Audio-Technica has built its reputation on making high-quality, affordable turntables — the kind of gear that gets vinyl newbies hooked without draining their wallets. Most of its models sit comfortably between $200 and $500, making them a go-to brand for entry-level and budget-conscious audiophiles.
But last fall, the company decided to raise the bar (and the price tag) with the AT-LP8X, a $1,000 direct-drive turntable aimed squarely at more serious listeners. It was a bold move — and just a taste of what was to come. Like, you can’t even imagine how far off the traditional path Audio-Technica’s new flagship turntable ventures—it’s less “audiophile” and more “Deckard’s lounge rig after a long day of retiring replicants
Enter the Audio-Technica Hotaru — a futuristic marvel that looks like it time-traveled from Blade Runner but sounds like vinyl heaven. This is unlike anything Audio-Technica has ever made before: sleek, high-concept design meets uncompromising high-end performance. It’s a turntable built not just to impress, but to redefine what the brand can do when it’s aiming for the true audiophile elite — the kind with spaceship aesthetics and wallets to match.
And of course, there’s a weird catch—because nothing this futuristic comes without one. But hang tight, we’ll get to that in a minute.
The Hotaru Turntable
Innovative Floating Structure (a.k.a. Look Ma, No Gravity!)
Audio-Technica has come a long way since its humble 1962 beginnings as a maker of high-end phono cartridges. Back then, the brand focused on handcrafted precision — and that same obsession with detail is alive and well in the Hotaru. The stylus might be doing the groove-reading, but it’s the engineering behind the platter that ensures your records sound more like magic and less like mud.
Enter the Hotaru’s pièce de résistance: its levitating platter. Yes, levitating. Using a system of opposing magnets, Audio-Technica has created a literal floating turntable. The upper section — where your record spins in style — is suspended above the speaker base, effectively isolating it from vibrations that could muddy the sound.
It’s part anti-gravity lab experiment, part audiophile dream, and 100% guaranteed to make your Rega cry. Not only does it reduce unwanted noise, it does so while looking like it belongs in a Ridley Scott film. Because who says precision engineering can’t also be a flex?
Lighting System Where Light and Sound Merge (Because Your Turntable Should Party, Too)
The Hotaru doesn’t just play records — it puts on a show. Audio-Technica has equipped this sci-fi centerpiece with a built-in lighting system that reacts to your music like it’s been waiting for a DJ set all its life. Drawing from a 20-color palette, the lights respond in real-time to the music’s mood, tempo, and vibe, transforming your vinyl session into a multisensory experience.
You’ve got options, too. Basic Mode keeps things chill with a steady glow. Gradation Mode slowly shifts colors like a hi-fi lava lamp on Xanax. And Link Mode? That’s where things get wild — the light pulses and changes based on the actual character of the music. It’s not just listening anymore; it’s analog synesthesia, and your eyeballs are invited to the listening party.
It Plays (and Plays Itself): The Hotaru’s Confusing Built-In Speaker System
The Hotaru isn’t just a pretty face with its floating structure and dazzling lights — it actually plays music too. Inside the sleek aluminum base, Audio-Technica has nestled a speaker system that boasts four drivers: a pair of tweeters and a pair of full-range drivers. It’s like they thought, “Hey, why not throw in a speaker system to go with that ultra-premium price tag?”
Sure, it’s a nice touch for those who want to skip the speaker setup, but we can’t help but question the logic of including a speaker in a turntable that’s clearly aimed at audiophiles.
For those who are serious about their sound, though, fear not — the Hotaru does have a line-out port for those looking to connect to their existing high-end gear. And, because who doesn’t want to shake their walls a little more, it also features a subwoofer output. So while the built-in speaker might not blow your mind, you do have the option to upgrade the experience… if you’re willing to let go of that “all-in-one” vibe.
Specifications
- Motor: DC servo motor
- Drive Method: Belt drive
- Speeds: 33-1/3 RPM, 45 RPM
- Output Terminals
- Line output (RCA pin jack × 2)
- Subwoofer output (RCA pin jack × 1)
- Tonearm Specifications
- Type: Static balanced straight carbon tonearm
- Cartridge and Headshell Specifications
- Cartridge type: VM stereo cartridge (special specification)
- Headshell type: Original headshell
- Speaker Specifications
- Speaker unit: 63.5 mm (2.5″) × 2
- Tweeter unit: 19 mm (0.75″) × 2
- Frequency response: 60 to 20,000 Hz
- Sensitivity: 82 dB (1 W, 1 m)
- General Specifications
- Dimensions: 430 mm (17″) × 430 mm (17″) × 235 mm (9.3″) (W × D × H)
- Weight: Approx. 12 kg (26 lbs)
- Power supply requirements: 100 to 240 V, 50/60 Hz, 2.5 A Max.
- AC Adapter: 12 V, 7.5 A
- Included Accessories
- Platter
- Counterweight
- Headshell with VM stereo cartridge (special specification)
- 45 RPM adapter
- AC Adapter
- Power cable
The Bottom Line
If you’ve got the bankroll (and maybe some Tyrell Corporation connections), you can go ahead and preorder it directly from the company’s website. But don’t wait too long — preorders close on May 30th. After all, this is your chance to own a piece of futuristic, high-end audio tech before it becomes a collector’s item for replicants who love vinyl.
But, let’s be real: while the visuals and concept are impressive, we’re still in the dark about some key details — like the power specs, tonearm design, or what cartridge it ships with. Until those are revealed, it’s hard to say whether this is a true audio masterpiece or just another expensive piece of vinyl-glam tech.
Price & Availability
Unveiled at Milan Design Week, the Audio-Technica Hotaru is as rare as a flying car in Blade Runner — with only 1,000 units being produced. At a cool $9,999, it easily takes the crown as Audio-Technica’s most expensive turntable to date. But it won’t be released until August 2025.
For more information: audio-technica.co.jp
Related Reading:
Anton Gandy
April 18, 2025 at 12:01 pm
The speaker absolutely ruins this for me. For that price, include one of your better MC carts and integrate a $$$ internal phono section.
Would sell very well with all of those features.
Ian White
April 18, 2025 at 1:45 pm
I’m with you on this one. I don’t get the speaker angle at all. For $10,000 — Michell Gyrodeck SE with a high-end phono pre-amp and active speakers for $10,000 would destroy this thing.
I get whom they are trying to sell this to, however.
Deckard
rl1856
April 18, 2025 at 5:40 pm
A no frills option would be nice. Remove the light show, speakers and associated equipment.
Ian White
April 18, 2025 at 6:15 pm
Right?
Make it a $4K table with a great arm and good cartridge. I’m ok with adding a better quality internal phono pre-amplifier to make it easier for people to add to their systems. The light show doesn’t do it for me.
IW
