Audio-Technica SonicPro ATH-MSR7 Headphones
Audio-Technica ATH-MSR7
Audio-Technica just announced the $250 SonicPro ATH-MSR7 Over-Ear Hi-Res Audio Headphones, designed to deliver the highest level of accuracy and musical realism with a frequency range up to 40 kHz. The headphones feature new, proprietary True Motion Drivers, which employ an exclusive 45 mm driver with a lightweight, highly responsive voice coil and diaphragm. The ATH-MSR7’s Multi-Layer Air Damping Technology utilizes a two-layer aluminum/magnesium housing that provides a lightweight yet rigid structure for the drivers to reduce unwanted internal vibrations that could color the sound. Within the multi-layer structure are three precisely placed air vents that control the airflow to provide greater dynamics and sonic impact. The housing is specially shaped to “mirror” the physical structure of the ear to enhance low-frequency sounds.
In addition, the ATH-MSR7 incorporates a mesh acoustic resistor that improves high-frequency response, and a low-frequency acoustic resistor for extended, accurate bass. The sonic result is a smooth, richly detailed, powerful and spacious sonic presentation that completely immerses listeners in the high-resolution audio experience.
Complementing its superlative sound quality, the ATH-MSR7 is designed for total comfort. Its cushioned, soft, memory foam earpads fit securely yet comfortably around the ears and its flexible swivel design and padded headband facilitate a perfect fit for any wearer.
The ATH-MSR7 is ideal for use with any music system or playback device whether it’s a home stereo, laptop, portable music player or smartphone. The headphones are supplied with a detachable 4-foot smartphone-compatible cable with an integrated controller and microphone that let the wearer answer phone calls and control music/video playback from compatible smartphones and other devices, including Android™-based systems, iPhone, iPad and iPod. The ATH-MSR7 also comes with a standard 4-foot and 10-foot cable and a carrying pouch.
Price and Availability
The Audio-Technica SonicPro ATH-MSR7 Over-Ear High-Resolution Audio Headphones will be available in March 2015 for $249.95 in black (ATH-MSR7BK) or gun metal (ATH-MSR7GM) with two-year warranty.
Specifications
Type Close-back Dynamic
Driver Diameter 45 mm
Frequency Response 5-40,000 Hz
Maximum Input Power 2,000 mW
Sensitivity 100 dB/mW
Impedance 35 ohms
Weight 290 g
Cable Detachable 1.2 m (3.9′) standard cable, detachable 3.0 m (9.8′) standard cable, detachable 1.2 m (3.9′) cable with in-line controls and microphone for smartphones
Connector 3.5 mm gold-plated stereo mini plug, L-shaped
Accessories Included Protective pouch
Type (Microphone) Condenser
Frequency Response (Microphone) 50 – 4,000 Hz
Polar Pattern (Microphone) Omnidirectional
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
