Audio-Technica ATH-PRO500MK2 DJ Headphones
ATH-PRO500MK2
Audio-Technica introduced its ATH-PRO500MK2 professional DJ monitor-style headphones, which bring the professional-style durability, functionality and audio quality that DJs rely on to listeners everywhere. Available in black, and a striking red and black version, the ATH-PRO500MK2 features swiveling earpieces (50°/90°) for every listening and monitoring preference and is engineered to deliver exceptional sound.
The ATH-PRO500MK2 employs large-diameter 53 mm drivers with an exceptionally wide 10 Hz – 30,000 Hz frequency response in acoustically efficient housings. The sonic result is authoritative, articulate bass, a clear, detailed midrange and open, well-defined treble. The headphones’ generously padded construction provides maximum comfort even during extended use, and the swivel ear pieces ensure a perfect fit for every listening and DJ monitoring application.
The ATH-PRO500MK2 has a durable frame and a soft elastomer grip that provides non-slip stability during DJ use. It is supplied with two detachable cords, one straight and one coiled that attach to the headphones with a screw-on connector. The ATH-PRO500MK2 is foldable for compact portability.
Price and Availability
The Audio-Technica ATH-PRO500MK2 DJ headphones are available now for $179.95 in red or black.
Specifications:
  • TYPE: Dynamic
  • DRIVER DIAMETER: 53 mm
  • FREQUENCY RESPONSE: 10 – 30,000 Hz
  • MAXIMUM INPUT POWER: 1,600 mW
  • SENSITIVITY: 106 dB
  • IMPEDANCE: 38 ohms
  • WEIGHT: 290 g
  • CONNECTOR: 3.5 mm gold-plated stereo mini-plug
  • ACCESSORIES INCLUDED: Screw-on 1/4″ (6.3 mm) adapter, detachable coiled cable (1.2 – 3.0 m), detachable straight cable (1.2 m), pouch
  • DESIGN:
    • Durable elastomer frame
    • Soft elastomer grip for non-slip stability during DJ use
    • Foldable for compact portability
    • Swiveling earpieces (50°/90°) provide versatile positioning for every monitoring preference
    • Easily replaceable detachable cord with screw-in connector
3 Comments
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
At $1,599, Audio-Technica's limited edition wooden audiophile over-ear headphones are handcrafted in Tokyo, but only 300 will be made.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
