15W RMS / 30W peak per channel), AES
  • Drivers: 2.75″ aramid fiber woofers, 3/4” silk dome tweeters
  • Inputs: 3.5mm stereo mini-jack, RCA, USB, Bluetooth
  • Outputs: RCA variable line-out
  • Mains voltages: 110-240V 50/60Hz auto-switching
  • SNR: >95dB (typical A-weighted)
  • THD+N: <0.05% at all power settings
  • Crosstalk: <50dB
  • Freq. response: 65Hz-22kHz ±2.0dB
  • Input impedance: 5K ohms unbalanced
  • Protection: Output current limiting, thermal over-temperature, power on/off transient protection
  • USB specifications:
    • Connector type: Micro USB
    • USB device class: type 1.1 and above
  • Internal D/A converter: CSR8670
  • Input bit depth: up to 16 bits native
  • Input sample rate: up to 48KHz native
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
