Audio-Technica Releases 3 New Wireless Earphones
Audio-Technica ATH-CKR75BT Sound Reality Wireless In-Ear Headphones
If Apple AirPods aren’t your thing, Audio-Technica has three new Sound Reality in-ear Bluetooth headphones priced from $69 to $149 for you to consider. The top two models include built-in amplifiers (ATH-CKR75BT and ATH-CKR55BT), while the lowest priced ATH-CKR35BT makes wireless listening affordable.
The ATH-CKR75BT ($149, pictured top) utilizes high-precision 11.8 mm drivers that deliver powerful, smooth and extended frequency reproduction from 5 Hz – 40,000 Hz. The drivers are mounted in rigid, lightweight aluminum housings that greatly reduce unwanted resonance for clearer sound with exceptional resolution. The ATH-CKR75BT features a built-in amplifier that further enhances the headphones’ audio quality and is compatible with aptX and AAC (as well as SBC) codecs for the best-possible wireless audio reproduction.
Like all the new Sound Reality in-ear headphones, The ATH-CKR75BT features an in-line omnidirectional mic and controls that enable the listener to answer calls, adjust volume and handle playback of music and videos on compatible smartphones and other devices. Its design conveniently situates the mic and controls for easy access. The internal battery in the ATH-CKR75BT (and the ATH-CKR55BT and ATH-CKR35BT) provides up to seven hours of continuous use and the headphones come with four sizes of eartips (XS, S, M and L) for a comfort-tailored fit, a USB charging cable, a secure-fit battery clip and a carrying case.
The Sound Reality ATH-CKR55BT ($99) features newly designed 10.7 mm drivers with wideband 5 Hz – 35,000 Hz frequency response, mounted in machined brass aluminum housings that reduce unwanted resonances for improved clarity. Its built-in amplifier contributes to the headphones’ impactful, detailed sound and compatibility with aptX, AAC and SBC codecs. The headphones’ design places the in-line mic and controls in a position for easy access. The ATH-CKR55BT comes with XS, S, M and L eartips, a USB charging cable and a carrying pouch and is available in a choice of black or blue colors.
Audio-Technica’s high-performance/high value ATH-CKR35BT ($69) combines superior sound quality with wireless Bluetooth convenience and an attractive, comfortable design. Its high-performance 9.8 mm drivers operate in conjunction with machined brass stabilizers to offer rich, full-range audio reproduction of 5 Hz – 24,000 Hz with remarkably clear midrange and high frequencies. The in-line mic and controls are integrated into a comfortable behind-the-neck design. The ATH-CKR35BT is available in black, blue and white and is supplied with a charging cable and carrying pouch.
“Our new in-ear Sound Reality models are designed to bring true high-quality wireless audio to more affordable price points,” said Bob Peet, Audio-Technica U.S. Marketing Manager.
Price and Availability
All are available now.
  • ATH-CKR35BT – $69 (black, blue, white)
  • ATH-CKR55BT – $99 (black, blue)
  • ATH-CKR75BT – $149 (gunmetal)
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
