Car Equalizers
AudioControl LCQ-1 Car EQ and Signal Processor
AudioControl announce the LCQ-1, a powerful, six-channel signal processor which provides an audio bridge between factory installed source units and after-market car amplifiers. Mobile Electronics enthusiasts can now easily install and “tune” audio systems that will truly outperform OEM. The LCQ-1 is an ideal combination of discrete equalization controls combined with AudioControl's active speaker level integration circuitry. Enthusiasts who want audio performance that only comes from custom tuned audio systems but want to utilize their factory installed source units will truly enjoy the LCQ-1.
“The LCQ-1 allows dealers to easily interface with factory installed audio systems and utilize precise equalization controls to optimize the sound, said Chris Kane of AudioControl.
Designed for maximum sound quality and enhanced audio performance, the LCQ-1 is the latest AudioControl processor to incorporate AccuBASS . This patent pending process automatically corrects for the bass roll-off that is common with many factory-installed audio systems. AudioControl engineers designed the LCQ-1 to be a very high-value processor, so subsequently it was equipped with a number of installer friendly features that simplify the connection and calibration process.
Features
  • Individual equalization controls for the front, rear and subwoofer channels
  • Input For Optional ACR-2 Remote Level Control with equalization switching – Allows for control of subwoofer output plus equalization bypass for highly effective demos.
  • Six channels of active speaker level inputs — accepts up to 400 watts per channel
  • Internal Channel Summing — For interfacing with factory installed amplifiers with built-in crossovers
  • GTOTM (Great Turn-On) Circuit — Powers up the LCQ-1 when it detects signal on the speaker level input
  • Fixed and variable outputs with discrete level controls
The LCQ-1 is housed in a compact (6″x 6″) chassis allowing for ease of installation. Like all AudioControl signal processors, the LCQ-1 is backed by an industry leading, five-year parts and labor warranty, when installed authorized AudioControl dealers.
Price and Availabililty
The LCQ-1 will be available through authorized AudioControl dealers in June 2011 for $299.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
