Audio-Technica Introduces SpectraPulse Ultra Wideband Wireless Microphone System
— SpectraPulse offers secure wireless operation for the installed sound market free from RF competition, frequency coordination and “white space” issues —
STOW, OH, June 19, 2007 — Audio-Technica U.S., Inc. is introducing its revolutionary SpectraPulse Ultra Wideband (UWB) wireless microphone system at InfoComm 07. A completely new application of proven, patented Ultra Wideband technology, SpectraPulse bypasses the increasingly congested RF environment to deliver clear, intelligible audio without the performance and set-up issues associated with conventional wireless systems. It offers levels of security that have never before been commercially available in wireless microphones, making it ideal for conference or boardrooms, corporate events/meetings, courtrooms and other contractor/system integrator applications in the business, government and commercial markets. SpectraPulse utilizes up to 14 simultaneous channels that operate flawlessly without RF competition, frequency hunting/coordination, white space** issues or infringement from other wireless systems or radio sources.
Ultra Wideband (UWB) Technology — the next generation of wireless
Audio-Technica has partnered with Multispectral Solutions, Inc. (MSSI), the industry leader in the development of Ultra Wideband systems for communications, radar and geo-positioning, to introduce this new application of UWB technology. A-T’s SpectraPulse Ultra Wideband wireless microphone system represents the first commercial sound implementation of UWB technology, which has recently been licensed for commercial use by the U.S. Federal Communications Commission (FCC). Ultra Wideband technology allows the wireless transmission of data in extremely short-duration pulses over a wide spectrum of frequencies. Instead of utilizing conventional channels and carrier frequencies, UWB technology uses a series of short nano-second pulses which occupy an instantaneous bandwidth of 500 MHz within the 6 GHz frequency spectrum. The signals, in precisely timed sequences, result in the reliable transmission of information near noise-floor levels. The “decoding” of these pulses requires the specialized technology incorporated into the SpectraPulse system — making SpectraPulse inherently secure and preventing signal interception by other wireless systems. For a higher level of security, Audio-Technica offers an optional encryption package that meets the NIST-approved (National Institute of Standards and Technology) AES 128-bit encryption standard developed by the U.S. government for securing sensitive material.
The SpectraPulse System — simple, secure and revolutionary
The SpectraPulse Ultra Wideband wireless microphone system components include: the mtu101 Microphone Transmitter Unit; drm141 Digital Receiver Module; aci707 Audio Control Interface; and cei007 Charger Encryption Interface.
The mtu101 Microphone Transmitter Unit (in a boundary mic design) features a programmable touch-sensitive switch (that can be programmed for push-to-talk, push-to-mute, or toggle operation) and 9-hour rechargeable battery life. The drm141 Digital Receiver Module consists of a completely integrated UWB antenna and 14 channels of digital wireless transceiving (that mounts in a 3-gang electrical box) with power and data carried over a Cat-5 connection. The aci707 Audio Control Interface is a 1U rack mounting unit allowing the demultiplexing and audio output of up to seven channels, which are simply selected on the mtu101 Microphone Transmitter Unit. Seven distinct line/mic level audio outputs are provided on standard Phoenix-type connectors. A separate charger/encryption unit, the cei007 Charger Encryption Interface charges up to seven mtu101s and allows for encrypting the mtu101 units using optional encryption software.
For the contractor or system integrator, setting up a SpectraPulse system is simple and quick. Install the Digital Receiver Module (drm141) and connect it to the equipment rack via a standard shielded Cat-5 cable. In the rack, install up to two Audio Control Interface (aci707) units for a total of 14 separate microphone channels. Place up to 14 Microphone Transmitter Units (mtu101) out in the environment as required and set their individual addresses. Turn the system on, and SpectraPulse is ready to go. There is no frequency scanning or channel planning required.
**”White space” refers to the portions of the TV broadcast frequency spectrum that will be available after the federally mandated February, 2009 transition to digital TV. With the transition, a variety of unlicensed consumer devices, as well as proposed wireless broadband services, may be allowed to operate in these white space areas. Should this happen, wireless products used in live audio production, newsrooms, sporting events, boardrooms and other applications may not be able to operate without interference. Digital TV signals in some areas might also be affected by white space interference. Legislation is currently pending.
Celebrating over 45 years of audio excellence worldwide, Audio-Technica is a leading innovator in transducer technology, renowned for the design and manufacture of microphones, wireless microphones, headphones, mixers, and electronics for the audio industry.
Media Contact:
Frank Doris
FM Public Relations
631-385-1304 ext. 402
frank.doris@fm-group.net
— For more information on the complete range of Audio-Technica products, contact
Karen Emerson, Audio-Technica U.S., Inc., 1221 Commerce Drive, Stow, OH 44224. Tel: (330) 686-2600; Fax: (330) 688-3752; Web: www.audio-technica.com
— For further information regarding product availability and pricing in Europe, please contact Denise Burnage, marketing, Audio-Technica Ltd., Old Lane, Leeds LS11 8AG England. Tel: +44 (0) 113 277 1441, Fax: +44 (0) 113 270 4836
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
